请问下 Arduino nano 编译失败怎么解决-Arduino中文社区 - Powered by Discuz!
查看: 349|回复: 2
[未解决] 请问下 Arduino nano 编译失败怎么解决
发表于 2021-7-31 22:09 来自手机 | 显示全部楼层 |阅读模式
Arduino:1.8.4 (Mac OS X), 开发板:"Arduino Nano, ATmega328P"
/Applications/Arduino.app/Contents/Java/arduino-builder 返回 139
为开发板 Arduino Nano 编译时出错。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
签到天数: 68 天
发表于 2021-8-1 07:06 | 显示全部楼层
开启详细输出,查找errors
 楼主| 发表于 2021-8-1 10:46 来自手机 | 显示全部楼层
XlinliY.Zhang 发表于 2021-8-1 07:06
开启详细输出,查找errors
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/hyldc/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10804 -build-path /var/folders/1b/m7r7k1mn05n_vc_wmbv1_9bh0000gn/T/arduino_build_776792 -warnings=none -build-cache /var/folders/1b/m7r7k1mn05n_vc_wmbv1_9bh0000gn/T/arduino_cache_355130 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /var/folders/1b/m7r7k1mn05n_vc_wmbv1_9bh0000gn/T/untitled1982058979.tmp/sketch_aug01a/sketch_aug01a.ino
继电器断开瞬间esp32重启或者网络断开
继电器断开瞬间esp32重启
【Arduino】168种传感器系
【Arduino】168种传感器系
大佬们,帮帮忙
大佬们,帮帮忙
