楼主: 单片机菜鸟
《博哥ESP8266系列4》- 局域网:ESP8266+路由+RGB彩灯+App
    2020-2-17 14:41
  • 签到天数: 789 天
    [LV.10]以坛为家III
     楼主| 发表于 2018-3-8 17:05 | 显示全部楼层
    15873889685 发表于 2018-3-8 17:02
    for (i = 0; i < MAX_SRV_CLIENTS; i++){
            if (serverClients && serverClients.connected( ...
    首先数组肯定不能调用方法吧 方法都是针对对象的  serverClients.connected()   serverClients.available()
    2020-2-17 14:41
  • 签到天数: 789 天
    [LV.10]以坛为家III
    后面那几个也加上i
    2020-2-9 17:38
  • 签到天数: 330 天
    发表于 2018-3-8 17:07 | 显示全部楼层
    加了一样不行?
    2020-2-17 14:41
  • 签到天数: 789 天
    [LV.10]以坛为家III
     楼主| 发表于 2018-3-8 17:10 | 显示全部楼层
    加了不行  有提示什么错误吗
    2020-2-9 17:38
  • 签到天数: 330 天
    发表于 2018-3-8 17:11 | 显示全部楼层
    单片机菜鸟 发表于 2018-3-8 17:10
    加了不行  有提示什么错误吗
    Arduino:1.6.5 (Windows 8.1), 板:"NodeMCU 0.9 (ESP-12 Module), 80 MHz, 115200, 4M (3M SPIFFS)"
    sketch_mar08c.ino: In function 'void loop()':
    sketch_mar08c:55: error: request for member 'connected' in 'serverClients', which is of non-class type 'WiFiClient [3]'
    sketch_mar08c:56: error: request for member 'stop' in 'serverClients', which is of non-class type 'WiFiClient [3]'
    sketch_mar08c:56: error: 'ii' was not declared in this scope
    sketch_mar08c:57: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
    In file included from C:\Users\shenghui\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:40:0,
                     from sketch_mar08c.ino:6:
    C:\Users\shenghui\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiServer.h:51:14: error:   initializing argument 1 of 'WiFiClient WiFiServer::available(uint8_t*)' [-fpermissive]
       WiFiClient available(uint8_t* status = NULL);
    sketch_mar08c:62: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
    sketch_mar08c:62: error: variable-sized object 'serverClient' may not be initialized
    sketch_mar08c:64: error: request for member 'stop' in 'serverClient', which is of non-class type 'WiFiClient [(((sizetype)(((ssizetype)i) + -1)) + 1)]'
    sketch_mar08c:69: error: request for member 'connected' in 'serverClients', which is of non-class type 'WiFiClient [3]'
    sketch_mar08c:71: error: request for member 'available' in 'serverClients', which is of non-class type 'WiFiClient [3]'
    sketch_mar08c:72: error: request for member 'available' in 'serverClients', which is of non-class type 'WiFiClient [3]'
    sketch_mar08c:73: error: request for member 'read' in 'serverClients', which is of non-class type 'WiFiClient [3]'
      报告将会包含更多的信息
      "在编译时,输出详细信息"
      在 文件>首选项 中启用
    2020-2-17 14:41
  • 签到天数: 789 天
    [LV.10]以坛为家III
     楼主| 发表于 2018-3-8 17:12 | 显示全部楼层
    你前面那个都改对了  为毛后面那几个改错了    。。。。。。数组啊数组啊  为什么i放到了函数的参数里面去了呢
    2020-2-9 17:38
  • 签到天数: 330 天
    发表于 2018-3-8 17:15 | 显示全部楼层
    单片机菜鸟 发表于 2018-3-8 17:12
    你前面那个都改对了  为毛后面那几个改错了    。。。。。。数组啊数组啊  为什么i放到了函数的参数里面 ...
    啥意思?i我就放在serverClients【i】,serverClients.connected(i),,serverClients.available(i)里面
    2020-2-17 14:41
  • 签到天数: 789 天
    [LV.10]以坛为家III
     楼主| 发表于 2018-3-8 17:16 | 显示全部楼层
    15873889685 发表于 2018-3-8 17:15
    啥意思?i我就放在serverClients【i】,serverClients.connected(i),,serverClients.available(i)里面 ...
    。。。。你先去理解一下什么叫做数组   然后怎么引用数组里面的元素  貌似你弄混了概念
    新手求助,github上一个arduino开源CG重心称的问题
    新手求助,github上一个ar
    在github找到一个开源CG重心称的代码,并按文档说明搭建了硬件环境。发现程序在串口监
    求助为什么下载开发板出错???
    求助为什么下载开发板出错
    网络,网址都没错,为什么下载开发板出错???谢谢
    自制arduino时,usb周围电路搞不懂
    自制arduino时,usb周围电
    最近在画搭载atmega 32u4的arduino 兼容板,参考的arduino micro的设计,但电路知识贫
    关于DS1302.h
    关于DS1302.h
    去年买了个ARDUINO没怎么玩(就是不会玩),然后今天看见了例程中有一个DS1302.h时钟
    小爱控制ws2812,能开灯,调亮度、颜色,就是不能关灯
    小爱控制ws2812,能开灯,
    小爱控制ws2812,能开灯,调亮度、颜色,就是不能关灯,跑的例程不行,改了代码也是不
