查看: 10881|回复: 18
如何使用ruRisym DS18B20数字温度传感器探头水温探测温线?
发表于 2016-12-14 15:51 | 显示全部楼层 |阅读模式
我想使用一下Risym DS18B20数字温度传感器探头水温探测温线 不锈钢封装防水型 TB2QpKdasCO.eBjSZFzXXaRiVXa_!!738263294.jpg
使用方法和
DS18B20数字温度传感器的代码是一致的吗?我把三个接线柱分别焊接完成后 连接了arduino
代码使用这个帖子的:
http://www.arduino.cn/thread-1345-1-1.html
用第一种的代码方法:一直显示   ("No more addresses.");
代码如下:
[mw_shl_code=c,true]#include <OneWire.h>
OneWire  ds(10);  // 连接arduino10引脚
void setup(void) {
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr, HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  Serial.println();
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS18S20");  // or old DS1820
      type_s = 1;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
    default:
      Serial.println("Device is not a DS18x20 family device.");
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  Serial.print("  Data = ");
  Serial.print(present,HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data = ds.read();
    Serial.print(data, HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  Serial.println();
  // convert the data to actual temperature
  unsigned int raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // count remain gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
  } else {
    byte cfg = (data[4] & 0x60);
    if (cfg == 0x00) raw = raw << 3;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
    // default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
用帖子提到的第二种方法,则提示:temperature for the device 1 (index 0) is:
#include <DallasTemperature.h>
// 定义DS18B20数据口连接arduino的2号IO上
#define ONE_WIRE_BUS 2
// 初始连接在单总线上的单总线设备
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
void setup(void)
  // 设置串口通信波特率
  Serial.println("Dallas Temperature IC Control Library Demo");
  // 初始库
  sensors.begin();
void loop(void)
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures(); // 发送命令获取温度
  Serial.println("DONE");
  Serial.print("Temperature for the device 1 (index 0) is: ");
  Serial.println(sensors.getTempCByIndex(0));
怎么回事???哪里出现的问题?
请指教  谢谢!
 楼主| 发表于 2016-12-14 16:13 | 显示全部楼层
没人理我啊?好伤心 好着急啊。。。
发表于 2016-12-14 17:11 | 显示全部楼层
这个要看传感器的datasheet,
发表于 2016-12-14 17:12 | 显示全部楼层
没有用过  路过
发表于 2016-12-14 17:41 | 显示全部楼层
一个测温代码写的这么麻烦,真是服了。。。。
两线测温头与三线测温头的区别在于:三线测温头自带分压电阻,两线的测温头需要外接分压电阻。
+  -  pwmpin,
analogRead(pwmpin)
然后map调整数值
发表于 2016-12-15 08:50 | 显示全部楼层
这是我前一阵的用的库,调用很简单,你试试
DS18B20_S.rar
2.81 KB, 下载次数: 180
发表于 2016-12-15 11:59 | 显示全部楼层
两线测温头与三线测温头的区别在于:三线测温头自带分压电阻 ...
你说的不是DS18B20这类数字传感器吧
发表于 2016-12-15 14:50 | 显示全部楼层
接线没对,在信号脚加上上拉电阻,你仔细看下提供的连接里面的“接线示意图”就明白了~
 楼主| 发表于 2016-12-19 18:31 | 显示全部楼层
jackten 发表于 2016-12-14 17:11
这个要看传感器的datasheet,
谢谢您的回复!!
 楼主| 发表于 2016-12-19 18:33 | 显示全部楼层
谢谢您的回复!!谢谢您的回复!!
blinker物联网教程——11、自动灌溉
blinker物联网教程——11
【Arduino】168种传感器模块系列实验(43)---单路继电器模块
为什么电平为LOW时LED亮而反之不亮
为什么电平为LOW时LED亮而
如题,刚入门ESP8266,买了个开发板回来感到大惑不解,代码如图 此时板载LED常亮,利用串
想在原有的项目上加上一个呼吸灯怎么做才不影响原程序
想在原有的项目上加上一个
串口分析字符操作符,灵活的实现自动化控制。
串口分析字符操作符,灵活
Arduino String可以分析串口读取的字符是何种操作符,一共十三种: isAlphaNumeric
