    难过
    2018-1-9 15:05
    我在利用WiFi模块内置处理器搭建一个服务器,支持手机通用浏览器访问,并以此控制室内灯光开关。可是代码写完以后,可以正常连接WIFI,但是串口显示器就像下图一样,后面打着打着没有了,不知道这是为什么,而且用手机也不能连接到设置的服务页面,求问各位大神们这是为什么?
    串口监视器是这样现实的,后面的东西没打完就没有了
    #include <ESP8266WiFi.h>
    #include <ESP8266WebServer.h>
    #include <ESP8266mDNS.h>
    #include <FS.h>
    const char ssid[] = "P10"; //SSID
    const char pass[] = "18810970082"; //Password
    const char* host = "iot";
    ESP8266WebServer server(80);
    //实现了简单的HTTP服务器
    String getContentType(String filename){
      if(server.hasArg("download")) return "application/octet-stream";
      else if(filename.endsWith(".htm")) return "text/html";
      else if(filename.endsWith(".html")) return "text/html";
      else if(filename.endsWith(".css")) return "text/css";
      else if(filename.endsWith(".js")) return "application/javascript";
      else if(filename.endsWith(".png")) return "image/png";
      else if(filename.endsWith(".gif")) return "image/gif";
      else if(filename.endsWith(".jpg")) return "image/jpeg";
      else if(filename.endsWith(".ico")) return "image/x-icon";
      else if(filename.endsWith(".xml")) return "text/xml";
      else if(filename.endsWith(".pdf")) return "application/x-pdf";
      else if(filename.endsWith(".zip")) return "application/x-zip";
      else if(filename.endsWith(".gz")) return "application/x-gzip";
      return "text/plain";
    bool handleFileRead(String path){
      Serial.println("handleFileRead: " + path);
      if(path.endsWith("/")) path += "index.html";
      String contentType = getContentType(path);
      String pathWithGz = path + ".gz";
      if(SPIFFS.exists(pathWithGz) || SPIFFS.exists(path)){
        if(SPIFFS.exists(pathWithGz))
          path += ".gz";
        File file = SPIFFS.open(path, "r");
        size_t sent = server.streamFile(file, contentType);
        file.close();
        return true;
      return false;
    void setup( ){
    SPIFFS.begin();
      WiFi.begin(ssid, pass);
        Serial.print(".");
      Serial.println("");
      Serial.println(ssid);
      Serial.print("Connected to ");
      Serial.print("IP address: ");
      IPAddress ip = WiFi.localIP();
      if (!MDNS.begin(host, ip)) {
        Serial.println("Error setting up MDNS responder!");
        while(1) {
      Serial.println("mDNS responder started");
        Serial.print(".");
      Serial.println("");
      Serial.print("Connected! IP address: ");
      pinMode(1, OUTPUT);
      pinMode(2, OUTPUT);
    server.on ("/gpio02", []() {
         String state = server.arg("state");
         if (state == "SET") {
             digitalWrite(1, HIGH);
         } else if (state == "RESET") {
             digitalWrite(1, LOW);
      server.on ("/gpio16", []() {
             digitalWrite(2, HIGH);
             digitalWrite(2, LOW);
    server.onNotFound([](){
        if(!handleFileRead(server.uri()))
          server.send(404, "text/plain", "404 Not Found.");
      server.begin();
      Serial.println("HTTP server started");
      MDNS.setInstanceName("IOT605 WiFiBoard");
      MDNS.addService("http", "tcp", 80);
    void loop(){
      server.handleClient();
    这是我的源代码
    这个需要购买域名吗?
    哪里卡死了,程序需要优化,最好不要while(1)
    看作者这么辛苦的份上,打赏鼓励一下!
