三、对照手册,熟悉指令:对照官方给的手册,掌握它的配置指令。输入:CMD+SENSOR_HELP(加回车),串口会返回所以的指令信息,就不需要对指令的死记硬背,指令数据如下============Welcome!!!============MU - An Intelligent Vision Sensor
All Commands:
CMD+SENSOR_SETUP
CMD+SENSOR_HELP
CMD+SENSOR_RESET
CMD+SENSOR_STATUS
CMD+SENSOR_EXIT
CMD+VISION_STATUS=ENABLE or DISABLE
CMD+VISION_TYPE=LINE or BALL or BODY or FACE
CMD+USB_STATUS=ENABLE or DISABLE
CMD+UART_STATUS=ENABLE or DISABLE
CMD+UART_BAUD=1200~576000
CMD+SERVOX_STATUS=ENABLE or DISABLE
CMD+SERVOX_STEP=-100~100 (integer)
CMD+SERVOX_INITANGLE=0~180 (integer)
CMD+SERVOX_REVERSE=ENABLE or DISABLE
CMD+SERVOY_STATUS=ENABLE or DISABLE
CMD+SERVOY_STEP=-100~100 (integer)
CMD+SERVOY_INITANGLE=0~180 (integer)
CMD+SERVOY_REVERSE=ENABLE or DISABLE
Each Command requires "Carriage Return" and "Line Feed" at the end
Each command can be use "?" to return current setting:
CMD+VISION_TYPE=?
Current Vision Type is: BODY
More information can be found at http://www.morpx.com
============Morpx.Inc.============
