查看: 17011|回复: 13
【328P+W5100】在web中读取SD卡的文件
    2015-10-30 10:45
    发表于 2015-11-14 22:09 | 显示全部楼层 |阅读模式
    磨磨唧唧写了一个礼拜,弄出来这个了,总之SD.h这个库是各种玄学。直接上代码!代码有点长 大家可以去github下载项目文件https://github.com/mo10/SDwebserver
    关于请求地址 表单 路径 后缀名截取方法 可以参考http://www.arduino.cn/thread-18012-1-1.html
    注意!访问不要太频繁,在上一个文件未完全关闭的情况下打开下一个文件可能会抽风!代码难免不出错,大家不要喷我~ Debug很累的
    #include <SPI.h>
    #include <Ethernet.h>
    #include <SD.h>
    byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};//mac地址
    IPAddress ip(192, 168, 31, 177);//ip地址
    EthernetServer server(80);//访问端口
    String fakename = "Nginx/1.8.0 (ATmega328p/Ubuntu 12.04 LTS)"; //装逼参数(伪装服务器)
    String res = "", path = "";
    EthernetClient client;
      while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      //启动sd
      Serial.print("init sd:");
      if (!SD.begin(4)) {
        Serial.println("failed");
        return;
      Serial.println("done");
      //启动eth
      Ethernet.begin(mac, ip);
      server.begin();
      Serial.print("ip:");
      Serial.println(Ethernet.localIP());
      client = server.available();
      if (client) {
        Serial.println("new client");
        delay(200);
        res = ""; path = ""; /*httpget = "", */
        int resend = 1;
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            //Serial.write(c);
            //只读取一行
            if (c != '\n' && resend) {
              res += c;
            } else {
              resend = 0;
            if (c == '\n' && currentLineIsBlank) {
              //判断GET头完整性
              if ((res.indexOf("GET ") != -1) && (res.indexOf(" HTTP") != -1)) {
                //判断是否存在get参数
                if (res.indexOf('?') != -1) {
                  //httpget = res.substring(res.indexOf('?') + 1, res.indexOf(" HTTP"));
                  path = res.substring(res.indexOf("GET ") + 4, res.indexOf('?'));
                } else {
                  path = res.substring(res.indexOf("GET ") + 4, res.indexOf(" HTTP"));
                Serial.println(res);
                //Serial.println("GET:" + httpget);
                Serial.println("path:" + path);
                //delay(100);
                File s = SD.open(path);
                if (s) {
                  webprintDirectory(s);
                } else {
                  client.println(s);
                  s.rewindDirectory();
                  s.close();
                //client.println("<p>" + fakename + "</p></body></html>");
            if (c == '\n') {
              // you're starting a new line
            else if (c != '\r') {
              // you've gotten a character on the current line
              currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disconnected");
    void webprintDirectory(File dir) {
      //判断是否为文件
      if (!dir.isDirectory()) {
        if (path.indexOf('.') != -1) {
          //获取后缀名
          http_header("200 OK", path.substring(path.indexOf('.') + 1));
        } else {
          http_header("200 OK", "txt");//文件没有后缀名 默认显示文本格式
        //读文件
        while (dir.available()) {
          char sc = dir.read();
          client.print(sc);
        dir.close();
        dir.rewindDirectory();
        return;//退出
      //判断不是文件
      http_header("200 OK", "htm");
      client.print("<!DOCTYPE HTML><html><body><h1>200 Success</h1><br />ATH:" + path + "<hr />");
      dir.rewindDirectory();//索引回到第一个位置
      while (true) {
        File entry =  dir.openNextFile();
        if (!entry) {
          //没有下一个索引了
          client.print("<br />No more files");
        if (path == "/") {
          client.print("<br /><a href=\"" + path);
        } else {
          client.print("<br /><a href=\"" + path + "/");
        client.print(entry.name());
        client.print("\"target=\"_self\">");
        client.print("</a>");
        if (!entry.isDirectory()) {
          // files have sizes, directories do not
          client.print("  ");
          client.println(entry.size(), DEC);
        entry.close();
      dir.close();
      delay(200);
    void http_header(String statuscode, String filetype) {
      filetype.toLowerCase();//把后缀名变小写
      client.println("HTTP/1.1 " + statuscode);
      client.print("Content-Type: ");
      //判断文件mime类型
      if (filetype == "htm" || filetype == "html") {
        client.println("text/html");
      if (filetype == "png" || filetype == "jpg" || filetype == "bmp" || filetype == "gif") {
        client.println("image/" + filetype);
      } else {
        client.println("text/plain");
      client.println("Connection: close");
      client.println();
    运行
    出现文件列表
    打开个图片看看
    加载速度有些坑爹了27KB文件要加载9秒多
    做个死 加载个大图片看看
    3MB用了17分钟,还是不要加载太大的图,慢死~~
    打开文本文件
    2020-4-7 14:48
  • 签到天数: 954 天
    [LV.10]以坛为家III
    发表于 2015-11-14 22:46 | 显示全部楼层
    膜拜一下高级东东
    2015-10-30 10:45
     楼主| 发表于 2015-11-15 00:27 | 显示全部楼层
    seesea 发表于 2015-11-14 22:46
    膜拜一下高级东东
    看海大大老是调侃我 给个精好不好啊~~?么么么
    2016-7-22 20:28
  • 签到天数: 5 天
    发表于 2015-11-15 20:32 | 显示全部楼层
    某十大神威武
    2020-4-7 14:48
  • 签到天数: 954 天
    [LV.10]以坛为家III
    发表于 2015-11-15 21:52 | 显示全部楼层
    某10大威武!
    2015-10-30 10:45
     楼主| 发表于 2015-11-17 07:19 | 显示全部楼层
    爱卓泰 爱生活!!
    2020-4-7 14:48
  • 签到天数: 954 天
    [LV.10]以坛为家III
    发表于 2015-11-17 22:06 | 显示全部楼层
    某1o 发表于 2015-11-17 07:19
    爱卓泰 爱生活!!
    哈哈,好基友,一辈子
    2017-1-22 10:14
  • 签到天数: 11 天
    发表于 2015-11-25 13:50 | 显示全部楼层
    好基友,一被子
    2019-10-16 23:39
  • 签到天数: 407 天
    发表于 2016-2-13 12:09 | 显示全部楼层
    seesea 发表于 2015-11-17 22:06
    哈哈,好基友,一辈子
    都在啊
    2020-4-7 14:48
  • 签到天数: 954 天
    [LV.10]以坛为家III
    发表于 2016-2-14 21:21 | 显示全部楼层
    昨天不在
    《Color Unit免费申请试用》
    《Color Unit免费申请试用
    编译时空白行出现stray &#
    【原创】 drawbot平面关节
    siri+小爱+小度+天猫控制灯
    siri+小爱+小度+天猫控制
    siri控制8266
    siri控制8266
