查看: 580|回复: 17
[未解决] 求助大神,想把下面的代码移植到ST7565或者ST7796S上。
发表于 2021-4-10 14:01 | 显示全部楼层 |阅读模式
先不搞了
签到天数: 82 天
发表于 2021-4-10 17:12 | 显示全部楼层
签到天数: 82 天
发表于 2021-4-10 17:13 | 显示全部楼层
 楼主| 发表于 2021-4-10 17:39 | 显示全部楼层
topdog 发表于 2021-4-10 17:13
http://www.lcdwiki.com/zh/4.0inch_SPI_Module_ST7796
谢谢回复 就是不会代码,那些例程都有。
签到天数: 82 天
发表于 2021-4-13 00:44 | 显示全部楼层
我只有一块TFT 尺寸是 240x320  驱动芯片 ILI9341 。根据你的需求做了一个坐标实时显示。
#include <Elegoo_GFX.h>    // https://github.com/Erutan409/Elegoo_GFX
#include <Elegoo_TFTLCD.h> // https://github.com/Erutan409/Elegoo_TFTLCD
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#define LIGHT_GREY      0xBDF7
#define DARK_GREY       0x7BEF
#define ORANGE          0xFBE0
#define BROWN           0x79E0
#define PINK            0xF81F
Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// 全局变量
int valueBlock[200];
int timeBlock[200];
int locationBlock[200];
int valuePos;
int blockPos;
int temp;
int chk;
// 可编辑的变量
bool proDebug = 0;
uint16_t graphColor = BLUE;
uint16_t pointColor = BLACK;
uint16_t lineColor = GREEN;
String graphName = "Time Graph";
int graphRange = 50;
int markSize = 3;
// 计算拘束
const int numberOfMarks = 8;
const int originX = 45;
const int originY = 200;
const int sizeX = 270;
const int sizeY = 150;
const int deviation = 30;
int boxSize = (sizeX / numberOfMarks);
int mark[] = {(boxSize + deviation), ((boxSize * 2) + deviation), ((boxSize * 3) + deviation), ((boxSize * 4) + deviation), ((boxSize * 5) + deviation), ((boxSize * 6) + deviation), ((boxSize * 7) + deviation), ((boxSize * 8) + deviation)};
const int minorSizeY = (originY + 10);
const int minorSizeX = (originX - 10);
int numberSize = (sizeY / 6);
int number[] = {numberSize, (numberSize * 2), (numberSize * 3), (numberSize * 4), (numberSize * 5), (numberSize * 6)};
int numberValue = (graphRange / 6);
int val[] = {graphRange, (numberValue * 5), (numberValue * 4), (numberValue * 3), (numberValue * 2), numberValue};
void drawHome()
  tft.fillScreen(BLACK);
  tft.setCursor(10, 10);
  tft.setTextColor(BLUE);
  tft.setTextSize(5);
  tft.println("Arduino CN");
  tft.setCursor(10, 80);
  tft.setTextColor(CYAN);
  tft.setTextSize(3);
  tft.println("Graphing");
  tft.setCursor(30, 110);
  tft.setTextSize(2);
  tft.println("History Graphs");
  tft.setCursor(10, 160);
  tft.setTextColor(WHITE);
  tft.setTextSize(2);
  tft.println("ILI9341 LCD 240x320");
  delay(4000);
  tft.fillScreen(WHITE);
void drawGraph()
  // 绘制标题
  tft.setCursor(10, 10); // 设置游标
  tft.setTextColor(BLUE); // 设置文本的颜色
  tft.setTextSize(4); // 设置文本的大小
  tft.println(graphName);
  // 绘制轮廓
  tft.drawLine(originX, originY, (originX + sizeX), originY, graphColor);
  tft.drawLine(originX, originY, originX, (originY - sizeY), graphColor);
