查看: 2139|回复: 3
大神们 求解
发表于 2017-10-3 19:48 | 显示全部楼层 |阅读模式
#include "U8glib.h"
#include "ESP8266.h"
#include "I2Cdev.h"
#include <Wire.h>
#include <Rtc_Pcf8563.h>
//#include <AM2321.h>
#include "rtc.h"
#define SSID        "xxxxxx"
#define PASSWORD    "xxxxxx"
#define HOST_NAME   "pool.ntp.org"
#define HOST_PORT   (123)
#define INTERVAL_NET             20000
#define INTERVAL_LCD             200             //定义OLED刷新时间间隔
#define INTERVAL_SENSOR          1000
uint16_t baud_data[5] = {9600, 19200, 38400, 57600, 115200};
//CoreUSB UART Port: [Serial1] [D0,D1]
#if defined(__AVR_ATmega32U4__)
#define EspSerial Serial1
#define UARTSPEED  115200
#endif
//Core+ UART Port: [Serial1] [D2,D3]
#if defined(__AVR_ATmega1284P__) || defined (__AVR_ATmega644P__) || defined(__AVR_ATmega128RFA1__)
#endif
//Core UART Port: [SoftSerial] [D2,D3]
#if defined (__AVR_ATmega168__) || defined (__AVR_ATmega328__) || defined (__AVR_ATmega328P__)
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); /* RX3, TX2 */
#define EspSerial mySerial
#define UARTSPEED  19200
#endif
ESP8266 wifi(&EspSerial);
String wifiSetInfo = "wifi ready...";
unsigned long net_time = millis();
unsigned long lcd_time = millis();                 //OLED刷新时间计时器
uint8_t buffer[128] = {0};
static uint8_t upd_id = 0;
uint32_t len = 0;
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);     //设置OLED型号
//-------字体设置,大、中、小
#define setFont_L u8g.setFont(u8g_font_7x13)
#define setFont_M u8g.setFont(u8g_font_fixed_v0r)
#define setFont_S u8g.setFont(u8g_font_fixed_v0r)
#define setFont_SS u8g.setFont(u8g_font_fub25n)
const unsigned char bmp_logo0[] U8G_PROGMEM =
  0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0xFF, 0x01, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0xFF, 0xFF, 0x01, 0x87, 0x9F, 0x1D, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0xFF, 0xFF, 0xC0, 0x87, 0x0F, 0x7C, 0x00,
  0x00, 0x00, 0x00, 0xF0, 0xFF, 0xFF, 0xFF, 0xC0, 0x03, 0x38, 0xE0, 0x01, 0x00, 0x00, 0x00, 0xF8, 0xFF, 0xFE, 0xFF, 0x00, 0x00, 0x3C, 0xFC, 0xC1, 0x07, 0x00, 0x00, 0xF8, 0xFF, 0xE0, 0x7F, 0x00, 0x00, 0x6F, 0xFF, 0x9F, 0x03, 0x00, 0x1C, 0xF8, 0xFF, 0xE3, 0x7F, 0x00, 0x0E, 0xF7,
  0xFF, 0xFF, 0x1F, 0x06, 0xFF, 0xFF, 0xFF, 0xE7, 0x7F, 0x80, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0x07, 0xFF, 0xFF, 0xFF, 0xEF, 0xFF, 0x81, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F, 0xFF, 0xFF, 0xFF, 0xEF, 0xE7, 0xC1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F, 0xFF, 0xFF, 0xFF, 0xC7, 0xC3, 0xF0,
  0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0B, 0xFF, 0xFF, 0x8F, 0x8F, 0x01, 0xF6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x1E, 0xFF, 0x9F, 0x0F, 0x00, 0xEC, 0xFF, 0xFF, 0xFF, 0xFF, 0x3C, 0x00, 0x07, 0xFE, 0xFF, 0x3F, 0x00, 0xEF, 0xFF, 0xFF, 0xFF, 0xFF, 0x39, 0x00, 0x01, 0xFE, 0xFF, 0x3F,
  0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x19, 0x00, 0x00, 0xFC, 0xFF, 0x7F, 0x00, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0x05, 0x00, 0x00, 0xF8, 0xFF, 0x7F, 0x00, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0x07, 0x00, 0x00, 0xF8, 0xFF, 0x0F, 0x00, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0x03, 0x00, 0x00, 0xF8,
