查看: 110223|回复: 46
Arduino教程(提高篇)——使用EEPROM断电也能保存数据
发表于 2012-6-14 23:14 | 显示全部楼层 |阅读模式
EEPROM (Electrically Erasable Programmable Read-Only Memory),电可擦可编程只读存储器--一种掉电后数据不丢失的存储芯片。
简而言之就是你想断电后arduino还要保存一些参数,就使用EEPROM吧。
在各型号的arduino控制器上的AVR芯片均带有EEPROM,也有外接的EEPROM芯片,常见arduino控制器的EEPROM大小:
Arduino UNO、Arduino duemilanove-m328、Zduino m328均使用ATmega328芯片,EEPROM都为1K
Arduino duemilanove-m168的EEPROM为512bytes
Arduino 2560的EEPROM为4K
下面我们介绍arduino自带的EEPROM使用方法,arduino的库已经为我们准备好了EEPROM类库,我们要使用得先调用EEPROM.h,然后使用write和read方法,即可操作EEPROM。
另:下面的官方例子由于写成较早,所以讲EEPROM的大小都定为了512字节,实际使用中,大家可参照上面所说的EEPROM大小,自行更改。
1.写入
选择 File>Examples>EEPROM>eeprom_write
  1. /*
  2. * EEPROM Write
  3. *
  4. * Stores values read from analog input 0 into the EEPROM.
  5. * These values will stay in the EEPROM when the board is
  6. * turned off and may be retrieved later by another sketch.
  7. */
  8. #include <EEPROM.h>
  9. // EEPROM 的当前地址,即你将要写入的地址,这里就是从0开始写
  10. int addr = 0;
  11. void setup()
  12. {
  13. }
  14. void loop()
  15. {
  16.   //模拟值读出后是一个0-1024的值,但每字节的大小为0-255,所以这里将值除以4再存储到val
  17.   int val = analogRead(0) / 4;
  18.
  19.   // write the value to the appropriate byte of the EEPROM.
  20.   // these values will remain there when the board is
  21.   // turned off.
  22.   EEPROM.write(addr, val);
  23.
  24.   // advance to the next address.  there are 512 bytes in
  25.   // the EEPROM, so go back to 0 when we hit 512.
  26.   addr = addr + 1;
  27.   if (addr == 512)
  28.     addr = 0;
  29.
  30.   delay(100);
  31. }
2.读取
选择 File>Examples>EEPROM>eeprom_read
  1. /*
  2. * EEPROM Read
  3. *
  4. * Reads the value of each byte of the EEPROM and prints it
  5. * to the computer.
  6. * This example code is in the public domain.
  7. */
  9. // start reading from the first byte (address 0) of the EEPROM
  10. int address = 0;
  11. byte value;
  12. void setup()
  13. {
  14.   // initialize serial and wait for port to open:
  15.   Serial.begin(9600);
  16.   while (!Serial) {
  17.     ; // wait for serial port to connect. Needed for Leonardo only
  18.   }
  19. }
  20. void loop()
  21. {
  22.   // read a byte from the current address of the EEPROM
  23.   value = EEPROM.read(address);
  24.
  25.   Serial.print(address);
  26.   Serial.print("\t");
  27.   Serial.print(value, DEC);
  28.   Serial.println();
  29.
  30.   // advance to the next address of the EEPROM
  31.   address = address + 1;
  32.
  33.   // there are only 512 bytes of EEPROM, from 0 to 511, so if we're
  34.   // on address 512, wrap around to address 0
  35.   if (address == 512)
  36.     address = 0;
  37.
  38.   delay(500);
  39. }
3.清除
选择 File>Examples>EEPROM>eeprom_clear
清除EEPROM的内容,其实就是把EEPROM中每一个字节写入0,因为只用清一次零,所以整个程序都在setup部分完成。
  1. /* * EEPROM Clear
  2. *
  3. * Sets all of the bytes of the EEPROM to 0.
  4. * This example code is in the public domain.
  5. */
  6. #include <EEPROM.h>
  7. void setup()
  8. {
  9.   // 让EEPROM的512字节内容全部清零
  10.   for (int i = 0; i < 512; i++)
  11.     EEPROM.write(i, 0);
  12.
  13.   // 清零工作完成后,将L灯点亮,提示EEPROM清零完成
  14.   digitalWrite(13, HIGH);
  15. }
  16. void loop()
  17. {
  18. }
使用共用体结构保存其他类型的数据到EEPROM:http://www.arduino.cn/thread-2684-1-1.html
评分
参与人数 1金币 +9 收起 理由
袁培根 + 9 很给力!
查看全部评分
 楼主| 发表于 2012-6-14 23:57 | 显示全部楼层
还没翻译完,明天再写~
发表于 2012-6-15 10:01 | 显示全部楼层
写的挺好的,但是第一个例子和第三个例子的“选择 File>Examples>EEPROM>eeprom_write”这一部分是不是弄反了
3Q,谢谢指正~  发表于 2012-6-15 13:14
 楼主| 发表于 2012-6-15 13:13 | 显示全部楼层
dy20082250 发表于 2012-6-15 10:01
写的挺好的,但是第一个例子和第三个例子的“选择 File>Examples>EEPROM>eeprom_write”这一部分是不是弄反 ...
发现了,谢谢指正
发表于 2012-6-17 22:07 | 显示全部楼层
楼主辛苦了。让我这个小白入门了。
发表于 2012-7-23 09:43 | 显示全部楼层
我想知道这个编程环境能在线调试不?叫什么名字啊。
发表于 2012-7-23 09:46 | 显示全部楼层
不能在线调试
发表于 2012-7-23 14:18 | 显示全部楼层
奈何col 发表于 2012-7-23 09:46
不能在线调试
这样啊。。我知道了,谢谢。。想找一个能在线调试的,,
发表于 2012-8-6 11:15 | 显示全部楼层
第三个清除eeprom的例子,最后点灯之前不需要将13数字口设置为输出模式么?
发表于 2012-8-13 22:27 | 显示全部楼层
不是很明白 但是很崇拜
GMT+8, 2023-3-21 10:25 , Processed in 0.079110 second(s), 17 queries .
