TA的每日心情 | 奋斗 2020-11-27 01:24 |
签到天数: 1 天 [LV.1]初来乍到
楼主 |
发表于 2020-11-27 01:26
显示全部楼层
请教一下如果用下面的代码应该怎么改
char buf[100] = {0}; // this is an array
char inChar;
bool stringComplete = false;
int i = 0;
// declare the function
char ConvertString(char);
// Initialize serial and wait for port to open
while (!Serial)
// Wait for serial port to connect, needed for native USB port only
while (Serial.available())
inChar = (char)Serial.read();
if (inChar == '\n') // change '\n' to '~' when using Tinkercad
buf[i++] = inChar; // last character is newline
buf[i] = 0; // string array should be terminated with a zero
stringComplete = true;
buf[i++] = inChar;
if (stringComplete)
Serial.print(buf); // the printing of string will be stopped when zero is reached
i = 0;
