查看: 240|回复: 1
[未解决] ESP32从SD卡读取汉字库一直重启
发表于 2021-9-18 18:27 | 显示全部楼层 |阅读模式
以下是我的代码,是仿照https://platformio.org/lib/show/1559/TFT_eSPI/examples改写的代码,显示图片正常,但是一到载入字体,tft.loadFont(fileName, SD); 就报错重启
  tft.init();
  tft.setRotation(0);
  tft.fillScreen(TFT_BLACK);
   if (TFT_BL > 0) { // TFT_BL has been set in the TFT_eSPI library in the User Setup file TTGO_T_Display.h
     pinMode(TFT_BL, OUTPUT); // Set backlight pin to output mode
     digitalWrite(TFT_BL, HIGH);
    // digitalWrite(TFT_BL, TFT_BACKLIGHT_ON); // Turn backlight on. TFT_BACKLIGHT_ON has been set in the TFT_eSPI library in the User Setup file TTGO_T_Display.h
   //挂载文件系统
  sdSPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS);
  if (!SD.begin(SD_CS, sdSPI))
    DebugPrintln("存储卡挂载失败");
    return;
tft.setTextWrap(true, true);
  // Name of font file (library adds leading / and .vlw)
  String fileName = "MicrosoftYaHeiUI-16";
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.loadFont(fileName, SD);       // Use font stored on SD
  tft.setCursor(0, 0);
tft.println("测试!");
  tft.unloadFont();
///////////////////////////////////////////////////错误信息
18:25:59.330 -> Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
18:25:59.424 -> Core 1 register dump:
18:25:59.424 -> PC      : 0x400d51cb  PS      : 0x00060b30  A0      : 0x800d58b8  A1      : 0x3ffb1ed0
18:25:59.517 -> A2      : 0x3ffbfea4  A3      : 0x00000000  A4      : 0x0008f1a4  A5      : 0x00000000
18:25:59.611 -> A6      : 0x00000004  A7      : 0x00000008  A8      : 0x00000002  A9      : 0x3ffd1ed0
18:25:59.704 -> A10     : 0xfffffffc  A11     : 0x00000000  A12     : 0x00000006  A13     : 0x3f40b6f0
18:25:59.847 -> A14     : 0x3ffb8b84  A15     : 0xff000000  SAR     : 0x0000001b  EXCCAUSE: 0x0000001d
18:25:59.894 -> EXCVADDR: 0x00000000  LBEG    : 0x4000c28c  LEND    : 0x4000c296  LCOUNT  : 0x00000000
18:25:59.990 ->
18:25:59.990 -> ELF file SHA256: 0000000000000000
18:26:00.037 ->
18:26:00.037 -> Backtrace: 0x400d51cb:0x3ffb1ed0 0x400d58b5:0x3ffb1ef0 0x400d5921:0x3ffb1f40 0x400d0f91:0x3ffb1f70 0x400d7325:0x3ffb1fb0 0x400862b1:0x3ffb1fd0
18:26:00.177 ->
18:26:00.177 -> Rebooting...
发表于 2021-9-19 20:01 | 显示全部楼层
追进去看看具体哪里
为什么ESP32不能使用超过3个GPIO引脚
为什么ESP32不能使用超过3
我用ESP32s作为主控制作的一个8路继电器,单独测试每一路都可以正常工作,但是一旦同
DIY炫彩灯带,竟如此简单,更有硬件开发工具免费领!
DIY炫彩灯带,竟如此简单
如何用PID代替电位器控制Arduino的PWM输出?
如何用PID代替电位器控制A
如题,想实现Arduino用PID代替电位器控制PWM的输出,以此来控制一个MOSFET驱动器,求
【原创】全球最小口袋3D打印机mini one直播教程贴
【原创】全球最小口袋3D打
重大好消息,重大好消息,ARDUINO IDE支持中文变量名称了。
重大好消息,重大好消息,
我想念已久的中文变量名终于可以了。
