    2017-7-16 11:47
  • 签到天数: 44 天
    奈何col 攻城狮 2016-6-15 17:36 楼主
    关于CurieNeurons
    CurieNeurons,即Curie神经元,
    Neurons能通过示例学习,不用编程,可以通过数据离线学习。
    能自主发现新内容或异常。
    general-vision提供了两个版本的下载,免费版和专业版,专业版售价19美刀。
    免费版下载:
    http://pan.baidu.com/s/1jI8kOaa
    收费版购买:
    http://www.general-vision.com/products/curieneurons/
    免费版与收费版区别:
    CurieNeurons
    CurieNeurons
    从字面上理解,就是收费版对动作的识别能更准确。我已经买了收费版,粗略的看了下库,两个版本并没有多大区别,猜测收费版只是添加了传感器数据融合,让数据更为准确。所以暂时不建议大家购买。
    下载并通过IDE导入库:
    现在我们可以开始我们牛逼哄哄的神经元编程之旅了。
    [C++] 纯文本查看 复制代码
      Example sketch using the Intel CurieIMU library and the General Vision CurieNeurons library
      for Intel(R) Curie(TM) devices
      Motion is converted into a simple feature vector as follows:
      [ax'1, ay'1, az'1, gx'1,gy'1, gz'1, ax'2, ay'2, az'2, gx'2, gy'2, gz'2, ...] over a number of time samples
      Note that the values a' and g' are normalized and expand between the running min and max of the a and g signals.
      After calibration is made,
      Use the serial monitor to edit the category of a motion,
        (ex= 1 for vertical, 2 for horizontal, 0 for stillness or anything else),
      Start moving the Curie in an expected direction,
      and when you press Enter the last feature vector is learned.
      Note that this "snapshot" approach is simplistic and you may have to teach several times
      a given motion so the neurons store models with different amplitudes, acceleration, etc.
      Ideally we want to learn consecutives vectors for a few seconds.
    #include "CurieIMU.h"
    int ax, ay, az;         // accelerometer values
    int gx, gy, gz;         // gyrometer values
    int calibrateOffsets = 1; // int to determine whether calibration takes place or not
    #include <CurieNeurons.h>
    CurieNeurons hNN;
    int catL=0; // category to learn
    int prevcat=0; // previously recognized category
    int dist, cat, nid, nsr, ncount; // response from the neurons
    // Variables used for the calculation of the feature vector
    #define sampleNbr 10  // number of samples to assemble a vector
    #define signalNbr  6  // ax,ay,az,gx,gy,gz
    int raw_vector[sampleNbr*signalNbr]; // vector accumulating the raw sensor data
    byte vector[sampleNbr*signalNbr]; // vector holding the pattern to learn or recognize
    int mina=0xFFFF, maxa=0, ming=0xFFFF, maxg=0, da, dg;
      Serial.begin(9600); // initialize Serial communication
      while (!Serial);    // wait for the serial port to open
      // initialize device
      Serial.println("Initializing IMU device...");
      CurieIMU.begin();
      // use the code below to calibrate accel/gyro offset values
      if (calibrateOffsets == 1)
        Serial.println("About to calibrate. Make sure your board is stable and upright");
        delay(5000);
        Serial.print("Starting Gyroscope calibration and enabling offset compensation...");
        CurieIMU.autoCalibrateGyroOffset();
        Serial.println(" Done");
        Serial.print("Starting Acceleration calibration and enabling offset compensation...");
        CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0);
        CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
        CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
      // Initialize the neurons and set a conservative Max Influence Field
      hNN.Init();
      hNN.Forget(1000); //set a conservative  Max Influence Field prior to learning
      int value=hNN.MAXIF(); // read the MAXIF back to verify proper SPI communication
      Serial.print("\nMaxif register=");Serial.print(value);
      Serial.print("\n\nEntering loop...");
      Serial.print("\nMove the module vertically or horizontally...");
