程序作用:实现下图这样的矩阵键盘控制,将按键代表的数字或字母输出到上位机。
/***************horizontal port******************/#define hor1 30#define hor2 31#define hor3 32#define hor4 33int horizontal[] = {30, 31, 32, 33};/***************vertical port****************/#define ver1 34#define ver2 35#define ver3 36#define ver4 37int vertical[] = {34, 35, 36, 37};
int i = 0, j = 0;int num = 0;int count = 0;char sym = '0';int height=0;
void setup(){ Serial.begin(9600); for (i = 0; i < 4; i++) { pinMode(13, OUTPUT); pinMode(horizontal[i], OUTPUT); pinMode(vertical[i], INPUT_PULLUP); }}
void loop(){ for (i = 0; i < 4; i++) { digitalWrite(hor1, HIGH); digitalWrite(hor2, HIGH); digitalWrite(hor3, HIGH); digitalWrite(hor4, HIGH); digitalWrite(horizontal[i], LOW); for (j = 0; j < 4; j++) { if (digitalRead(vertical[j]) == LOW) { delay(10); if (digitalRead(vertical[j]) == LOW) { if (i != 3 && j != 3) { num = j + 3 * i + 1; Serial.println(num); count++; if (count == 1) //The first Number We take { height = num * 10; } else if (count == 2) { height += num; } else { count = 0; num=0; } } if (j == 3) { switch (i) { case 0: sym = 'A'; num = 0; count = 0; break; case 1: sym = 'B'; break; case 2: sym = 'C'; break; case 3: sym = 'D'; if(count == 1) Serial.println(height/10); else Serial.println(height); num = 0; count = 0; break; } Serial.println(sym); } if (i == 3 && j != 3) { if (j == 0) sym = '*'; if (j == 2) sym = '#'; Serial.println(sym); if (j == 1) { num = 0; Serial.println(num); count++; if (count == 1) { height = num * 10; } else if (count == 2) { height += num; } else { count = 0; num=0; } } } } while (digitalRead(vertical[j]) == LOW); delay(10); } } }}
