查看: 199|回复: 3
[未解决] 如何在開始前延遲2秒才實現
发表于 2022-1-13 19:57 | 显示全部楼层 |阅读模式
請問要如何在開始閃燈前, 先延遲2秒才觸發閃燈?
PS. 只在開始時發生一次2秒延遲
  1. // constants won't change. Used here to set a pin number:
  2. const int ledPin =  LED_BUILTIN;// the number of the LED pin
  3. // Variables will change:
  4. int ledState = LOW;             // ledState used to set the LED
  5. // Generally, you should use "unsigned long" for variables that hold time
  6. // The value will quickly become too large for an int to store
  7. unsigned long previousMillis = 0;        // will store last time LED was updated
  8. // constants won't change:
  9. const long interval = 1000;           // interval at which to blink (milliseconds)
  10. void setup() {
  11.   // set the digital pin as output:
  12.   pinMode(ledPin, OUTPUT);
  13. }
  14. void loop() {
  15.   // here is where you'd put code that needs to be running all the time.
  16.   // check to see if it's time to blink the LED; that is, if the difference
  17.   // between the current time and last time you blinked the LED is bigger than
  18.   // the interval at which you want to blink the LED.
  19.   unsigned long currentMillis = millis();
  20.   if (currentMillis - previousMillis >= interval) {
  21.     // save the last time you blinked the LED
  22.     previousMillis = currentMillis;
  23.     // if the LED is off turn it on and vice-versa:
  24.     if (ledState == LOW) {
  25.       ledState = HIGH;
  26.     } else {
  27.       ledState = LOW;
  28.     }
  29.     // set the LED with the ledState of the variable:
  30.     digitalWrite(ledPin, ledState);
  31.   }
  32. }
发表于 2022-1-14 10:27 | 显示全部楼层
放在setup里一段,或者设置一个标志位,用个if判断是否是第一次执行
 楼主| 发表于 2022-1-14 21:17 | 显示全部楼层
不好意思, 我是新手.
可否說明詳細一些?
签到天数: 312 天
发表于 2022-1-14 22:23 | 显示全部楼层
andywwf 发表于 2022-1-14 21:17
不好意思, 我是新手.
可否說明詳細一些?
在 setup() 裏面放一條延遲 2 秒的指令
delay(2000);
就只有在開機時才會延遲
毕设求助!max30102与gy906实现脉搏体温测量
毕设求助!max30102与gy90
arduino解码sbus
arduino解码sbus
香蕉派 BPI-R3 开源路由器
求智能垃圾桶编程代码
求智能垃圾桶编程代码
求大佬解答 很急!!
安信可ESP32点灯APP自动浇花和天气空气质量
安信可ESP32点灯APP自动浇
