查看: 648|回复: 2
[已解答] 快一周了,还是上不了线。。。。
发表于 2022-9-30 16:48 | 显示全部楼层 |阅读模式
之前发过求助,现象就是连接到wifi ,APP上一直是离线,关掉wifi ,用另一台手机开wifi一样的名称的热点,马上就上线了,换了三个模块都是同样的问题。
看串口信息,这样应该是连上网了吧?
串口信息每次还不太一样,但是都上不了线。。。。
有时是这样的:
Download latest blinker library here!
    => https://github.com/blinker-iot/blinker-library
[104] Connecting to fei
[109] ESP8266_MQTT initialized...
[109]
     EEPROM address 1536-2431 is used for Blinker Timer!
========= PLEASE AVOID USING THESE EEPROM ADDRESS! ========
[4359] WiFi Connected.
[4359] IP Address:
[4359] 192.168.1.171
[4570] Freeheap: 36456
[4572] mDNS responder started
[4573] webSocket_MQTT server started
[4573] ws://438752FD9VK8QQRUTQ4JL965.local:81
有时是这样的:
_time2: 0
[3610] _action2:
[3612] _lpData: 0
[3613] checkNum count: 1
[3615] checkNum count: 1
[6169] WiFi Connected.
[6170] IP Address:
[6170] 192.168.1.171
[6180] [HTTP] begin: http://iot.diandeng.tech/api/v1/user/device/diy/auth?authKey=69220482ede0&version=0.1.0&protocol=mqtt
[6388] [HTTP] GET... code: 200
[6390] reply was:
[6390] ==============================
[6390] {"detail": {"broker": "blinker", "deviceName": "438752FD9VK8QQRUTQ4JL965", "host": "mqtt://broker.diandeng.tech", "iotId": "BHQaPjCFhqvfMrECiW7FfEzFY6", "iotToken": "dLe97826jnjDygWbZ4wmmEauEwzkJHEa", "port": "1883", "productKey": "blinker", "uuid": "2c455696369611edb82f5254"}, "message": 1000}
[6411] ==============================
[6416] _num: 4
[6416] ====================
[6419] DEVICE_NAME_MQTT: 438752FD9VK8QQRUTQ4JL965
[6423] MQTT_PRODUCTINFO_MQTT: blinker
[6426] MQTT_ID_MQTT: 438752FD9VK8QQRUTQ4JL965
[6430] MQTT_NAME_MQTT: BHQaPjCFhqvfMrECiW7FfEzFY6
[6435] MQTT_KEY_MQTT: dLe97826jnjDygWbZ4wmmEauEwzkJHEa
[6440] MQTT_BROKER: blinker
[6442] HOST: broker.diandeng.tech
[6445] PORT: 1883
[6447] HOST: broker.diandeng.tech
[6450] PORT: 1883
[6452] UUID_MQTT: 2c455696369611edb82f5254
[6455] ====================
[6458] BLINKER_PUB_TOPIC_MQTT: /device/438752FD9VK8QQRUTQ4JL965/s
[6464] BLINKER_SUB_TOPIC_MQTT: /device/438752FD9VK8QQRUTQ4JL965/r
[6470] Freeheap: 34784
[6473] mDNS responder started
[6476] webSocket_MQTT server started
[6478] ws://438752FD9VK8QQRUTQ4JL965.local:81
发表于 2022-10-1 02:16 | 显示全部楼层
既然用手机热点能上线,那就不是blinker这边的问题,更可能是你路由器设置的问题
 楼主| 发表于 2022-10-5 21:24 | 显示全部楼层
我也觉得应该是路由器的WIFI问题 ,但是我更换过另一个路由器(路由器恢复了出厂设置,没有进行特殊的设置 ,原路由器是Openwrt系统,后更换的路由器是Padavan系统),还是上不了线,这个应该是点灯科技的BUG吧?因为其它设备都能正常上网,只有这个点灯科技上不了线。也不知道要对路由器进行什么设置才能正常上线。
GMT+8, 2022-12-1 21:20 , Processed in 0.065804 second(s), 16 queries .
