    2017-7-16 11:47
  • 签到天数: 44 天
    奈何col 攻城狮 2017-3-12 17:36 楼主
    什么是机器学习
    机器学习领域的先驱ArthurSamuel,在其论文《Some Studies in Machine Learning Using the Game of Checkers》中,将机器学习非正式定义为:“在不直接针对问题进行编程的情况下,赋予计算机学习能力的一个研究领域。”例如要让Genuino 101判断其自身姿态是正面朝上,还是朝下时。常规做法是,计算出姿态角,并判断其是否在某一区间中;而使用机器学习,可以通过多次将Genuino 101朝上或朝下放置,并将此时传感器数据及姿态输入模式匹配引擎进行学习,此后Genuino 101即可根据新的传感器数据判断当前的姿态了。
    intel Curie的模式匹配引擎(patternmatching engine),带有128个神经元,支持k近邻法(k-Nearest Neighbors)和径向基核函数(Radial Basis Function)两种匹配算法。其让Curie具有了像人一样的学习、归类能力,进而可以省去某些繁琐的编程过程。
    Intel提供了CuriePME库用于驱动模式匹配引擎,其下载地址为:
    下载安装CuriePME后,可通过示例程序了解其使用方法。如下示例程序可用于学习并识别手势动作。
    * This example demonstrates using the pattern matching engine (CuriePME)
    * to classify streams of accelerometer data from CurieIMU.
    * First, the sketch will prompt you to draw some letters in the air (just
    * imagine you are writing on an invisible whiteboard, using your board as the
    * pen), and the IMU data from these motions is used as training data for the
    * PME. Once training is finished, you can keep drawing letters and the PME
    * will try to guess which letter you are drawing.
    * This example requires a button to be connected to digital pin 4
    * https://www.arduino.cc/en/Tutorial/Button
    * NOTE: For best results, draw big letters, at least 1-2 feet tall.
    * Copyright (c) 2016 Intel Corporation.  All rights reserved.
    * See license notice at end of file.
    #include "CurieIMU.h"
    #include "CuriePME.h"
    /*  This controls how many times a letter must be drawn during training.
    *  Any higher than 4, and you may not have enough neurons for all 26 letters
    *  of the alphabet. Lower than 4 means less work for you to train a letter,
    *  but the PME may have a harder time classifying that letter. */
    const unsigned int trainingReps = 4;
    /* Increase this to 'A-Z' if you like-- it just takes a lot longer to train */
    const unsigned char trainingStart = 'A';
    const unsigned char trainingEnd = 'F';
    /* The input pin used to signal when a letter is being drawn- you'll
    * need to make sure a button is attached to this pin */
    const unsigned int buttonPin = 4;
    /* Sample rate for accelerometer */
    const unsigned int sampleRateHZ = 200;
    /* No. of bytes that one neuron can hold */
    const unsigned int vectorNumBytes = 128;
    /* Number of processed samples (1 sample == accel x, y, z)
    * that can fit inside a neuron */
    const unsigned int samplesPerVector = (vectorNumBytes / 3);
    /* This value is used to convert ASCII characters A-Z
    * into decimal values 1-26, and back again. */
    const unsigned int upperStart = 0x40;
    const unsigned int sensorBufSize = 2048;
    const int IMULow = -32768;
    const int IMUHigh = 32767;
        while(!Serial);
        pinMode(buttonPin, INPUT);
        /* Start the IMU (Intertial Measurement Unit) */
        CurieIMU.begin();
        /* Start the PME (Pattern Matching Engine) */
        CuriePME.begin();
        CurieIMU.setAccelerometerRate(sampleRateHZ);
        CurieIMU.setAccelerometerRange(2);
        trainLetters();
        Serial.println("Training complete. Now, draw some letters (remember to ");
        Serial.println("hold the button) and see if the PME can classify them.");
    void loop ()
        byte vector[vectorNumBytes];
        unsigned int category;
        char letter;
        /* Record IMU data while button is being held, and
         * convert it to a suitable vector */
        readVectorFromIMU(vector);
        /* Use the PME to classify the vector, i.e. return a category
         * from 1-26, representing a letter from A-Z */
        category = CuriePME.classify(vector, vectorNumBytes);
        if (category == CuriePME.noMatch) {
            Serial.println("Don't recognise that one-- try again.");
        } else {
            letter = category + upperStart;
            Serial.println(letter);
    /* Simple "moving average" filter, removes low noise and other small
    * anomalies, with the effect of smoothing out the data stream. */
    byte getAverageSample(byte samples[], unsigned int num, unsigned int pos,
                       unsigned int step)
        unsigned int ret;
        unsigned int size = step * 2;
        if (pos < (step * 3) || pos > (num * 3) - (step * 3)) {
            ret = samples[pos];
        } else {
            ret = 0;
            pos -= (step * 3);
            for (unsigned int i = 0; i < size; ++i) {
                ret += samples[pos - (3 * i)];
            ret /= size;
        return (byte)ret;
    /* We need to compress the stream of raw accelerometer data into 128 bytes, so
    * it will fit into a neuron, while preserving as much of the original pattern
    * as possible. Assuming there will typically be 1-2 seconds worth of
    * accelerometer data at 200Hz, we will need to throw away over 90% of it to
    * meet that goal!
