查看: 2093|回复: 0
发表于 2022-4-12 00:48 | 显示全部楼层 |阅读模式
TTGO T8 1.7.1采用Espressif官方ESP32-WROVER模块制作,4MB闪存和8MB PSRAM,支持TF 内存卡。上面的图片右下角就是板载的SD卡槽走线情况。由此连线在使用TFT_eSPI库驱动2.4寸ILI9341屏幕,共用SPI总线,采用Software SPI的方法。一般爱好者会修改TFT_eSPI库中User_Setup.h的设置,但是库文件升级以后,就会被覆盖掉。
另辟蹊径,在..\Arduino\libraries\ 中创建TFT_eSPI_Setups文件夹,在里面放置你的配置文件,这样就避免了重复修改。譬如已经存入TFT_eSPI_ILI9341_TTGO_T8_user.h ,那么只需要在TFT_eSPI库的User_Setup_Select.h中,注释掉//#include <User_Setup.h>,然后添加#include <../TFT_eSPI_Setups/TFT_eSPI_ILI9341_TTGO_T8_user.h>。
在程序里引用TFT_eSPI_ILI9341_TTGO_T8_user.h 就可以了。该文件内容如下:
[pre]// ##################################################################################
// Section 1. Call up the right driver file and any options for it
// Only define one driver, the other ones must be commented out
#define ILI9341_DRIVER       // Generic driver for common displays
// For ST7735, ST7789 and ILI9341 ONLY, define the colour order IF the blue and red are swapped on your display
// Try ONE option at a time to find the correct colour order for your display
#define TFT_RGB_ORDER TFT_RGB  // Colour order Red-Green-Blue
// Section 2. Define the pins that are used to interface with the display here
// If a backlight control signal is available then define the TFT_BL pin in Section 2
// below. The backlight will be turned ON when tft.begin() is called, but the library
// needs to know if the LEDs are ON with the pin HIGH or LOW. If the LEDs are to be
// driven with a PWM signal or turned OFF/ON then this must be handled by the user
// sketch. e.g. with digitalWrite(TFT_BL, LOW);
#define TFT_BL   22            // LED back-light control pin
#define TFT_BACKLIGHT_ON HIGH  // Level to turn ON back-light (HIGH or LOW)
// For ESP32 Dev board (only tested with GC9A01 display)
// The Software SPI can be mapped to any pins
// TTGO T8 结合SD卡考虑管脚配置,SD卡CS管脚13
#define TFT_MISO 2
#define TFT_MOSI 15 // In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 14
#define TFT_CS   18  // Chip select control pin
#define TFT_DC   5  // Data Command control pin
#define TFT_RST  4  // Reset pin (could connect to Arduino RESET pin)
#define SD_CS    13
//#define TOUCH_CS 27     // Chip select pin (T_CS) of touch screen
// Section 3. Define the fonts that are to be used here
// Comment out the #defines below with // to stop that font being loaded
// The ESP8366 and ESP32 have plenty of memory so commenting out fonts is not
// normally necessary. If all fonts are loaded the extra FLASH space required is
// about 17Kbytes. To save FLASH space only enable the fonts you need!
#define LOAD_GLCD   // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2  // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4  // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6  // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7  // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8  // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF  // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
// Section 4. Other options
// Define the SPI clock frequency, this affects the graphics rendering speed. Too
// fast and the TFT driver will not keep up and display corruption appears.
// With an ILI9341 display 40MHz works OK, 80MHz sometimes fails
// With a ST7735 display more than 27MHz may not work (spurious pixels and lines)
// With an ILI9163 display 27 MHz works OK.
