    2016-1-27 11:13
    libnfc是首个遵循GNU(自由工程项目)通用公共许可证针对所有人都完全免费的低级别NFC软件开发包和编程应用程序接口。它提供了完整的透明度且免费供大家使用。该库目前支持调制ISO / IEC14443 A和B,FeliCa,Jewel/Topaz标签及数据交换协议(P2P)作为目标和启动程序。想了解更多关于libnfc的信息,可参考http://nfc-tools.org/
    ITEAD PN532 NFC模块配有双排引脚,可直接通过排线连接到树莓派,然后树莓派将驱动模块进行非接触式近场通信操作,如读写13.56M IC卡。
    以下教程,演示如何在树莓派上使用libnfc通过SPI总线来驱动ITEAD PN532 模块。
    1, 硬件链接
    Itead PN532 Module是专门为树莓派量身定制的,仅需要排线直接连接就行,如下图
    按照上图的连接方式,Itead PN532 模块是通过SPI总线与树莓派连接的,所以需要把NFC模块的工作模式设置为SPI模式,如下图:
        即 :  SET0-->L   SET1-->H
    2,安装依赖的软件包
        sudo apt-get update
        sudo apt-get install libusb-dev libpcsclite-dev
    3,下载并解压缩libnfc源码包
        cd ~
        tar -xf libnfc-1.7.1.tar.bz2
    4,编译与安装
        cd libnfc-1.7.1
        ./configure --prefix=/usr --sysconfdir=/etc
        make
        sudo make install
    5, 修改配置文件
        cd /etc
        sudo mkdir nfc
        sudo nano /etc/nfc/libnfc.conf
    将如下内容复制到/etc/nfc/libnfc.conf文件中:
        # Allow device auto-detection (default: true)
        # Note: if this auto-detection is disabled, user has to set manually a device
        # configuration using file or environment variable
        allow_autoscan = true
        # Allow intrusive auto-detection (default: false)
        # Warning: intrusive auto-detection can seriously disturb other devices
        # This option is not recommended, user should prefer to add manually his device.
        allow_intrusive_scan = false
        # Set log level (default: error)
        # Valid log levels are (in order of verbosity): 0 (none), 1 (error), 2 (info), 3 (debug)
        # Note: if you compiled with --enable-debug option, the default log level is "debug"
        log_level = 1
        # Manually set default device (no default)
        # To set a default device, you must set both name and connstring for your device
        # Note: if autoscan is enabled, default device will be the first device available in device list.
        device.name = "Itead_PN532_SPI"
        device.connstring = "pn532_spi:/dev/spidev0.0:500000"
    6,树莓派系统默认是将SPI模块的驱动关闭的,我们需要将其打开;
        sudo nano /etc/modprobe.d/raspi-blacklist.conf
    在 “blacklist spi-bcm2708”前添加“#”,变为 “#blacklist spi-bcm2708”,如下图:
    重启后能在/dev下看到两个spi设备:
    7, 至此,准备工作已经做完,我们可以用“nfc-list”命令查看是否安装成功。
    现在,刷个卡试下。。
    测试OK!
    下面再顺便介绍下第二个方法:
    如何采用树莓派I2C总线连接的配置方式:
    1. 软件配置
    树莓派开启I2C总线,将/etc/modprobe.d/raspi-blacklist.conf中“blacklist i2c-bcm2708”变为“#blacklist i2c-bcm2708”
    在/etc/modules末尾添加一行 “i2c-dev”
    将/etc/nfc/libnfc.conf 文件最后一行改为:“pn532_i2c:/dev/i2c-1”
    2. 硬件连接,如下图所示:
    刷卡测试,运行效果如图:
    参考资料附录&相关链接:
    A6. Iteadstudio PN532 Module 网址 http://imall.iteadstudio.com/im130625002.html
    A7. Disable R-Pi/RASPBIAN serial console for using UART0 http://learn.adafruit.com/adafru ... eing-uart-on-the-pi
    教程到此结束,谢谢大家!有问题请留言或微博@ITEAD创易工作室
    赞赞赞………………赞赞赞………………赞赞赞………………
    谢谢楼主的精华帖子 爱唯侦察http://www.e2398.com
    谢谢谢.................谢谢谢.................谢谢谢.................
    分享、学习、进步!
    新鲜出炉,一款开源的可配置的13.56MHz模块:http://www.arduino.cn/thread-5979-1-1.html
    Arduino SPI接线 上传源码后 打开串口监视器 没有数据
