楼主: 奈何col
软串口通信——SoftwareSerial库的使用
发表于 2019-5-28 11:34 | 显示全部楼层
  Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo and Micro support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() { // run over and over
  if (mySerial.available()) {
    Serial.print(mySerial.read());
  if (Serial.available()) {
    mySerial.write(Serial.read());
发表于 2019-5-28 11:36 | 显示全部楼层
捣鼓好几天,怎么弄都不行,问题出哪里了,arduino 用的新下载的arduino1.5.4
发表于 2019-5-28 11:37 | 显示全部楼层
希望版主辛苦一下,困扰我好几天了,我用maga2560也测试了一下,也不行
发表于 2019-5-28 11:38 | 显示全部楼层
奈何老师,您还需要什么信息,我再发
发表于 2019-5-28 13:27 | 显示全部楼层
有可能板子坏了
发表于 2019-5-28 13:40 | 显示全部楼层
换了一块板子测试还是不行
发表于 2019-6-19 20:29 | 显示全部楼层
为什么 软串口不要
while (!Serial) {
发表于 2019-6-19 21:32 | 显示全部楼层
硬串对硬串 是不是不行  我的数据都被打成几段了
通常是程序逻辑有问题哦  详情 回复 发表于 2019-6-19 22:09
 楼主| 发表于 2019-6-19 22:09 | 显示全部楼层
通常是程序逻辑有问题哦
发表于 2019-6-21 22:56 | 显示全部楼层
奈何col 发表于 2019-6-19 22:09
通常是程序逻辑有问题哦
328p 获取传感器数据
void loop(void) {
  getSD18B20();
  getDHT11();
  sendmsg=JSON.stringify(datamsg);
//  int bytesSent =
  Serial.write(sendmsg.c_str());
   //Serial.println(bytesSent);
  //Serial.write("sendmsg");
  delay(750);
8266 接受并发送到mqtt
void readstr(){
    while(Serial.available()>0) {
        char inByte =Serial.read();
        //String 拼接char
        _mqttinfo.arduinomsg += inByte;//获取串口接收到的数据
      if(_mqttinfo.arduinomsg.length()>0){
         Serial.println(_mqttinfo.arduinomsg.length());
         Serial.println(_mqttinfo.arduinomsg);
         timeClient.update();
         mqttjson["uptime"]=timeClient.getEpochTime()-60*60*8;
         msg["hsc"] = 2;//12345HTTP Status Code +0 kill
         msg["data"] = _mqttinfo.arduinomsg;
         mqttjson["msg"] = msg;//12345HTTP Status Code +0 kill
         _mqttinfo.jsonString = JSON.stringify(mqttjson);
         client.publish(_mqttinfo.mqttup, _mqttinfo.jsonString); // You can activate the retain flag by setting the third parameter to true
         _mqttinfo.arduinomsg="";
  client.loop();
  readstr();
atmega32u4芯片的主控最多有多少引脚?
atmega32u4芯片的主控最多
想自己diy一个键盘,涉及到的引脚比较多,淘宝找了下没找到相应的主控 需要atmega32u4
Arduino与S7-200 PLC 进行Modbus通信测试
Modbus是一种串行通信协议,Modbus已经成为工业领域通信协议的业界标准,并且现在是工
Arduino Nano V3.0无法烧录问题
在t宝上买的那种改了“USB转TLL”芯片的nano板,上手后无法烧录程序,L灯闪烁(我的UN
请教一个有关NodeMCU和舵机的问题
请教一个有关NodeMCU和舵
[*]问题现象 我尝试使用网页控制NodeMCU引脚的方式来控制舵机。但是在程序烧进去
arduino pid麦克纳姆轮小车程序详解
arduino pid麦克纳姆轮小
