楼主 |
发表于 2022-7-2 21:45
显示全部楼层
运行了官方例程都不行呀,感觉板子有问题~
- EEPROM Write
- Stores random values into the EEPROM.
- These values will stay in the EEPROM when the board is
- turned off and may be retrieved later by another sketch.
- #include "EEPROM.h"
- // the current address in the EEPROM (i.e. which byte
- // we're going to write to next)
- int addr = 0;
- #define EEPROM_SIZE 64
- void setup()
- Serial.begin(115200);
- Serial.println("start...");
- if (!EEPROM.begin(EEPROM_SIZE))
- Serial.println("failed to initialise EEPROM"); delay(1000000);
- Serial.println(" bytes read from Flash . Values are:");
- for (int i = 0; i < EEPROM_SIZE; i++)
- Serial.print(byte(EEPROM.read(i))); Serial.print(" ");
- Serial.println();
- Serial.println("writing random n. in memory");
- void loop()
- // need to divide by 4 because analog inputs range from
- // 0 to 1023 and each byte of the EEPROM can only hold a
- // value from 0 to 255.
- // int val = analogRead(10) / 4;
- int val = byte(random(10020));
- // write the value to the appropriate byte of the EEPROM.
- // these values will remain there when the board is
- // turned off.
- EEPROM.write(addr, val);
- Serial.print(val); Serial.print(" ");
- // advance to the next address. there are 512 bytes in
- // the EEPROM, so go back to 0 when we hit 512.
- // save all changes to the flash.
- addr = addr + 1;
- if (addr == EEPROM_SIZE)
- Serial.println();
- addr = 0;
- EEPROM.commit();
- Serial.print(EEPROM_SIZE);
- Serial.println(" bytes written on Flash . Values are:");
- Serial.println(); Serial.println("----------------------------------");
- delay(100);
复制代码 |
