涂鸦arduino中文社区活动
查看: 659|回复: 10
[已解答] 求助esp8266使用小爱同学 、天猫精灵无法控制,附带源码
发表于 2021-2-2 21:36 | 显示全部楼层 |阅读模式
#define BLINKER_WIFI
#define BLINKER_ESP_SMARTCONFIG
#define BLINKER_ALIGENIE_MULTI_OUTLET
#define BLINKER_MIOT_MULTI_OUTLET
#define LED 5
#define LED2 4
char auth[] = "5ee963455d27";  //设备密匙
char ssid[] = "H3C_fl";
char pswd[] = "fxb12251314";
// 新建组件对象
BlinkerButton Button1("btn-1");    // APP组件名称
BlinkerButton Button2("btn-2");    // APP组件名称
BlinkerButton Button3("btn-3");    // APP组件名称
BlinkerNumber Number1("num-xxx");  // blinker新建组件
bool switch_onoff = 0;             //开关标志位
bool switch_onoff_2 = 0;
bool switch_onoff_3 = 0;
bool oState[5] = { false };
//开灯函数1
void ON() {
  digitalWrite(LED, HIGH);
  Button1.color("#B22222");
  Button1.text("点我关灯");
  Button1.print();
  switch_onoff = 1;
//关灯函数1
void OFF() {
  digitalWrite(LED, LOW);
  Button1.color("#000000");
  Button1.text("点我开灯");
  Button1.print();
  switch_onoff = 0;
//开灯函数2
void ON2() {
  digitalWrite(LED2, HIGH);
  Button2.color("#B22222");
  Button2.text("点我关灯");
  Button2.print();
  switch_onoff_2 = 1;
//关灯函数2
void OFF2() {
  digitalWrite(LED2, LOW);
  Button2.color("#000000");
  Button2.text("点我开灯");
  Button2.print();
  switch_onoff_2 = 0;
void heartbeat()  //心跳包
  Number1.print(WiFi.RSSI());  //信号强度
  if (switch_onoff == 1) {
    Button1.print();
    BUILTIN_SWITCH.print("on");
  } else {
    Button1.print();
    BUILTIN_SWITCH.print("off");
  if (switch_onoff_2 == 1) {
    Button2.print();
  } else {
    Button2.print();
// 按下APP按键即会执行该函数
void button1_callback(const String &state) {
  switch_onoff = !switch_onoff;
  if (switch_onoff) {
    ON();
  } else {
    OFF();
// 按下APP按键即会执行该函数2
void button2_callback(const String &state) {
  switch_onoff_2 = !switch_onoff_2;
  if (switch_onoff_2) {
    ON2();
  } else {
    OFF2();
  BLINKER_LOG("get button state2: ", state);
// 按下APP按键即会执行该函数3
void button3_callback(const String &state) {
  switch_onoff_3 = !switch_onoff_3;
  if (switch_onoff_3) {
    ON();
    ON2();
  } else {
    OFF();
    OFF2();
////////阿里精灵
void aligeniePowerState(const String & state, uint8_t num)
  BLINKER_LOG("need set outlet: ", num, ", power state: ", state);
    if (num == 1) {
      switch_onoff = 1;
      ON();
      BlinkerAliGenie.powerState("on", 1);
      BlinkerAliGenie.print();
    else if (num == 2) {
      switch_onoff_2 = 1;
      ON2();
      BlinkerAliGenie.powerState("on", 2);
    else if (num == 0) {
      switch_onoff = 1;
      switch_onoff_2 = 1;
      switch_onoff_3 = 1;
      ON();
      ON2();
      BlinkerAliGenie.powerState("on", 0);
    if (num == 1) {
      switch_onoff = 0;
      OFF();
      BlinkerAliGenie.powerState("off", 1);
      switch_onoff_2 = 0;
      OFF2();
      BlinkerAliGenie.powerState("off", 2);
