楼主 |
发表于 2021-1-22 17:10
显示全部楼层
比如这个最简单的点灯程序
- int led = 8;
- void setup() {
- // initialize digital pin led as an output.
- pinMode(led, OUTPUT);
- // the loop function runs over and over again forever
- void loop() {
- ked_k();
- void ked_k()
- digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
- delay(1000); // wait for a second
- digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
我要把这个 void ked_k() 单独拿出来,我在 .cpp .h 文件里应该怎么写 |