      Serial.print("\ntype 1 + Enter if vertical motion");
      Serial.print("\ntype 2 + Enter if horizontal motion");
      Serial.print("\ntype 0 + Enter for any other motion");
        // Learn if push button depressed and report if a new neuron is committed
        if (Serial.available() == 2)
          catL = Serial.read();
          char inChar = (char)Serial.read();
          if (inChar == '\n')
            catL = catL - 48;
            Serial.print("\nLearning motion category "); Serial.print(catL);
            // learn 5 consecutive sample vectors
            for (int i=0; i<5; i++)
              getVector(); // the vector array is a global
              //Serial.print("\nVector = ");
              //for (int i=0; i<signalNbr*sampleNbr; i++) {Serial.print(vector[i]);Serial.print("\t");}
              ncount=hNN.Learn(vector, sampleNbr*signalNbr, catL);
            Serial.print("\tNeurons="); Serial.print(ncount);
          // Recognize
          hNN.Classify(vector, sampleNbr*signalNbr,&dist, &cat, &nid);
          if (cat!=prevcat)
            if (cat!=0x7FFF)
              Serial.print("\nMotion category #"); Serial.print(cat);
            else Serial.print("\nMotion unknown");
            prevcat=cat;
    void getVector()
      // the reset of the min and max values is optional depending if you want to
      // use a running min and max from the launch of the script or not
      for (int sampleId=0; sampleId<sampleNbr; sampleId++)
        //Build the vector over sampleNbr and broadcast to the neurons
        CurieIMU.readMotionSensor(ax, ay, az, gx, gy, gz);
        // update the running min/max for the a signals
        if (ax>maxa) maxa=ax; else if (ax<mina) mina=ax;
        if (ay>maxa) maxa=ay; else if (ay<mina) mina=ay;
        if (az>maxa) maxa=az; else if (az<mina) mina=az;
        da= maxa-mina;
        // update the running min/max for the g signals
        if (gx>maxg) maxg=gx; else if (gx<ming) ming=gx;
        if (gy>maxg) maxg=gy; else if (gy<ming) ming=gy;
        if (gz>maxg) maxg=gz; else if (gz<ming) ming=gz;
        dg= maxg-ming;
        // accumulate the sensor data
        raw_vector[sampleId*signalNbr]= ax;
        raw_vector[(sampleId*signalNbr)+1]= ay;
        raw_vector[(sampleId*signalNbr)+2]= az;
        raw_vector[(sampleId*signalNbr)+3]= gx;
        raw_vector[(sampleId*signalNbr)+4]= gy;
        raw_vector[(sampleId*signalNbr)+5]= gz;
      // normalize vector
      for(int sampleId=0; sampleId < sampleNbr; sampleId++)
        for(int i=0; i<3; i++)
          vector[sampleId*signalNbr+i]  = (((raw_vector[sampleId*signalNbr+i] - mina) * 255)/da) & 0x00FF;
          vector[sampleId*signalNbr+3+i]  = (((raw_vector[sampleId*signalNbr+3+i] - ming) * 255)/dg) & 0x00FF;
    待写
    以后我也可以装逼说,我在做深度学习了!
    gewenbin292 发表于 2016-6-16 17:09
    http://mp.weixin.qq.com/s?__biz=MzAwNjIzMzczMg==&mid=2650498756&idx=2&sn=240aa7689d8b629382d9546bdd4 ...
    事实证明,CurieNeurons也不是一个成熟的东西。。。
    创客大爆炸发的教程的例程和现在下载的有区别。。。
    现在下载的free中的example,其实是geek版本,但lib并不是,free版直接编译过不了~~~
    创客大爆炸那个文章让下载的免费版,但后面例程是收费版里的
    而免费版里的例程,调用了收费版的一个函数,直接编译过不了
    收费版的,是可以编译过的.......
    等Neurons更新了再弄了
    其实教程里写了如何调整代码诶~  发表于 2016-7-8 15:00
    如果你觉得以上内容帮到了你,你可以打赏支持作者
    听着好高级,首先得有一个神经元101不是
    请PY我
    只能假装看懂了
    打赏,是超越赞的一种表达
    明天把IMU的机器学习示例搬过来
    保守估计半年后~
    PY让世界更美好~
    gewenbin292 来自手机 新手上路 2016-6-16 17:02
    7#
    http://mp.weixin.qq.com/s?__biz=MzAwNjIzMzczMg==&mid=2650498756&idx=2&sn=240aa7689d8b629382d9546bdd4e3bca&scene=1&srcid=0614W1xA3QZSPrv5nTXwmPtO&from=groupmessage&isappinstalled=0
    gewenbin292 来自手机 新手上路 2016-6-16 17:06
    8#
    以上是创客大爆炸给的教程,我试过了,但感觉识别得不好。是不是没有融化imu数据啊?!最近考试没时间细研究了
    gewenbin292 来自手机 新手上路 2016-6-16 17:09
    9#
    123下一页
