查看: 365|回复: 3
[已解答] nodemcu重新刷入程序后无法使用ESPtouch配网
签到天数: 1 天
发表于 2021-6-11 18:00 | 显示全部楼层 |阅读模式
各位大佬好,之前使用以下代码可以用BLINKER进行配网,前一阵家里换了wifi6的路由,然后不记得esptouch配网更换ssid和密码了,重新更换点灯Key之后刷写了程序,就一直无法通过esptouch配网,显示搜索不到设备,板子重新flash清除过固件。
求帮忙解决~
//WS2812RGB+ESP8266-01s或NodeMCU
//完善亮度控制
#define BLINKER_PRINT Serial
#define BLINKER_MIOT_LIGHT
#define BLINKER_WIFI
#include <Blinker.h>  //点灯库
char auth[] = "736576de038c";  //填写自己的点灯key
//****秘钥****/
#define PIN D7  // 设置引脚D7接WS2812的输入(IN)引脚
#define NUMPIXELS 60  // 设置ws2812的LED灯珠数量
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
//Adafruit_NeoPixel提供以下几种方式组合,自由搭配
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
// 新建组件对象
BlinkerRGB RGB1("RGB");
BlinkerButton Button1("key");
BlinkerText Text_ip("tex-ip");
BlinkerText Text_str("tex-str");
int counter = 0;
int LED_R = 0, LED_G = 0, LED_B = 0, LED_Bright = 180; // RGB和亮度
bool LED_Flag = false;
bool WIFI_Status = true;
void smartConfig()//配网函数
  WiFi.mode(WIFI_STA);
  Serial.println("\r\nWait for Smartconfig...");
  WiFi.beginSmartConfig();//等待手机端发出的用户名与密码
  while (1)
    Serial.print(".");
    if (WiFi.smartConfigDone())//退出等待
      Serial.println("SmartConfig Success");
      Serial.printf("SSID:%s\r\n", WiFi.SSID().c_str());
      Serial.printf("PSW:%s\r\n", WiFi.psk().c_str());
void WIFI_Set()//
  //Serial.println("\r\n正在连接");
  int count = 0;
  while (WiFi.status() != WL_CONNECTED)
    if (WIFI_Status)
      Serial.print(".");
      count++;
      if (count >= 5) //5s
        WIFI_Status = false;
        Serial.println("WiFi连接失败,请用手机进行配网");
      smartConfig();  //微信智能配网
  /* Serial.println("连接成功");
    Serial.print("IP:");
    Serial.println(WiFi.localIP());*/
  Blinker.print(state);
  //digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
  LED_Flag = !LED_Flag;
  if (LED_Flag) SET_RGB(255, 255, 255, LED_Bright);
  else SET_RGB(0, 0, 0, 0);
  counter = counter;
  Number1.print(counter);
void SET_RGB(int R, int G, int B, int bright)
  for (uint16_t i = 0; i < NUMPIXELS; i++) //把灯条变色
    pixels.setPixelColor(i, R, G, B);
  pixels.setBrightness(bright);//亮度
  pixels.show();    //送出显示
//APP RGB颜色设置回调
void rgb1_callback(uint8_t r_value, uint8_t g_value,
                   uint8_t b_value, uint8_t bright_value)
  BLINKER_LOG("R value: ", r_value);
  BLINKER_LOG("G value: ", g_value);
  BLINKER_LOG("B value: ", b_value);
  BLINKER_LOG("Rrightness value: ", bright_value);
  LED_Bright = bright_value;
  SET_RGB(r_value, g_value, b_value, LED_Bright);
//小爱电源类回调
    //digitalWrite(LED_BUILTIN, LOW);
    SET_RGB(255, 255, 255, 255);
    BlinkerMIOT.powerState("on");
    BlinkerMIOT.print();
    //digitalWrite(LED_BUILTIN, HIGH);
    SET_RGB(255, 255, 255, 0);
//小爱设置颜色回调
void miotColor(int32_t color)
  BLINKER_LOG("need set color: ", color);
  int colorR, colorG, colorB;
  colorR = color >> 16 & 0xFF;
  colorG = color >>  8 & 0xFF;
  colorB = color       & 0xFF;
  BLINKER_LOG("colorR: ", colorR, ", colorG: ", colorG, ", colorB: ", colorB);
  SET_RGB(colorR, colorG, colorB, LED_Bright);
  //pixelShow();
  BlinkerMIOT.color(color);//反馈小爱控制状态
//小爱调亮度回调
void miotBright(const String & bright)
  BLINKER_LOG("need set brightness: ", bright);
  int colorW = bright.toInt();
  BLINKER_LOG("now set brightness: ", colorW);
  LED_Bright = colorW;
  if (LED_Bright >= 80 && LED_Bright <= 100) {
  } else if (LED_Bright >= 40 && LED_Bright <= 79) {
    SET_RGB(125, 125, 125, 125);
  } else if (LED_Bright >= 1 && LED_Bright <= 39) {
    SET_RGB(50, 50, 50, 50);
  Serial.printf("亮度调节中...%d", colorW);
  BlinkerMIOT.brightness(colorW);//反馈小爱控制状态
  // 初始化串口
  pixels.begin();//WS2812初始化
  pixels.show();
  pinMode(LED_BUILTIN, OUTPUT);
#if defined(BLINKER_PRINT)
#endif
  WIFI_Set();
  // 初始化blinker
  Blinker.reset();
  Blinker.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
  Blinker.attachData(dataRead);//如果没有被绑定的组件被触发就执行这个回调
  Button1.attach(button1_callback);//Button1这个组件被触发就执行这个回调
  RGB1.attach(rgb1_callback);//注册调节颜色的回调函数
  BlinkerMIOT.attachColor(miotColor);//小爱调节颜色
  BlinkerMIOT.attachBrightness(miotBright);//小爱调节RGB亮度
  Blinker.attachHeartbeat(heartbeat);          //将传感器获取的数据传给
  给blinkerapp回传数据
void heartbeat() {
  Text_ip.print(WiFi.localIP().toString().c_str());
//unsigned long  timecnt = Blinker.runTime();//获取运行时间单位秒
unsigned long timecnt = millis();
unsigned long fenl = timecnt/ 60000L; //计算分
  Text_str.print(fenl);//显示分
发表于 2021-6-12 20:54 | 显示全部楼层
1.esp8266/32只支持2.4G wifi接入
2.esptouch受环境影响较大,部分网络环境会配置失败,esp官方的问题。
签到天数: 1 天
 楼主| 发表于 2021-6-13 09:12 来自手机 | 显示全部楼层
2.esptouch受环境影响较大,部分网络环境会配置失败,esp官方的问题。 ...
版主,我是用的2.4和5G混合wifi,是不是也不行啊
不是,这个是esp官方esptouch手机端的bug,blinker中直接使用的是esp官方模块,存在已久了,一直没有解决。  详情 回复 发表于 2021-6-14 10:38
发表于 2021-6-14 10:38 | 显示全部楼层
不是,具体原因不详,表现就是在一些环境下esptouch无法成功,这个是esp官方esptouch手机端的bug,blinker中直接使用的是esp官方模块,问题存在已久了,一直没有解决。
智能“百味”勺子开发实战营,为你的生活添滋味!
智能“百味”勺子开发实战
20sffactory 三自由度3D打
多位数码管显示项目——以TM1650为例
多位数码管显示项目——以
新手小白付费拜师求教:TM1650四位时钟数码管的具体用法
新手小白付费拜师求教:TM