#define SPI_FREQUENCY  40000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY  60000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY  2500000[/pre]
其中,把SD卡的选择引脚也一并加入了,接下来就可以实现把TF卡里面的图片读取出来用2.4寸ILI9341屏幕显示出来。程序如下:
[pre]#include <SPI.h>
#include <FS.h>
#include <SD.h>
// JPEG decoder library
#include <JPEGDecoder.h>
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI(320, 240);
SPIClass SDSPI(VSPI);
// Setup
  SDSPI.begin(TFT_SCLK, TFT_MISO, TFT_MOSI);
  digitalWrite(TFT_BL, HIGH);
  tft.init();
  tft.setRotation(0);
  tft.begin();
  if (!SD.begin(SD_CS,SDSPI)) {
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
  } else {
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  Serial.println("initialisation done.");
// Main loop
  tft.setRotation(3);  // portrait
  tft.fillScreen(TFT_BLACK);
  tft.setSwapBytes(true);
  // The image is 300 x 300 pixels so we do some sums to position image in the middle of the screen!
  // Doing this by reading the image width and height from the jpeg info is left as an exercise!
  int x = (tft.width()  - 300) / 2 - 1;
  int y = (tft.height() - 300) / 2 - 1;
  drawSdJpeg("/EagleEye.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  drawSdJpeg("/Baboon40.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  drawSdJpeg("/lena20k.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  drawSdJpeg("/panda.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  tft.setRotation(2);  // landscape
  drawSdJpeg("/Mouse480.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
// Draw a JPEG on the TFT pulled from SD Card
// xpos, ypos is top left corner of plotted image
void drawSdJpeg(const char *filename, int xpos, int ypos) {
  // Open the named file (the Jpeg decoder library will close it)
  File jpegFile = SD.open( filename, FILE_READ);  // or, file handle reference for SD library
  if ( !jpegFile ) {
    Serial.print("ERROR: File \""); Serial.print(filename); Serial.println ("\" not found!");
    return;
  Serial.println("===========================");
  Serial.print("Drawing file: "); Serial.println(filename);
  // Use one of the following methods to initialise the decoder:
  bool decoded = JpegDec.decodeSdFile(jpegFile);  // Pass the SD file handle to the decoder,
  //bool decoded = JpegDec.decodeSdFile(filename);  // or pass the filename (String or character array)
  if (decoded) {
    // print information about the image to the serial port
    jpegInfo();
    // render the image onto the screen at given coordinates
    jpegRender(xpos, ypos);
  else {
    Serial.println("Jpeg file format not supported!");
// Draw a JPEG on the TFT, images will be cropped on the right/bottom sides if they do not fit
// This function assumes xpos,ypos is a valid screen coordinate. For convenience images that do not
// fit totally on the screen are cropped to the nearest MCU size and may leave right/bottom borders.
void jpegRender(int xpos, int ypos) {
  //jpegInfo(); // Print information from the JPEG file (could comment this line out)
  uint16_t *pImg;
  uint16_t mcu_w = JpegDec.MCUWidth;
  uint16_t mcu_h = JpegDec.MCUHeight;
  uint32_t max_x = JpegDec.width;
  uint32_t max_y = JpegDec.height;
  bool swapBytes = tft.getSwapBytes();
  // Jpeg images are draw as a set of image block (tiles) called Minimum Coding Units (MCUs)
  // Typically these MCUs are 16x16 pixel blocks
  // Determine the width and height of the right and bottom edge image blocks
  uint32_t min_w = jpg_min(mcu_w, max_x % mcu_w);
  uint32_t min_h = jpg_min(mcu_h, max_y % mcu_h);
  // save the current image block size
  uint32_t win_w = mcu_w;
  uint32_t win_h = mcu_h;
  // record the current time so we can measure how long it takes to draw an image
