查看: 2043|回复: 6
[未解决] 毕设求助!max30102与gy906实现脉搏体温测量
发表于 2021-3-22 17:05 | 显示全部楼层 |阅读模式
各位大佬,我最近在搞毕业设计,想通过arduino,max30102,gy906实现脉搏体温测量,但效果并不好,无法读取数据(但两个传感器单独使用时能正常读取显示数据)
求教各位大佬如何解决!!!!谢谢!!!!
以下是代码:
gy906单独使用时代码:
//温度
#include <Wire.h>   //IIC头文件
  Wire.begin();         // join i2c bus (address optional for master)
  Serial.begin(9600);  // 波特率
uint16_t result;
float temp;
  Wire.beginTransmission(0x5A);
  Wire.write(0x07);                // sends instruction byte
  Wire.endTransmission(false);     // stop transmitting
  Wire.requestFrom(0x5A, 3);   //Send data n-bytes read
  result = Wire.read();        //Receive DATA
  result |= Wire.read() << 8;  //Receive DATA
  uint8_t pec = Wire.read();
  temp =  result*0.02-273.15;  //温度数值转换
  Serial.print(F("temp="));
  Serial.println(temp);
max30102单独使用测量脉搏时代码:
  Optical Heart Rate Detection (PBA Algorithm) using the MAX30105 Breakout
  By: Bennu @ MH-ET LIVE
  Date: October 2nd, 2017
  https://github.com/MHEtLive/MH-ET-LIVE-max30102
  This is a demo to show the reading of heart rate or beats per minute (BPM) using
  a Penpheral Beat Amplitude (PBA) algorithm.
  It is best to attach the sensor to your finger using a rubber band or other tightening
  device. Humans are generally bad at applying constant pressure to a thing. When you
  press your finger against the sensor it varies enough to cause the blood in your
  finger to flow differently which causes the sensor readings to go wonky.
  Hardware Connections (Breakoutboard to Arduino):
  -5V = 5V (3.3V is allowed)
  -GND = GND
  -SDA = A4 (or SDA)
  -SCL = A5 (or SCL)
  -INT = Not connected
  The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V
  but it will also run at 3.3V.
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
  Serial.println("Initializing...");
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println("MAX30105 was not found. Please check wiring/power. ");
    while (1);
  Serial.println("Place your index finger on the sensor with steady pressure.");
  particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
  long irValue = particleSensor.getIR();
  if (checkForBeat(irValue) == true)
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20)
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  Serial.print("IR=");
  Serial.print(irValue);
  Serial.print(", BPM=");
  Serial.print(beatsPerMinute);
  Serial.print(", Avg BPM=");
  Serial.print(beatAvg);
  if (irValue < 50000)
    Serial.print(" No finger?");
  Serial.println();
gy906与max30102一起使用代码:
shili5+gy906
#include <Wire.h>
byte rateSpot = 0;
int beatAvg;
  //Serial.begin(9600);  // 波特率
    while (1);
uint16_t result;
float temp;
    //We sensed a beat!
      beatAvg = 0;
// Serial.print(F("temp="));
  Serial.println();
gy906单独使用效果
gy906单独使用效果
max30102单独使用效果
max30102单独使用效果
两传感器同时使用效果
两传感器同时使用效果
签到天数: 72 天
发表于 2021-3-22 18:46 | 显示全部楼层
这个问题遇到过,解决方案是使用其他引脚实现SMBUS协议,库文件可以有偿提供
附带一份
按下按钮,读取10次心率和体温,并求平均值,LCD显示,超过阈值蜂鸣器 LED红灯报警,正常LED绿灯的程序
发表于 2022-1-21 10:45 来自手机 | 显示全部楼层
附带一份
按下按钮,读取10次 ...
可以问一下是怎么解决的吗
签到天数: 72 天
发表于 2022-1-23 01:03 | 显示全部楼层
Alexjet 发表于 2022-1-21 10:45
可以问一下是怎么解决的吗
发表于 2022-1-23 23:34 来自手机 | 显示全部楼层
可以有偿提供库文件或教程吗
签到天数: 72 天
发表于 2022-1-24 02:10 | 显示全部楼层
Alexjet 发表于 2022-1-23 23:34
可以有偿提供库文件或教程吗
左侧QQ交谈
发表于 2022-3-31 21:20 | 显示全部楼层
兄弟,求库以及解决方法,可以有偿,急
Arduino IDE  ESP32 下不能使用中文关键字使我非常郁闷。
Arduino IDE ESP8266 下可以使用中文关键字 Arduino IDE ESP32 下不能使用中文关键
AVR32开发板
AVR32开发板
at32UC3B1128开发板支持很多硬件资源,感兴趣可以在评论区交流
合宙ESP32C3使用TFT_eSPI
blinker物联网教程——4、控制开关灯
blinker物联网教程——4、
简介[hr]在基础教程中,我们用wifiduino做了一系列的控制实验,并了解了传感器和主板
合宙ESP32C3使用TFT_eSPI
TFT_eSPI库里面含有自备字库的制作工具,数字、英文大小写和中文字体采用Unicode编码
