查看: 151|回复: 0
[未解决] arduino ide 2.0 错误不能启动界面
发表于 2022-11-24 11:33 | 显示全部楼层 |阅读模式
我的arduino ide 2.0.1,直接按图标启动,画面闪过管理员确认的信息后就没有信息了
在任务管理器里有三个 arduino IDE.exe的进程,然后就再也没有后续了
使用命令行运行显示如下错误信息
D:\Program Files\Arduino IDE>
Failed to start the electron application.
Error: EINVAL: invalid argument, realpath 'T:\Temp'
    at Function.realpathSync.native (node:fs:2540:3)
    at Function.native (node:electron/js2c/asar_bundle:5:4819)
    at new IsTempSketch (D:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\is-temp-sketch.js:25:51)
    at Object.resolveInstance (D:\Program Files\Arduino IDE\resources\app\node_modules\inversify\lib\resolution\instantiation.js:51:18)
    at D:\Program Files\Arduino IDE\resources\app\node_modules\inversify\lib\resolution\resolver.js:75:42
    at Array.map (<anonymous>)
    at _injectProperties (D:\Program Files\Arduino IDE\resources\app\node_modules\inversify\lib\resolution\instantiation.js:17:57)
    at Object.resolveInstance (D:\Program Files\Arduino IDE\resources\app\node_modules\inversify\lib\resolution\instantiation.js:48:18)
    at Object.resolve (D:\Program Files\Arduino IDE\resources\app\node_modules\inversify\lib\resolution\resolver.js:99:12) {
  errno: -4071,
  syscall: 'realpath',
  code: 'EINVAL',
  path: 'T:\\Temp'
[8296:1124/081910.546:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
这里面的T:\\Temp是我的系统内存虚拟硬盘,容量大小4G(全部内存16G),
我猜想的问题是T盘可能arduino不识别,系统其他软件运行正常
我的所有缓存文件和临时文件都在这里面,不知道怎么修改arduino ide来适应内存虚拟盘
向大神们请教
错误提示信息
错误提示信息
GMT+8, 2022-12-1 22:42 , Processed in 0.069975 second(s), 18 queries .