      switch_onoff = 0;
      switch_onoff_2 = 0;
      switch_onoff_3 = 0;
      OFF();
      OFF2();
      BlinkerAliGenie.powerState("off", 0);
void miotPowerState(const String & state, uint8_t num)
    if (num == 1) {
      switch_onoff = 1;
      ON();
      BlinkerMIOT.powerState("on", 1);
      BlinkerMIOT.print();
      switch_onoff_2 = 1;
      ON2();
      BlinkerMIOT.powerState("on", 2);
      switch_onoff = 1;
      switch_onoff_2 = 1;
      switch_onoff_3 = 1;
      ON();
      ON2();
      BlinkerMIOT.powerState("on", 0);
    if (num == 1) {
      switch_onoff = 0;
      OFF();
      BlinkerMIOT.powerState("off", 1);
      switch_onoff_2 = 0;
      OFF2();
      BlinkerMIOT.powerState("off", 2);
      switch_onoff = 0;
      switch_onoff_2 = 0;
      switch_onoff_3 = 0;
      OFF();
      OFF2();
      BlinkerMIOT.powerState("off", 0);
void miotQuery(int32_t queryCode, uint8_t num)
    BLINKER_LOG("AliGenie Query outlet: ", num,", codes: ", queryCode);
    switch (queryCode)
            BlinkerMIOT.powerState(oState[num] ? "on" : "off", num);
        default :
void switch_callback(const String &state) {
  BLINKER_LOG("get switch state: ", state);
    ON();
    ON2();
  } else {
    OFF();
    OFF2();
  // 初始化串口
  BLINKER_DEBUG.stream(Serial);
  // BLINKER_DEBUG.debugAll();
  // 初始化IO
  pinMode(12, INPUT);
  pinMode(LED, OUTPUT);
  pinMode(LED2, OUTPUT);
  // 初始化blinker
  BlinkerAliGenie.attachPowerState(aligeniePowerState);  //天猫精灵开关
  BUILTIN_SWITCH.attach(switch_callback);
发表于 2021-2-2 22:56 | 显示全部楼层
确保lib和package为最新,并测试例程,如果还是不行,请看调试信息是否有报错
 楼主| 发表于 2021-2-2 23:47 | 显示全部楼层
奈何col 发表于 2021-2-2 22:56
确保lib和package为最新,并测试例程,如果还是不行,请看调试信息是否有报错 ...
QQ截图20210202234613.png 这里呼叫天猫和小爱没有任何反应
 楼主| 发表于 2021-2-2 23:48 | 显示全部楼层
https://github.com/blinker-iot/blinker-library/blob/master/examples/Blinker_AliGenie/AliGenie_MULTI_OUTLET/AliGenie_MULTI_OUTLET.ino   用这个直接写入测试也没有反应
您确定您写入了,用的例程?正常情况,串口也应该有输出  详情 回复 发表于 2021-2-3 00:11
发表于 2021-2-3 00:11 | 显示全部楼层
1278945 发表于 2021-2-2 23:48
https://github.com/blinker-iot/blinker-library/blob/master/examples/Blinker_AliGenie/AliGenie_MULTI_ ...
 楼主| 发表于 2021-2-3 00:24 | 显示全部楼层
确定写入了, app操作可以 。
语音控制不能用我找不出什么原因
发表于 2021-2-3 10:24 | 显示全部楼层
1278945 发表于 2021-2-3 00:24
确定写入了, app操作可以 。
语音控制不能用我找不出什么原因
我在blinker的官网发现只有阿里云的设备key才可以使用语音控制,我之前问题和你一样,换了一下设备就可以了
发表于 2021-2-3 10:26 | 显示全部楼层
可能是服务器的问题。语音控制不支持电灯科技的key但是支持阿里云的key
目前语音助手接入,只有阿里broker支持,这个文档有写明  详情 回复 发表于 2021-2-3 10:36
发表于 2021-2-3 10:36 | 显示全部楼层
目前语音助手接入,只有阿里broker支持,这个文档有写明,请阅读文档https://diandeng.tech/doc/voice-assistant
 楼主| 发表于 2021-2-3 14:10 | 显示全部楼层
3137234383 发表于 2021-2-3 10:24
我在blinker的官网发现只有阿里云的设备key才可以使用语音控制,我之前问题和你一样,换了一下设备就可以 ...
是阿里云
arduinoT12焊台 控制器 炫酷UI
arduinoT12焊台 控制器 炫
Arduino引脚图
Arduino引脚图
Arduino物联网开发实例教程
Arduino物联网开发实例教