  // 绘制标记
  for (int i = 0; i < numberOfMarks; i++)
    tft.drawLine(mark[i], originY, mark[i], minorSizeY, graphColor);
  // 绘制数字
  for (int i = 0; i < 6; i++)
    tft.drawLine(originX, (originY - number[i]), minorSizeX, (originY - number[i]), graphColor);
  // 绘制数字的取值
    tft.setCursor((minorSizeX - 30), (number[i] + numberSize));
    tft.setTextColor(graphColor);
    tft.setTextSize(1);
    tft.println(val[i]);
void graph()
  timeBlock[valuePos] = ((millis() - 4500) / 1000);
  temp += 1 ;
  valueBlock[valuePos] = temp;
  if (proDebug)
    Serial.println(timeBlock[valuePos]);
  if (blockPos < 8)
    // 打印的时间
    tft.setCursor((mark[valuePos] - 5), (originY + 16));
    tft.setTextColor(graphColor, WHITE);
    tft.setTextSize(1);
    tft.println(timeBlock[valuePos]);
    // 映射的值
    locationBlock[valuePos] = map(temp, 0, graphRange, originY, (originY - sizeY));
    // 画标点
    tft.fillRect((mark[valuePos] - 1), (locationBlock[valuePos] - 1), markSize, markSize, pointColor);
    // 尝试连接到前面的点
    if (valuePos != 0)
      tft.drawLine(mark[valuePos], locationBlock[valuePos], mark[(valuePos - 1)], locationBlock[(valuePos - 1)], lineColor);
    blockPos++;
    // 清除图形的画布
    tft.fillRect((originX + 2), (originY - sizeY), sizeX, sizeY, WHITE);
    // 映射值-当前点
    //绘制点-当前点
    tft.fillRect((mark[7]), (locationBlock[valuePos] - 1), markSize, markSize, pointColor);
    // 画出所有点
    for (int i = 0; i < 8; i++)
      tft.fillRect((mark[(blockPos - (i + 1))] - 1), (locationBlock[(valuePos - i)] - 1), markSize, markSize, pointColor);
    // 画出所有的线
    for (int i = 0; i < 7; i++)
      tft.drawLine(mark[blockPos - (i + 1)], locationBlock[valuePos - i], mark[blockPos - (i + 2)], locationBlock[valuePos - (i + 1)], lineColor);
    // 改变时间标记
    for (int i = 0; i <= 7; i++)
      tft.setCursor((mark[(7 - i)] - 5), (originY + 16));
      tft.setTextSize(1);
      tft.println(timeBlock[valuePos - i]);
  valuePos++;
  if (proDebug)
    while (!Serial) {};
  tft.reset();
  uint16_t identifier = tft.readID();
  identifier = 0x9341;
  tft.begin(identifier);
  tft.setRotation(1);
  drawHome();
  drawGraph();
  graph();
  delay(6000);
 楼主| 发表于 2021-4-14 21:38 | 显示全部楼层
#include     // ...
感谢感谢 我模仿一下。
 楼主| 发表于 2021-4-14 23:23 | 显示全部楼层
#include     // ...
大神 我这个是SPI出口屏 刷你这个程序不亮,刚才看ILI9431是并口屏。
签到天数: 82 天
发表于 2021-4-14 23:54 | 显示全部楼层
我的屏管脚分布如图。
 楼主| 发表于 2021-4-15 00:14 | 显示全部楼层
可能是库不支持ST7796S
签到天数: 82 天
发表于 2021-4-15 21:36 | 显示全部楼层
hjq9999 发表于 2021-4-15 00:14
可能是库不支持ST7796S
我没有ST7796S呀。
arduino程序设计基础 blinker物联网解决方案
关于红外的求助
关于红外的求助
[Arduino物联网开发实战5]云端历史数据存储与查看
[Arduino物联网开发实战5]
程序卡着不动,最后打印Freeheap 25427
程序卡着不动,最后打印Fr
各位有见过这个错误吗,程序跑到这里卡着不动
通过定时器读取串口数据出错
通过定时器读取串口数据出
