查看: 344|回复: 2
[已解答] Blinker的示例Ticker_BLE编译出错
发表于 2021-4-6 22:08 | 显示全部楼层 |阅读模式
我用的Arduino1.8.13+blinker0.3.6,在编译示例时出现错误:
  1. In file included from G:\arduino\portable\sketchbook\libraries\Blinker\src/Blinker.h:21:0,
  2.                  from G:\arduino\portable\sketchbook\libraries\Blinker\examples\Blinker_Ticker\Ticker_BLE\Ticker_BLE.ino:48:
  3. G:\arduino\portable\sketchbook\libraries\Blinker\src/BlinkerSerialBLE.h: In member function 'void BlinkerSerialBLE::begin(uint8_t, uint8_t, uint32_t)':
  4. G:\arduino\portable\sketchbook\libraries\Blinker\src/BlinkerSerialBLE.h:93:30: error: 'RX' was not declared in this scope
  5.              if (ss_rx_pin == RX && ss_tx_pin == TX) {
  6.                               ^
  7. G:\arduino\portable\sketchbook\libraries\Blinker\src/BlinkerSerialBLE.h:93:49: error: 'TX' was not declared in this scope
  8.              if (ss_rx_pin == RX && ss_tx_pin == TX) {
  9.                                                  ^
  10. G:\arduino\portable\sketchbook\libraries\Blinker\examples\Blinker_Ticker\Ticker_BLE\Ticker_BLE.ino: At global scope:
  11. Ticker_BLE:53:1: error: 'BlinkerTicker' does not name a type
  12. BlinkerTicker ticker;
  13. ^
  14. G:\arduino\portable\sketchbook\libraries\Blinker\examples\Blinker_Ticker\Ticker_BLE\Ticker_BLE.ino: In function 'void setup()':
  15. Ticker_BLE:88:5: error: 'ticker' was not declared in this scope
  16.      ticker.attach(30, ticker_callback);
  17.      ^
  18. G:\arduino\portable\sketchbook\libraries\Blinker\examples\Blinker_Ticker\Ticker_BLE\Ticker_BLE.ino: In function 'void loop()':
  19. Ticker_BLE:95:5: error: 'ticker' was not declared in this scope
  20.      ticker.run();
  21.      ^
  22. exit status 1
  23. 'BlinkerTicker' does not name a type
签到天数: 1 天
发表于 2021-4-7 19:11 | 显示全部楼层
这个示例是给avr用的,你没有选择对应的硬件所以编译报错
 楼主| 发表于 2021-4-9 22:30 | 显示全部楼层
谢谢,明白了,8266得用ticker库
arduino程序设计基础 blinker物联网解决方案
基于麦克纳姆轮的PID实例学习--机甲大师PID控制
基于麦克纳姆轮的PID实例
有没有人遇到过"MQTT Ping
HC05发送数据出错
HC05发送数据出错
HC05往手机发送数据会产生错乱和缺失?
arduinoT12焊台 控制器 炫酷UI
arduinoT12焊台 控制器 炫
