查看: 8871|回复: 2
intel Curie/Arduino 101入门开发套件之-TF卡模块读写使用教程1
发表于 2016-6-16 14:17 | 显示全部楼层 |阅读模式
     TF卡读写储存模块是互动媒体设备最常用存储模块,采用SPI接口。模块可以通过杜邦线与Arduino传感器扩展板连接,编写相应的程序可以实现各种传感器(如温湿度传感器、光线传感器,GPS 等等)数据记录等功能,通过读卡器将TF卡数据读出,便可轻松加以分析利用,模块并带有两个LED灯以指示TF卡工作状态。(指示灯说明:1、当接上电源未插卡时,一个LED常亮,表示模块供电正常。2、插入卡后常亮的LED开始闪速,表示TF卡已经插入。3、另一个LED闪烁是表示正在通信。)    在配合Arduino101的使用中接线方式可以与uno相同:
1
CD
用户可用来检测卡是否插入,不使用可不连接(例程中不使用)
2
CS
TF卡片选,例程中需连接到4号脚(在没有使用其他SPI设备时可不连接)
3
MOSI
连接到arduino的MOSI口,在101上为11号引脚
4
MISO
连接到arduino的MISO口,在101上为12号引脚
5
SCK
连接到arduino的SCLK口,在101上为13号引脚
6
VCC
电源供电正端,连接到5V
7
GND
电源供电负端,连接到电源负极,GND
  SD card test
 This example shows how use the utility libraries on which the'
 SD library is based in order to get info about your SD card.
 Very useful for testing a card when you're not sure whether its working or not.
 The circuit:
  * SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
                 Pin 4 used here for consistency with other Arduino examples
 created  28 Mar 2011
 by Limor Fried
 modified 9 Apr 2012
 by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 4;
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
  } else {
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
烧写官方的例程,上传程序后,等待系统启动(大约5s);
打开串口监视器,可以看到Arduino 101返回的信息,此时,如果TF卡里有内容的话,就会返回目录下的文件信息;
需要注意的是,TF或SD卡的文件格式必须为FAT32或FAT16,否则系统无法读取内存卡的信息。
arduino IDE编译ESP8266代码出错
blinker做的卧室灯开关发现一个问题
blinker做的卧室灯开关发
Blinker项目实例:Nodemcu
arduino nano控制舵机
arduino nano控制舵机
