涂鸦训练营的wbr3开发板收到了,示例代码编译报错-Arduino中文社区 - Powered by Discuz!
查看: 178|回复: 0
签到天数: 36 天
发表于 2021-8-4 12:57 | 显示全部楼层 |阅读模式
涂鸦训练营的wbr3开发板收到了,按照操作指南,装软件,装驱动,设置环境变量,然后就卡在了这里。打开官方提供的示例,编译报错。
有没有老哥能帮忙看看我这问题出在哪里?
Arduino:1.8.15 (Windows 10), 开发板:"Nucleo-64, Nucleo G071RB, STM32CubeProgrammer (SWD), Enabled (generic 'Serial'), None, Low/Full Speed, Smallest (-Os default), Newlib Nano (default)"
In file included from d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDataPoint.cpp:13:
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:49:17: error: expected identifier before numeric constant
   49 | #define DISABLE 0
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:132:3: note: in expansion of macro 'DISABLE'
  132 |   DISABLE = 0,
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:49:17: error: expected '}' before numeric constant
  132 |   DISABLE = 0,
In file included from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\cores\arduino/stm32/stm32_def.h:38,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\cores\arduino/stm32/clock.h:43,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\cores\arduino/wiring_time.h:23,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\cores\arduino/wiring.h:38,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\cores\arduino/Arduino.h:36,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\libraries\SoftwareSerial\src/SoftwareSerial.h:36,
                 from d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaUart.h:17,
                 from d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDataPoint.cpp:15:
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:131:1: note: to match this '{'
  131 | {
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:49:17: error: expected unqualified-id before numeric constant
  132 |   DISABLE = 0,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:134:3: error: 'FunctionalState' does not name a type
  134 | } FunctionalState;
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:33:17: error: expected identifier before numeric constant
   33 | #define SUCCESS 1
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:139:3: note: in expansion of macro 'SUCCESS'
  139 |   SUCCESS = 0,
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:33:17: error: expected '}' before numeric constant
  139 |   SUCCESS = 0,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:138:1: note: to match this '{'
  138 | {
d:\Documents\Arduino\libraries\Tuya_WiFi_MCU_SDK\src\TuyaDefs.h:33:17: error: expected unqualified-id before numeric constant
  139 |   SUCCESS = 0,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:141:1: error: expected declaration before '}' token
  141 | } ErrorStatus;
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:141:3: error: 'ErrorStatus' does not name a type
In file included from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_dma.h:604,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/STM32G0xx/stm32g0xx_hal_conf_default.h:203,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/STM32G0xx/stm32g0xx_hal_conf.h:13,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal.h:30,
                 from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:171,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_dma_ex.h:60:3: error: 'FunctionalState' does not name a type
   60 |   FunctionalState SyncEnable;  /*!< Specifies if the synchronization shall be enabled or disabled
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_dma_ex.h:63:3: error: 'FunctionalState' does not name a type
   63 |   FunctionalState EventEnable;    /*!< Specifies if an event shall be generated once the RequestNumber is reached.
In file included from C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/STM32G0xx/stm32g0xx_hal_conf_default.h:211,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:122:3: error: 'FunctionalState' does not name a type
  122 |   FunctionalState LowPowerAutoWait; /*!< Select the dynamic low power Auto Delay: new conversion start only when the previous
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:133:3: error: 'FunctionalState' does not name a type
  133 |   FunctionalState LowPowerAutoPowerOff; /*!< Select the auto-off mode: the ADC automatically powers-off after a conversion and automatically wakes-up when a new conversion is triggered (with startup time between trigger and start of sampling).
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:138:3: error: 'FunctionalState' does not name a type
  138 |   FunctionalState ContinuousConvMode; /*!< Specify whether the conversion is performed in single mode (one conversion) or continuous mode for ADC group regular,
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:154:3: error: 'FunctionalState' does not name a type
  154 |   FunctionalState DiscontinuousConvMode; /*!< Specify whether the conversions sequence of ADC group regular is performed in Complete-sequence/Discontinuous-sequence
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:170:3: error: 'FunctionalState' does not name a type
  170 |   FunctionalState DMAContinuousRequests; /*!< Specify whether the DMA requests are performed in one shot mode (DMA transfer stops when number of conversions is reached)
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:203:3: error: 'FunctionalState' does not name a type
  203 |   FunctionalState OversamplingMode;       /*!< Specify whether the oversampling feature is enabled or disabled.
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/STM32G0xx_HAL_Driver/Inc/stm32g0xx_hal_adc.h:286:3: error: 'FunctionalState' does not name a type
  286 |   FunctionalState ITMode;     /*!< Specify whether the analog watchdog is configured in interrupt or polling mode.
C:\Users\xincm\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.9.0\system/Drivers/CMSIS/Device/ST/STM32G0xx/Include/stm32g0xx.h:175:1: error: expected declaration before '}' token
  175 | }
exit status 1
为开发板 Nucleo-64 编译时出错。
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
继电器断开瞬间esp32重启或者网络断开
继电器断开瞬间esp32重启
【Arduino】168种传感器系
【Arduino】168种传感器系
大佬们,帮帮忙
大佬们,帮帮忙