  0xFF, 0x01, 0x00, 0xEE, 0xFF, 0xFF, 0xFF, 0x9F, 0x01, 0x00, 0x00, 0xF8, 0xFF, 0x01, 0x00, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0xE0, 0x7F, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x17, 0x00, 0x00,
  0x00, 0xC0, 0xC7, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0xFF, 0x17, 0x00, 0x00, 0x08, 0xC0, 0xF7, 0x03, 0x80, 0xFF, 0xFF, 0xE7, 0xFF, 0x07, 0x00, 0x00, 0x08, 0x00, 0xBF, 0x07, 0x80, 0xFF, 0xFF, 0xC7, 0xFB, 0x04, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x80, 0xFF, 0xFF, 0xC1, 0xF9, 0x0E,
  0x00, 0x00, 0x00, 0x00, 0xE0, 0x0F, 0x80, 0xFF, 0xFF, 0xC1, 0xF1, 0x0C, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x7F, 0x00, 0xFF, 0xFF, 0x81, 0x39, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x80, 0x7F, 0x00, 0xEE, 0xFF, 0x00, 0xB8, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0x01, 0xE0, 0x7F, 0x00,
  0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0x07, 0xC0, 0x3F, 0x00, 0xE0, 0xF7, 0x0F, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0x07, 0xC0, 0x3F, 0x00, 0xC0, 0xCF, 0x1F, 0x00, 0x00, 0x00, 0x80, 0xFF, 0x07, 0xC0, 0xBF, 0x01, 0x00, 0xFE, 0x17, 0x00, 0x00, 0x00, 0x80, 0xFF, 0x03, 0xC0,
  0xFF, 0x01, 0x00, 0xFC, 0x01, 0x03, 0x00, 0x00, 0x00, 0xFE, 0x03, 0xC0, 0xDF, 0x01, 0x00, 0xFF, 0x63, 0x03, 0x00, 0x00, 0x00, 0xFE, 0x01, 0x80, 0xDF, 0x00, 0x00, 0xFF, 0x67, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x80, 0xDF, 0x00, 0x00, 0xFF, 0x07, 0x00, 0x00, 0x00, 0x00, 0x7F,
  0x00, 0x80, 0x0F, 0x00, 0x00, 0xFF, 0x07, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x00, 0x00, 0x07, 0x00, 0x00, 0xEF, 0x87, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x83, 0x03, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83, 0x03, 0x00, 0x00,
  0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC3, 0x01, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
void setup(void)
  showLogo();
  //while (!Serial); // wait for Leonardo enumeration, others continue immediately
  Serial.print("setup begin\r\n");
  for (int a = 0; a < 5; a++) {
    EspSerial.begin(baud_data[a]);
    while (EspSerial.available() > 0) {
      EspSerial.read();
    wifi.setUart(UARTSPEED, DEFAULT_PATTERN);
  EspSerial.begin(UARTSPEED);
    EspSerial.read();
  Serial.print("FW Version:");
  Serial.println(wifi.getVersion().c_str());
  if (wifi.setOprToStationSoftAP()) {
    Serial.print("to station + softap ok\r\n");
    wifiSetInfo = "softap ok";
    showLogo();
  } else {
    Serial.print("to station + softap err\r\n");
    wifiSetInfo = "softap err";
    showLogo();
  if (wifi.joinAP(SSID, PASSWORD)) {
    Serial.print("Join AP success\r\n");
    Serial.print("IP: ");
    Serial.println(wifi.getLocalIP().c_str());
    wifiSetInfo = "Join AP success";
    showLogo();
  } else {
    Serial.print("Join AP failure\r\n");
    wifiSetInfo = "Join AP failure";
    showLogo();
  if (wifi.enableMUX()) {
    Serial.print("multiple ok\r\n");
  } else {
    Serial.print("multiple err\r\n");
  Serial.print("setup end\r\n");
  wifiSetInfo = "Getting Time...";
  showLogo();
  updateTimeData();
void loop(void)
  if (lcd_time > millis()) lcd_time = millis();
  if (millis() - lcd_time > INTERVAL_LCD) {
    ret = getRtcTimeString();
    //getRTC();
    volcd();                       //调用显示库
    //serialShowDateTime();
void updateTimeData() {
  do {
    delay(200);
