查看: 2640|回复: 5
[已解决] 报错'D5' was not declared in this scope,如何解决?
发表于 2020-8-23 10:02 | 显示全部楼层 |阅读模式
#define BLINKER_WIFI
char auth[] = "15991537557UF";
char ssid[] = "sxbctvnet-张军";
char pswd[] = "13689216174";
//新建组件对象
BlinkerButton Button1("btn-a");    //前进
BlinkerButton Button2("btn-1");    //左转
BlinkerButton Button3("btn-r");    //右转
BlinkerButton Button4("btn-b");    //后退
BlinkerButton Button5("btn-t");    //停车
BlinkerButton Button6("num-abc");
BlinkerButton Button7("btn-q");
BlinkerButton Button8("btn-h");
BlinkerButton Button9("btn-y");
BlinkerButton Button10("btn-z");
int counter = 0;
#define IN1                D5          //左转引脚
#define IN2                D6           //左转引脚调值
#define IN3                D7           //右转引脚
#define IN4                D8           //右转引脚调值
#define TIME_TAP           100           //延时参数
void blinker_car_init()
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
  digitalWrite(IN1,LOW);
  digitalWrite(IN2,LOW);
  digitalWrite(IN3,LOW);
  digitalWrite(IN4,LOW);
//按下按键会立即执行该函数
  if(state=="tap")
    digitalWrite(IN1,HIGH);
    digitalWrite(IN3,HIGH);
      delay(TIME_TAP);
    digitalWrite(IN1,LOW);    //右轮前进
    digitalWrite(IN3,LOW);    //左轮前进
  if(state=="press")
  if(state=="pressup")
void button2_callback(const String & state)
  if(state=="tap")
      delay(180);
    digitalWrite(IN4,LOW);   //左轮不动
void button3_callback(const String & state)
  if(state=="tap")
      delay(180);
    digitalWrite(IN2,LOW);   //右轮不动
    digitalWrite(IN4,LOW);   //左轮前进
  if(state=="press")
void button4_callback(const String & state)
  if(state=="tap")
    digitalWrite(IN2,HIGH);
    digitalWrite(IN4,HIGH);
      delay(TIME_TAP);
  if(state=="press")
    digitalWrite(IN2,HIGH);  //右轮后退
    digitalWrite(IN4,HIGH);  //左轮后退
    digitalWrite(IN4,LOW);     //右轮不动
    digitalWrite(IN1,LOW);     //左轮前进
void button5_callback(const String & state)
  if(state=="tap")
  if(state=="press")
void button7_callback(const String & state)
  if(state=="tap")
void button8_callback(const String & state)
  if(state=="tap")
void button9_callback(const String & state)
  if(state=="tap")
    analogWrite(IN1,1023);
    analogWrite(IN3,500);
  if(state=="press")
void button10_callback(const String & state)
  if(state=="tap")
    analogWrite(IN3,1023);
    analogWrite(IN1,500);
  if(state=="press")
//如果未绑定的组件被触发,则会执行其中内容
  Number6.print(counter);
void setup(){
  BLINKER_DEBUG.stream(Serial);
  //初始化有LED的IO
  blinker _car_init();
  pinMode(LED_BULLTIN,OUTPUT);
  //初始化blinker
  Blinker.attachData(dataRead);
  Button2.attach(button1_callback);
  Button3.attach(button1_callback);
  Button4.attach(button1_callback);
  Button5.attach(button1_callback);
  Button6.attach(button1_callback);
  Button7.attach(button1_callback);
  Button8.attach(button1_callback);
  Button9.attach(button1_callback);
  Button10.attach(button1_callback);
发表于 2020-8-23 10:56 | 显示全部楼层
写GPIO对应的数字编号,不要加“D”
 楼主| 发表于 2020-9-15 18:49 | 显示全部楼层
奈何col 发表于 2020-8-23 10:56
写GPIO对应的数字编号,不要加“D”
用的是esp8266,他对应的·gpio口就是D0-D8
D开头的不是GPIO编号,找到实际的GPIO编号,然后直接写就行了  详情 回复 发表于 2020-9-15 19:38
发表于 2020-9-15 19:38 | 显示全部楼层
发表于 2020-9-15 19:49 | 显示全部楼层
开发板型号不对?
试试选WeMos D1
发表于 2022-5-23 12:59 | 显示全部楼层
我也碰到这个问题了,楼主怎么解决的啊
程序继电器问题
程序继电器问题
?????????? 我这里又双叒叕变天了。。。 (大无语好吧) 写了一个程序,一
合宙ESP32C3使用TFT_eSPI
DHT11数字温湿度传感器Arduino
DHT11数字温湿度传感器Ard
/*-------------------按说明书_写代码_不需要库-----------------*/ #define DHT11
【梦云之家】ESP8266-WS模板服务器(开源项目)
【梦云之家】ESP8266-WS模
该项目是能够让ESP8266脱离服务器,不需要强化绑定某云服务器。 下面开看看展示的效果
【Arduino】168种传感器模块系列实验(218)--- 1.3寸 TFT显示屏
