TA的每日心情 | 开心 2021-1-11 09:13 |
签到天数: 2 天 [LV.1]初来乍到
小白一个,这个没看明白怎么接线,能占用大神两分钟指点一下吗?
https://diandeng.tech/doc/yuan-cheng-huan-jing-jian-ce-yi
/* * Blinker AQI Detector */#define BLINKER_PRINT Serial#define BLINKER_WIFI#include <Blinker.h>char auth[] = "Your Device Secret Key";char ssid[] = "Your WiFi network SSID or name";char pswd[] = "Your WiFi network WPA password or WEP key";// U8g2lib, https://github.com/olikraus/U8g2_Arduino#include <U8g2lib.h>#ifdef U8X8_HAVE_HW_I2C#include <Wire.h>#endifU8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /*reset Pin*/ 13);// BLINKER_PMSX003ST, https://github.com/i3water/Blinker_PMSX003ST#include <BLINKER_PMSX003ST.h>#if defined(ESP32)HardwareSerial pmsSerial(2);// Pins 16(RX),17(TX)#else#include <SoftwareSerial.h>SoftwareSerial pmsSerial(14, 15);#endifBLINKER_PMSX003ST pms;uint32_t os_time_ms;#define PM_1 "PM1.0"#define PM_2_5 "PM2.5"#define PM_10 "PM10"#define PMS_FA "FA"#define PMS_RH "RH"#define PMS_TP "TP"BlinkerNumber PM1(PM_1);BlinkerNumber PM25(PM_2_5);BlinkerNumber PM10(PM_10);BlinkerNumber HCHO(PMS_FA);BlinkerNumber HUMI(PMS_RH);BlinkerNumber TEMP(PMS_TP);void drawAQI(){ u8g2.setFont(u8g2_font_helvR10_te); u8g2.setCursor(0, 13); u8g2.print("PM1.0:" + String(pms.getPmAto(1.0))); u8g2.setCursor(0, 27); u8g2.print("PM2.5:" + String(pms.getPmAto(2.5))); u8g2.setCursor(0, 41); u8g2.print("PM10:" + String(pms.getPmAto(10))); u8g2.setCursor(75, 13); u8g2.print("FA:" + String(pms.getForm())); u8g2.setCursor(75, 27); u8g2.print("RH:" + String((int)pms.getHumi()) + "%"); u8g2.setCursor(75, 41); u8g2.print("TP:" + String((int)pms.getTemp()) + "°"); u8g2.drawLine(0, 46, 128, 46); u8g2.setFont(u8g2_font_helvR10_te); u8g2.setCursor(0, 63); u8g2.print("Blinker AQI detector");}void getPMS(){ if (millis() - os_time_ms > 1000UL) {#ifndef ESP32 if (!pmsSerial.isListening()) { pmsSerial.listen(); delay(100); }#endif pms.request(); if(!pms.read()){ return; } os_time_ms = millis(); }}void detectorDisplay(){ getPMS(); u8g2.firstPage(); do { drawAQI(); } while ( u8g2.nextPage() );}void u8g2Init(){ u8g2.begin(); u8g2.setFlipMode(0); u8g2.clearBuffer(); u8g2.enableUTF8Print();}void pmsInit(){ pmsSerial.begin(9600); pms.begin(pmsSerial); pms.setMode(PASSIVE);}void heartbeat(){ PM1.unit("ug/m3"); PM1.print(pms.getPmAto(1.0)); PM25.unit("ug/m3"); PM25.print(pms.getPmAto(2.5)); PM10.unit("ug/m3"); PM10.print(pms.getPmAto(10)); HCHO.unit("ug/m3"); HCHO.print(pms.getForm()); HUMI.unit("%"); HUMI.print(pms.getHumi()); TEMP.unit("°C"); TEMP.print(pms.getTemp());}void setup(){ Serial.begin(115200); #if defined(BLINKER_PRINT) BLINKER_DEBUG.stream(BLINKER_PRINT); #endif u8g2Init(); pmsInit(); Blinker.begin(auth, ssid, pswd); Blinker.attachHeartbeat(heartbeat);}void loop(){ Blinker.run(); detectorDisplay(); Blinker.delay(1000);}