    registerUDPAndSendRecvData();
    if (len > 0) {
      getTimeStampAndSetRTC();
      unregisterUDP();
    } else {
      unregisterUDP();
  } while (!len);
void registerUDPAndSendRecvData() {
  if (wifi.registerUDP(upd_id, HOST_NAME, HOST_PORT)) {
    Serial.print("register udp ");
    Serial.print(upd_id);
    Serial.println(" ok");
  } else {
    Serial.println(" err");
  static const char PROGMEM
  timeReqA[] = { 227,  0,  6, 236 }, timeReqB[] = {  49, 78, 49,  52 };
  // Assemble and issue request packet
  uint8_t       buf[48];
  memset(buf, 0, sizeof(buf));
  memcpy_P( buf    , timeReqA, sizeof(timeReqA));
  memcpy_P(&buf[12], timeReqB, sizeof(timeReqB));
  wifi.send(upd_id, (const uint8_t*)buf, 48);
  //uint32_t len = wifi.recv(upd_id, buffer, sizeof(buffer), 10000);
void getTimeStampAndSetRTC() {
  Serial.print("Received:[");
  unsigned long t = (((unsigned long)buffer[40] << 24) |
                     ((unsigned long)buffer[41] << 16) |
                     ((unsigned long)buffer[42] <<  8) |
                     (unsigned long)buffer[43]) - 2208988800UL;
  Serial.print("Unix timestamp:");
  Serial.print(t);
  Serial.print("]\r\n");
  getDateStamp(t);
  setRTC();
void unregisterUDP() {
  if (wifi.unregisterUDP(upd_id)) {
    Serial.print("unregister udp ");
  } else {
//显示函数
void volcd() {
  //pkj-=4;
  u8g.firstPage();
  do {
    setFont_L;
    u8g.setPrintPos(4, 16);
    u8g.print(rtc.formatDate());
    u8g.print("    ");
    switch (rtc.getWeekday()) {
      case 1:
        u8g.print("Mon");
      case 2:
        u8g.print("Tue");
      case 3:
        u8g.print("Wed");
      case 4:
        u8g.print("Thu");
      case 5:
        u8g.print("Fri");
      case 6:
        u8g.print("Sat");
      //case 7:
      case 0:
        u8g.print("Sun");
    setFont_SS;
    //u8g.setPrintPos(18, 49);
    u8g.setPrintPos(18, 60);
    //u8g.print(rtc.getHour());
    if (rtc.getHour() < 10)
      u8g.print("0");
    //u8g.setPrintPos(55, 46);
    u8g.setPrintPos(55, 55);
    if (rtc.getSecond() % 2 == 0)
      u8g.print(":");
      u8g.print(" ");
    //u8g.setPrintPos(68, 48);
    u8g.setPrintPos(68, 60);
    if (rtc.getMinute() < 10)
      u8g.print("0");
      u8g.print(rtc.getMinute());
  while ( u8g.nextPage() );
void showLogo() {
  u8g.firstPage();
  do {
    u8g.setDefaultForegroundColor();
    u8g.drawXBMP( 10, 1, 92, 46, bmp_logo0);
    setFont_L;
    u8g.setPrintPos(10, 60);
    //u8g.print("wifi ready...");
    u8g.print(wifiSetInfo);
Warning: Board Microduino:avr:mddevice doesn't define a 'build.board' preference. Auto-set to: AVR_MDDEVICE
C:\Users\闊╁崥\Desktop\mdxly\Microduino-IDE\examples\00.mCookie\_301_mWatch_WiFi\_301_mWatch_WiFi.ino:1:20: fatal error: U8glib.h: No such file or directory
compilation terminated.
exit status 1
为什么啊  这是实例里面的  求解  谢谢
    2018-10-24 17:42
  • 签到天数: 15 天
    发表于 2017-10-3 20:13 | 显示全部楼层
    没有找到U8glib库
    发表于 2017-10-4 11:37 | 显示全部楼层
    没有U8GLIB
    2019-1-20 16:41
  • 签到天数: 56 天
    发表于 2017-10-4 23:52 | 显示全部楼层
    用最新的IDE 1.8.4可以解决问题,mdxly内含Microduino-IDE的库文件不全。
    KittenBot杯第六届开源硬件开发大赛启动啦
    KittenBot杯第六届开源硬
    Blinker 模拟传感器+数字
    一文教你选择Arduino开发板,小白进
    一文教你选择Arduino开发
    [发布帖]RPG游戏 无人世界
    [发布帖]RPG游戏 无人世界
    【人脸识别】ESP-EYE 最新的板子到货了
    【人脸识别】ESP-EYE 最新
