查看: 3459|回复: 13
突然间arduino mini 就下不进程序了
    2017-5-21 20:50
  • 签到天数: 265 天
    发表于 2016-9-19 23:42 | 显示全部楼层 |阅读模式
    forum.php?mod=image&aid=23290&size=300x300&key=19043647f1c6be1d&nocache=yes&type=fixnone.gif 之前还能下的,大概隔了一个月后就不知道为什么下不了了,mini板也换了几块,下载器也换过了,电脑也换过了,就是下不了arduino mini 的程序,用arduino UNO下就没问题,软件版本1.6.2,1.6.9,1.6.11都试过了还是下不了。Arduino:1.6.9 (Windows 7), 开发板:"Arduino Mini, ATmega328"
    D:\arduino-1.6.9\Arduino_program\钃濈墮灏忚溅灞ュ甫鐗圽鏃犳瀬鍙橀?熸澘\wujibiansu\lanya.ino: In function 'void lanya_huoqu()':
    D:\arduino-1.6.9\Arduino_program\钃濈墮灏忚溅灞ュ甫鐗圽鏃犳瀬鍙橀?熸澘\wujibiansu\lanya.ino:8:21: warning: array subscript has type 'char' [-Wchar-subscripts]
    D:\arduino-1.6.9\Arduino_program\钃濈墮灏忚溅灞ュ甫鐗圽鏃犳瀬鍙橀?熸澘\wujibiansu\lanya.ino:14:21: warning: array subscript has type 'char' [-Wchar-subscripts]
    项目使用了 4,664 字节,占用了 (16%) 程序存储空间。最大为 28,672 字节。
    全局变量使用了234字节,(11%)的动态内存,余留1,814字节局部变量。最大为2,048字节。
    D:\arduino-1.6.9\hardware\tools\avr/bin/avrdude -CD:\arduino-1.6.9\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\ADMINI~1.USE\AppData\Local\Temp\build7f01e2bc44ae637a69e2a535bdfc3373.tmp/wujibiansu.ino.hex:i
    avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2009 Joerg Wunsch
             System wide configuration file is "D:\arduino-1.6.9\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM3
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xaa
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaa
    avrdude done.  Thank you.
    上传出错。查看页面 http://www.arduino.cc/en/Guide/Troubleshooting#upload 获取建议。
    在文件 -> 首选项开启
    “编译过程中显示详细输出”选项
    这份报告会包含更多信息。
    2017-3-21 13:10
  • 签到天数: 53 天
    发表于 2016-9-19 23:48 | 显示全部楼层
    mini板,下载器,电脑全部换过都这样吗?  看看是不是要换一个房子,换一个人,找风水大师看看换一个方位之类。
    2017-5-21 20:50
  • 签到天数: 265 天
     楼主| 发表于 2016-9-19 23:54 | 显示全部楼层
    1981818001 发表于 2016-9-19 23:48
    mini板,下载器,电脑全部换过都这样吗?  看看是不是要换一个房子,换一个人,找风水大师看看换一个方位之 ...
    哈哈哈,我也觉得,可惜是学校的实验室换不了
    2019-7-12 18:42
    发表于 2016-9-20 08:48 | 显示全部楼层
    点了下载后,马上手动复位试试
    2017-3-26 11:20
  • 签到天数: 50 天
    发表于 2016-9-20 09:23 | 显示全部楼层
    lz,我是新手一枚,请教你下题外话,
    这个mini就是用usb下载器下载就可以啦?
    一个usb下载器可以对多个mini下载是吗?
    mini的编程和uno差不多吧?除了引脚定义可能不同外……
    很菜的问题。。。。谢谢啦~
    2019-9-17 15:38
  • 签到天数: 169 天
    发表于 2016-9-20 10:05 | 显示全部楼层
    2017-5-21 20:50
  • 签到天数: 265 天
     楼主| 发表于 2016-9-20 10:26 来自手机 | 显示全部楼层
    coloz 发表于 2016-9-20 08:48
    点了下载后,马上手动复位试试
    一直都是在手动复位的,就是这几天下不进去,UNO却没问题,真是怪了
    2017-5-21 20:50
  • 签到天数: 265 天
     楼主| 发表于 2016-9-20 10:28 来自手机 | 显示全部楼层
    mrran 发表于 2016-9-20 09:23
    lz,我是新手一枚,请教你下题外话,
    一个usb下载器可以对多个mini ...
    是的,一个下载器可以通用,接对引脚就行了,记得按复位
    2018-10-15 14:57
  • 签到天数: 39 天
    发表于 2016-9-21 08:41 | 显示全部楼层
    换一个房子,换一个人,找风水大师看看换一个方位之类...
    哈哈,看来这个世界是要换换了!
    说笑的,兄弟,您的情况,我也遇到,近期买的mini片看来是那位大师将程序精简了!
    我是这样处理的:
    当正在编译,并编译刚完成,准备开始上传(即写程序)前1秒钟内,眼明手快,手动按复位键,这样就可以将编译好的程序写进去了,和电脑配置、软件版本没有什么关系的,我的经验希望对您有帮助。
    发表于 2016-9-21 09:43 | 显示全部楼层
    喜欢你的技术贴
    arduino与adafruit motor shield焊接后的问题
    焊接之前测试板子和电机运转正常,焊接完之后连上找不到端口了,用另一块板子测试电脑
    OLED初始化不通过
    OLED初始化不通过
    各位大牛好!!! 做一个arduino指纹密码锁,然后加了键盘,指纹传感器as608,加了个s
    不懂为什么我Arduino不能下载库
    不懂为什么我Arduino不能
    总是这样显示,之前esp8266的也下载不了
    语音识别模块
    语音识别模块
    有没有人会用这种的语音模块,用arduino怎么编程。求教,必有重谢!
