查看: 2175|回复: 2
【KittenBot巡线小车试用】固件下载失败及开发环境问题建议
    2020-1-1 21:48
  • 签到天数: 778 天
    [LV.10]以坛为家III
    发表于 2017-9-27 22:10 | 显示全部楼层 |阅读模式
    接上一篇帖子【新提醒】【KittenBot巡线小车试用】上电初体验-Arduino中文社区 - Powered by Discuz! http://www.arduino.cn/thread-49513-1-1.html
    看来必须使用Kittenblock,之前无线模块的拨码拨到了特殊模式,连上usb,蜂蜜器响,选择串口后就选择了,点击arduino,发现返回如下,这时发现小车电源开关没开,无线模块发烫厉害
    开电源开关,蜂蜜器不响了,再烧录,报错,如此3、4次,一直报错,无线模块发烫厉害。且烧录完,串口丢失,难道又要重启软件选择串口?串口输出的信息是什么意思?
    软件报错信息输出如下:
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4c
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4c
    avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4c
    �ϴ������鿴ҳ�� http://www.arduino.cc/en/Guide/Troubleshooting#upload ��ȡ���顣 avrdude done. Thank you.
    打开开关时,就会出现 avrdude done. Thank you.但是还是下载失败啊,整个电脑都累了,其他程序就QQ、浏览器
    虽然该开发环境免安装,但是建议再优化一下,
    1、增加字体大小设置
    2、增加下载进度提示,比如arduino IDE会显示upload ing...
    3、既然Kittenblock本身内置了Arduino 1.68和机器人相关的大多数库,为什么开发环境无法选择源文件或者例程?arduino里面不是有很多example
    同时使用USB电源和电池电源对小车会不会有影响?这时小车开关如果关闭,电池处于充电状态还是?怎么看到电充满了?
    为什么无线模块一接USB电源就发烫厉害
    还有按照你们的例程我没有下载固件成功,小车出厂固件是哪个版本?无线是哪个版本?
    由于我上电前无线拨码置于特殊模式,是不是更新WIFI模块自身的固件?可是我没联网啊,它怎么更新?那现在还是原来的固件?可是和我手机一直没连上
    2020-1-1 21:48
  • 签到天数: 778 天
    [LV.10]以坛为家III
     楼主| 发表于 2017-9-27 22:13 | 显示全部楼层
    状态栏输出的是什么意思?
    M11 F1CBAF6D
    M11 CD219C95
    M11 8DDE337E
    M11 24AE7D4F
    2020-1-1 21:48
  • 签到天数: 778 天
    [LV.10]以坛为家III
     楼主| 发表于 2017-9-27 22:16 | 显示全部楼层
    这下是不是版本输出正常了?可是为什么老输出其他字符呢
    开个帖子,记录我造小车的过程   欢迎大家批评指正
    开个帖子,记录我造小车的
    目的:想做一个可以远程控制的小车车,放在家里在公司都可 以控制的。控制:MEGA2560+
    一个通过串口操作Wemos D1连接无线网的程序
    一个通过串口操作Wemos D1
    [md]# 作案动机 前段时间买了一块Wemos D1的板子,集成了ESP8266,理论上8266能干的它
    arduino的io口损坏,被烧了,如何保护io口?
    arduino的io口损坏,被烧
    先感谢各位大大进来解惑。我用的是WIFIduino,它和arduino是相通的。 因为我自学的各
    【Arduino】168种传感器模块系列实验(158)---QMC5883L三轴罗盘
    8266-12F的接线方法问题
    8266-12F的接线方法问题
    我是新手小白,最近弄了几块ESP-12F的,想通过这个烧写器上传程序,按烧写器的对应针