    * This is done in 2 ways:
    * 1. Each sample consists of 3 signed 16-bit values (one each for X, Y and Z).
    *    Map each 16 bit value to a range of 0-255 and pack it into a byte,
    *    cutting sample size in half.
    * 2. Undersample. If we are sampling at 200Hz and the button is held for 1.2
    *    seconds, then we'll have ~240 samples. Since we know now that each
    *    sample, once compressed, will occupy 3 of our neuron's 128 bytes
    *    (see #1), then we know we can only fit 42 of those 240 samples into a
    *    single neuron (128 / 3 = 42.666). So if we take (for example) every 5th
    *    sample until we have 42, then we should cover most of the sample window
    *    and have some semblance of the original pattern. */
    void undersample(byte samples[], int numSamples, byte vector[])
        unsigned int vi = 0;
        unsigned int si = 0;
        unsigned int step = numSamples / samplesPerVector;
        unsigned int remainder = numSamples - (step * samplesPerVector);
        /* Centre sample window */
        samples += (remainder / 2) * 3;
        for (unsigned int i = 0; i < samplesPerVector; ++i) {
            for (unsigned int j = 0; j < 3; ++j) {
                vector[vi + j] = getAverageSample(samples, numSamples, si + j, step);
            si += (step * 3);
            vi += 3;
    void readVectorFromIMU(byte vector[])
        byte accel[sensorBufSize];
        int raw[3];
        unsigned int samples = 0;
        unsigned int i = 0;
        /* Wait until button is pressed */
        while (digitalRead(buttonPin) == LOW);
        /* While button is being held... */
        while (digitalRead(buttonPin) == HIGH) {
            if (CurieIMU.accelDataReady()) {
                CurieIMU.readAccelerometer(raw[0], raw[1], raw[2]);
                /* Map raw values to 0-255 */
                accel = (byte) map(raw[0], IMULow, IMUHigh, 0, 255);
                accel[i + 1] = (byte) map(raw[1], IMULow, IMUHigh, 0, 255);
                accel[i + 2] = (byte) map(raw[2], IMULow, IMUHigh, 0, 255);
                i += 3;
                ++samples;
                /* If there's not enough room left in the buffers
                * for the next read, then we're done */
                if (i + 3 > sensorBufSize) {
        undersample(accel, samples, vector);
    void trainLetter(char letter, unsigned int repeat)
        unsigned int i = 0;
        while (i < repeat) {
            if (i) Serial.println("And again...");
            CuriePME.learn(vector, vectorNumBytes, letter - upperStart);
            Serial.println("Got it!");
            ++i;
    void trainLetters()
        for (char i = trainingStart; i <= trainingEnd; ++i) {
            Serial.print("Hold down the button and draw the letter '");
            Serial.print(String(i) + "' in the air. Release the button as soon ");
            Serial.println("as you are done.");
