这个程序有大佬能帮忙检查一下么。这个是智能垃圾桶,-Arduino中文社区 - Powered by Discuz!
查看: 224|回复: 0
发表于 2021-7-30 17:31 | 显示全部楼层 |阅读模式
#include <Servo.h>
volatile int s;
Servo servo_8;
float checkdistance_2_4() {
  digitalWrite(2, LOW);
  delayMicroseconds(2);
  digitalWrite(2, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(4, HIGH) / 58.00;
  delay(10);
  return distance;
void setup(){
  s = 0;
  servo_8.attach(8);
  pinMode(2, OUTPUT);
  pinMode(4, INPUT);
  servo_8.write(90);
  delay(0);
  for (int i = 1; i <= 5; i = i + (1)) {
    s = checkdistance_2_4();
void loop(){
  Serial.println(s);
  if ((s<10)) {
    delay(200);
    if ((s<10)) {
      for (int i = 90; i <= 180; i = i + (2)) {
        servo_8.write(i);
        delay(10);
      delay(2000);
      for (int i = 180; i >= 90; i = i + (-3)) {
        servo_8.write(i);
        delay(10);
用的是超声波传感器,程序下栽进去了,超声波感应到了,马达一直在旋转,有大佬能检查一下哪出错了么
继电器断开瞬间esp32重启或者网络断开
继电器断开瞬间esp32重启
【Arduino】168种传感器系
【Arduino】168种传感器系
大佬们,帮帮忙
大佬们,帮帮忙
