查看: 251|回复: 6
[已解答] 远程开机,编译时出错,求大神看看
发表于 2021-6-5 15:09 | 显示全部楼层 |阅读模式
错误
错误
Arduino:1.8.9 (Windows 10), 开发板:"Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
D:\程序\_______\_______.ino: In function 'void miotPowerState(const String&)':
_______:21:12: error: 'D2' was not declared in this scope
D:\程序\_______\_______.ino:30:18: note: in expansion of macro 'PW'
_______:35:5: error: 'BlinkerAliGenie' was not declared in this scope
D:\程序\_______\_______.ino:41:18: note: in expansion of macro 'PW'
_______:46:5: error: 'BlinkerAliGenie' was not declared in this scope
D:\程序\_______\_______.ino: In function 'void miotQuery(int32_t)':
_______:22:12: error: 'D5' was not declared in this scope
D:\程序\_______\_______.ino:58:19: note: in expansion of macro 'PM'
_______:59:5: error: 'BlinkerAliGenie' was not declared in this scope
_______:63:5: error: 'BlinkerAliGenie' was not declared in this scope
_______:66:3: error: 'BlinkerAliGenie' was not declared in this scope
D:\程序\_______\_______.ino: In function 'void button1_callback(const String&)':
D:\程序\_______\_______.ino:85:16: note: in expansion of macro 'PW'
D:\程序\_______\_______.ino: In function 'void heartbeat()':
D:\程序\_______\_______.ino:91:19: note: in expansion of macro 'PM'
D:\程序\_______\_______.ino: In function 'void setup()':
D:\程序\_______\_______.ino:104:11: note: in expansion of macro 'PM'
D:\程序\_______\_______.ino:110:11: note: in expansion of macro 'PW'
D:\程序\_______\_______.ino: In function 'void loop()':
D:\程序\_______\_______.ino:126:23: note: in expansion of macro 'PM'
exit status 1
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
大神们怎么解决啊,在线等
#define BLINKER_PRINT Serial
#define BLINKER_WIFI
#define BLINKER_MIOT_OUTLET   //小爱同学
char auth[] = "ea47b142001c";
char ssid[] = "TP-LINK_776E";
char pswd[] = "123456789";
BlinkerButton Button1("btn-abc");     //定义按钮数据键值
BlinkerText Text1("TextKey");        //文件显示键值
bool oState = false;
bool power;
bool lastpower;
int counter = 0;
String pState;  //存储检测到的电源状态
#define PW D2    //继电器控制管脚
#define PM D5    //电源检测管脚
    digitalWrite(PW, HIGH);
    delay(200);
    digitalWrite(PW, LOW);
    Serial.println("开了");
    BlinkerAliGenie.print();
    oState = true;
    delay(200);
    Serial.println("关了");
    oState = false;
  if (digitalRead(PM) == true) {
  else {
void dataRead(const String & data)      // 如果未绑定的组件被触发,则会执行其中内容
  Blinker.vibrate();
  delay(200);
void heartbeat() {
    pState = "开机";
  else {
    pState = "关机";
  Text1.print(pState, "电源状态反馈");
  Serial.println("心跳反馈");
  pinMode(PM, INPUT);
#if defined(BLINKER_PRINT)
#endif
  pinMode(PW, OUTPUT);              //定义io口为输出
  digitalWrite(PW, LOW);           //定义io默认为高电平
  Blinker.attachData(dataRead);
  power = digitalRead(PM);
  if (power != lastpower) {
      pState = "开机";
    else {
      pState = "关机";
    Serial.println("反馈");
  lastpower = power;
签到天数: 86 天
发表于 2021-6-5 18:09 | 显示全部楼层
检查一下  ESP8266 引脚编号  显示 D2 D3 有问题
签到天数: 4 天
发表于 2021-6-5 21:14 | 显示全部楼层
开发版选择 NodeMCU1.0  ESP12E
签到天数: 1 天
发表于 2021-6-6 00:28 | 显示全部楼层
IDE中选择您实际使用的开发板,或者将D2改成实际使用的GPIO编号
签到天数: 116 天
发表于 2021-6-6 00:34 | 显示全部楼层
#define PW 2    //继电器控制管脚
#define PM 5    //电源检测管脚
签到天数: 1 天
发表于 2021-6-8 11:47 | 显示全部楼层
感觉像是说D2定义有问题吧。该成数字引脚编号或者   char xxx = 'D2';   应该可以解决
【Arduino】108种传感器模块系列实验(52)---Micro SD卡读写模块
【Arduino】108种传感器模
DIY炫彩灯带,竟如此简单,更有硬件开发工具免费领!
DIY炫彩灯带,竟如此简单
步进电机播放音乐
步进电机播放音乐
esp32控制ws2812灯条会有闪烁
esp32控制ws2812灯条会有
把亮度调为0后第一个灯会一直亮其余一些会闪烁,把亮度调高以后就不会闪烁。之前用esp
想在原有的项目上加上一个呼吸灯怎么做才不影响原程序
想在原有的项目上加上一个