            trainLetter(i, trainingReps);
            Serial.println("OK, finished with this letter.");
            delay(2000);
    编译并上传以上程序到Genuino101,按串口提示,即可体验使用Genuino 101学习并识别动作。运行该示例需要在4号引脚上接一个按键模块,按下按键即会开始一次新的学习,松开按键结束该次学习。
    该示例主要使用的了CuriePME中learn和classify两个函数,这也是机器学习的两个主要过程。
    学习
    uint16_t  CuriePME.learn (uint8_t vector[], int32t  vector_length, uint16_t category)
    其中参数vector要进行学习的数据,参数vector_length为数据长度,参数category该次学习对应的分类类别。 调用learn函数,即可告知CuriePME,数据vector属于类别category。
    CuriePME是由128个特殊存储单元组成的神经元网络。每个存储单元可以容纳128字节的数据。每次调用learn函数,都会将输入的新数据写入网络中的一个神经元,即CuriePME在清空重置的状态下,可以进行128次学习操作,每次用于学习的数据vector长度最大为128字节。
    分类
    uint16_t  CuriePME.classify (uint8_t vector[], int32_t  vector_length)
    其中参数vector是要进行识别的数据,vector_length是要该数据的长度。调用classify函数,CuriePME即会判断数据vector属于哪一个别类,并返回别类对应的编号。
    以上程序中,CurieIMU设定加速度采样频率200Hz,采样缓冲区2 kb,最多可以录制3.41秒的动作,再经过程序处理将2kb数据缩小到128 byte,进行学习和分类。如果需要录制更长时间的动作,可以将加速度采样频率降低,或扩大采样缓冲区。
    由于实际用于学习和分类的特征数据只有128 byte,所以理论上越简单的动作,约少的录制时间,会得到更好的学习和识别效果。
    CuriePME主要用来结合CurieIMU进行姿态、动作的学习和识别,但实际上也可以用于其他类型数据的处理,本书篇幅有限,不做过多论述。
    本教程分为五部分:
    1.配置IMU及获取数据   http://www.arduino.cn/thread-42850-1-1.html
    2.解算AHRS姿态   http://www.arduino.cn/thread-42851-1-1.html
    3.姿态数据可视化   http://www.arduino.cn/thread-42852-1-1.html
    4.IMU中断检测   http://www.arduino.cn/thread-42853-1-1.html
    5.神经元与机器学习   http://www.arduino.cn/thread-42854-1-1.html
    Arduino:1.8.1 (Windows 10), 开发板:"Arduino/Genuino 101"
    C:\Users\pc\AppData\Local\Temp\arduino_modified_sketch_204514\sketch_mar17b.ino: In function 'void readVectorFromIMU(byte*)':
    sketch_mar17b:150: error: 'class CurieIMUClass' has no member named 'accelDataReady'
    sketch_mar17b:152: error: incompatible types in assignment of 'byte {aka unsigned char}' to 'byte [2048] {aka unsigned char [2048]}'
    exit status 1
    这是怎么回事?
    新版函数有变更,accelDataReady已作废,新的函数为DataReady  详情 回复 发表于 2017-3-17 15:26
    C:%users\pc\AppData\Local\Temp\arduino_mo ...
    E:\cz-Arduino\sketch_mar17b\sketch_mar17b.ino: In function 'void readVectorFromIMU(byte*)':
    sketch_mar17b:151: error: 'class CurieIMUClass' has no member named 'DataReady'
       if(CurieIMU.DataReady()){
    exit status 1
    还是不好使?????
    使用 1.0  版本的库 CurieIMU 在文件夹: C:\Users\pc\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.7\libraries\CurieIMU
    使用 0.1  版本的库 Intel-Pattern-Matching-Technology-master 在文件夹: E:\cz-Arduino\libraries\Intel-Pattern-Matching-Technology-master
    http://www.arduino.cn/thread-42890-1-1.html  详情 回复 发表于 2017-3-17 16:49
    987621305@QQ.CO 发表于 2017-3-17 15:55
    使用 1.0  版本的库 CurieIMU 在文件夹: C:%users\pc\AppData\Local\Arduino15\packages\Intel\hardware\a ...
    更新版的扩展包才有
    好使了,是CurieIMU.dataReady()。学了
    sp_12951sp 来自手机 新手上路 2017-3-28 16:40
    8#
    大哥们,我全试了,都不行啊,我在文件夹里面搜索curielIMU发现有dataReady但是每次编译都会出现上述错误,好气啊。
    9#
    在cpp文件里面看的
    12下一页