  uint32_t drawTime = millis();
  // save the coordinate of the right and bottom edges to assist image cropping
  // to the screen size
  max_x += xpos;
  max_y += ypos;
  // Fetch data from the file, decode and display
  while (JpegDec.read()) {    // While there is more data in the file
    pImg = JpegDec.pImage ;   // Decode a MCU (Minimum Coding Unit, typically a 8x8 or 16x16 pixel block)
    // Calculate coordinates of top left corner of current MCU
    int mcu_x = JpegDec.MCUx * mcu_w + xpos;
    int mcu_y = JpegDec.MCUy * mcu_h + ypos;
    // check if the image block size needs to be changed for the right edge
    if (mcu_x + mcu_w <= max_x) win_w = mcu_w;
    else win_w = min_w;
    // check if the image block size needs to be changed for the bottom edge
    if (mcu_y + mcu_h <= max_y) win_h = mcu_h;
    else win_h = min_h;
    // copy pixels into a contiguous block
    if (win_w != mcu_w)
      uint16_t *cImg;
      int p = 0;
      cImg = pImg + win_w;
      for (int h = 1; h < win_h; h++)
        p += mcu_w;
        for (int w = 0; w < win_w; w++)
          *cImg = *(pImg + w + p);
          cImg++;
    // calculate how many pixels must be drawn
    uint32_t mcu_pixels = win_w * win_h;
    // draw image MCU block only if it will fit on the screen
    if (( mcu_x + win_w ) <= tft.width() && ( mcu_y + win_h ) <= tft.height())
      tft.pushImage(mcu_x, mcu_y, win_w, win_h, pImg);
    else if ( (mcu_y + win_h) >= tft.height())
      JpegDec.abort(); // Image has run off bottom of screen so abort decoding
  tft.setSwapBytes(swapBytes);
  showTime(millis() - drawTime); // These lines are for sketch testing only
// Print image information to the serial port (optional)
// JpegDec.decodeFile(...) or JpegDec.decodeArray(...) must be called before this info is available!
void jpegInfo() {
  // Print information extracted from the JPEG file
  Serial.println("JPEG image info");
  Serial.println("===============");
  Serial.print("Width      :");
  Serial.println(JpegDec.width);
  Serial.print("Height     :");
  Serial.println(JpegDec.height);
  Serial.print("Components :");
  Serial.println(JpegDec.comps);
  Serial.print("MCU / row  :");
  Serial.println(JpegDec.MCUSPerRow);
  Serial.print("MCU / col  :");
  Serial.println(JpegDec.MCUSPerCol);
  Serial.print("Scan type  :");
  Serial.println(JpegDec.scanType);
  Serial.print("MCU width  :");
  Serial.println(JpegDec.MCUWidth);
  Serial.print("MCU height :");
  Serial.println(JpegDec.MCUHeight);
  Serial.println("");
// Show the execution time (optional)
// WARNING: for UNO/AVR legacy reasons printing text to the screen with the Mega might not work for
// sketch sizes greater than ~70KBytes because 16 bit address pointers are used in some libraries.
// The Due will work fine with the HX8357_Due library.
void showTime(uint32_t msTime) {
  //tft.setCursor(0, 0);
  //tft.setTextFont(1);
  //tft.setTextSize(2);
  //tft.setTextColor(TFT_WHITE, TFT_BLACK);
  //tft.print(F(" JPEG drawn in "));
  //tft.print(msTime);
  //tft.println(F(" ms "));
  Serial.print(F(" JPEG drawn in "));
  Serial.print(msTime);
  Serial.println(F(" ms "));
}[/pre]
如果需要用HSPI驱动就需要对配置做修改,存储的方法如前面叙述:
[pre]#define ILI9341_DRIVER       // Generic driver for common displays
//色彩顺序RGB
//背光
// HSPI管脚配置
#define TFT_MISO 12
#define TFT_MOSI 13
#define TFT_SCLK 14
#define TFT_CS   15  // Chip select control pin
#define TFT_RST   4  // Reset pin (could connect to RST pin)
// 设置字体
#define SMOOTH_FONT
//SPI频率
//否者刷屏不行
// 使用HSPI必须选
#define USE_HSPI_PORT[/pre]
开发板要这样选择:
感兴趣的爱好者可以下载后试一试。
data.rar (96.74 KB, 下载次数: 2)
(全文结束)
GMT+8, 2022-11-30 21:06 , Processed in 0.069719 second(s), 18 queries .
