查看: 7207|回复: 21
【Z】
发表于 2014-8-9 10:19 | 显示全部楼层 |阅读模式
111
 楼主| 发表于 2014-8-9 11:03 | 显示全部楼层
图片集:
 楼主| 发表于 2014-8-9 10:57 | 显示全部楼层
以下是各个部分的程序内容~
无线传感网络终端Yeelink联网部分
[mw_shl_code=c,true]#include <Wire.h>
#include <Ethernet.h>
#include <WiFi.h>
#include <SPI.h>
#include <yl_data_point.h>
#include <yl_device.h>
#include <yl_w5100_client.h>
#include <yl_wifi_client.h>
#include <yl_messenger.h>
#include <yl_sensor.h>
#include <yl_value_data_point.h>
yl_device ardu(11260);
yl_sensor therm(18633, &ardu);
yl_sensor pr(18635, &ardu);
yl_sensor d(18637, &ardu);
//replace first param value with ur u-apikey
yl_w5100_client client;
yl_messenger messenger(&client, "ed27f020ba253e9af28fea516a1b1056", "api.yeelink.net");   //此处替换为你自己的API KEY
#define BMP085_ADDRESS 0x77  // I2C address of BMP085
const unsigned char OSS = 0;  // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
short temperature;
long pressure;
  Wire.begin();
  bmp085Calibration();
  byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAA};
  Ethernet.begin(mac);
  int val;
  val=analogRead(0);
  temperature = bmp085GetTemperature(bmp085ReadUT());
  pressure = bmp085GetPressure(bmp085ReadUP());
  Serial.print(11);
  Serial.print(",");
  Serial.print(temperature);
  Serial.print(",");
  Serial.print(pressure/10);
  yl_value_data_point d1(temperature*0.1);
  therm.single_post(messenger, d1);
  yl_value_data_point d2(pressure/10);
  pr.single_post(messenger, d2);
  yl_value_data_point d3(val/10);
  d.single_post(messenger, d3);
  delay(2000);
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
  ac1 = bmp085ReadInt(0xAA);
  ac2 = bmp085ReadInt(0xAC);
  ac3 = bmp085ReadInt(0xAE);
  ac4 = bmp085ReadInt(0xB0);
  ac5 = bmp085ReadInt(0xB2);
  ac6 = bmp085ReadInt(0xB4);
  b1 = bmp085ReadInt(0xB6);
  b2 = bmp085ReadInt(0xB8);
  mb = bmp085ReadInt(0xBA);
  mc = bmp085ReadInt(0xBC);
  md = bmp085ReadInt(0xBE);
// Calculate temperature given ut.
// Value returned will be in units of 0.1 deg C
short bmp085GetTemperature(unsigned int ut)
  long x1, x2;
  x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
  x2 = ((long)mc << 11)/(x1 + md);
  b5 = x1 + x2;
  return ((b5 + 8)>>4);
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up)
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // Calculate B3
  x1 = (b2 * (b6 * b6)>>12)>>11;
  x2 = (ac2 * b6)>>11;
  x3 = x1 + x2;
  b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  // Calculate B4
  x1 = (ac3 * b6)>>13;
  x2 = (b1 * ((b6 * b6)>>12))>>16;
  x3 = ((x1 + x2) + 2)>>2;
  b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  if (b7 < 0x80000000)
    p = (b7<<1)/b4;
    p = (b7/b4)<<1;
  x1 = (p>>8) * (p>>8);
  x1 = (x1 * 3038)>>16;
  x2 = (-7357 * p)>>16;
  p += (x1 + x2 + 3791)>>4;
  return p;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
  unsigned char data;
  Wire.beginTransmission(BMP085_ADDRESS);
  Wire.write(address);
  Wire.endTransmission();
  Wire.requestFrom(BMP085_ADDRESS, 1);
  while(!Wire.available())
  return Wire.read();
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
  unsigned char msb, lsb;
  Wire.requestFrom(BMP085_ADDRESS, 2);
  while(Wire.available()<2)
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb<<8 | lsb;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT()
  unsigned int ut;
  // Write 0x2E into Register 0xF4
  // This requests a temperature reading
  Wire.write(0xF4);
  Wire.write(0x2E);
  // Wait at least 4.5ms
  delay(5);
  // Read two bytes from registers 0xF6 and 0xF7
  ut = bmp085ReadInt(0xF6);
  return ut;
// Read the uncompensated pressure value
unsigned long bmp085ReadUP()
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  // Write 0x34+(OSS<<6) into register 0xF4
  // Request a pressure reading w/ oversampling setting
  Wire.write(0xF4);
  Wire.write(0x34 + (OSS<<6));
  // Wait for conversion, delay time dependent on OSS
  delay(2 + (3<<OSS));
  // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  Wire.write(0xF6);
  Wire.requestFrom(BMP085_ADDRESS, 3);
  // Wait for data to become available
  while(Wire.available() < 3)
  msb = Wire.read();
  lsb = Wire.read();
  xlsb = Wire.read();
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  return up;
[/mw_shl_code]
无线传感网络TFT监视终端部分
[mw_shl_code=c,true]#include <ITDB02_Graph16.h>
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
ITDB02 myGLCD(38,39,40,41);
int r;
int g;
int b;
String comdata = "";
int numdata[3] = {0}, mark = 0;
  Serial3.begin(9600);
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
    myGLCD.print("MegaLink Terminal", 0, 0);
    myGLCD.setColor(0, 0, 255);
    myGLCD.print("Normal operation", 0,220);
    myGLCD.setColor(255, 255, 255);
    myGLCD.print("T1:       D1:", 0,40);
    myGLCD.print("T2:       D2:", 0,80);
    myGLCD.print("T3:       D3:", 0,120);
    myGLCD.print("TM:       AT:", 0,160);
    //myGLCD.setFont(SevenSegNumFont);
    myGLCD.setColor(0, 255, 0);
    int a=0;
    myGLCD.printNumI(a, 50, 40);
    myGLCD.printNumI(a, 50, 80);
    myGLCD.printNumI(a, 50, 120);
    myGLCD.printNumI(a, 50, 160);
    myGLCD.printNumI(a, 210, 40);
    myGLCD.printNumI(a, 210, 80);
    myGLCD.printNumI(a, 210, 120);
    myGLCD.printNumI(a, 210, 160);
if (Serial3.available())
    while(Serial3.available())
      SerialReadVal(3);
void SerialReadVal(unsigned int comdata_digit)
  String comdata = "";  //串口字符串传递变量
  char comdata_mark = ','; //字符串分段标志,可更改
  int comdata_mark_count = 0; //分段标志数量
  unsigned int comdata_mark_list[63]; //分段标志位置列表,最大63+1段,此三项可视实际情况增减
  unsigned int comdata_val_long[64]; //每段字串长度列表,最大64段
  String comdata_val[64]; //分段字符串列表,最大64段数据,此数组可在程序开始定义为全局变量,用于返回数据,数据可继续进行深加工
  //读入串口数据并赋值给传递变量
  while (Serial3.available() > 0)
    comdata += char(Serial3.read());
    delay(2);
  Serial.println(comdata);
  //确定分段标志位置,并判断输入段数是否符合给定值
  for (int i = 0; i < comdata.length(); i++)
    if (comdata.charAt(i) == comdata_mark)
      comdata_mark_list[comdata_mark_count] = i;
      comdata_mark_count++;
  for (int i = 0; i <= comdata_mark_count; i++)
    if (i == 0) comdata_val_long[0] = comdata_mark_list[0];
    else if (i == comdata_mark_count) comdata_val_long = comdata.length() - comdata_mark_list[i-1] - 1;
    else comdata_val_long = comdata_mark_list - comdata_mark_list[i-1] - 1;
  if (comdata_mark_count < (comdata_digit - 1)) return;
  //按给定的段数分段
  for (int i = 0; i < comdata_digit; i++)
    if (i == 0)
      for (int ii = 0; ii < comdata_val_long[0]; ii++) comdata_val += comdata.charAt(ii);
      for (int ii = 0; ii < comdata_val_long; ii++) comdata_val += comdata.charAt(comdata_mark_list[i-1]+1+ii);
  for (int i = 0; i < comdata_digit; i++); //Serial.println(comdata_val); // 串口监视程序运行
  b=comdata_val[2].toInt() ;
  g=comdata_val[1].toInt() ;
  r=comdata_val[0].toInt() ;
  show(r,g,b);
void show(int r,int g,int b){
  if(r==10){
    myGLCD.print("    ", 50, 40);
    myGLCD.print("    ", 210, 40);
    myGLCD.printNumI(b, 50, 40);
    myGLCD.printNumI(g, 210, 40);
  if(r==12){
    myGLCD.print("    ", 50, 80);
    myGLCD.print("    ", 210, 80);
    myGLCD.printNumI(b, 50, 80);
    myGLCD.printNumI(g, 210, 80);
  if(r==13){
    myGLCD.print("    ", 50, 120);
    myGLCD.print("    ", 210, 120);
    myGLCD.printNumI(b, 50, 120);
    myGLCD.printNumI(g, 210, 120);
  if(r==11){
    myGLCD.print("    ", 50, 160);
    myGLCD.print("    ", 210, 160);
    myGLCD.printNumI(g/10, 50, 160);
    myGLCD.printNumI(b, 210, 160);
中转器部分
[mw_shl_code=c,true]#include <dht11.h>
#include <ZigduinoRadio.h>
dht11 DHT11;
#define DHT11PIN 7 //DHT11 PIN 3 连接UNO 3
  Serial1.begin(9600);
  ZigduinoRadio.begin(11);
  if (ZigduinoRadio.available())
    while(ZigduinoRadio.available())
    Serial1.write((int)ZigduinoRadio.read());
    int i;
    DHT11.read(DHT11PIN);
    Serial1.print("12,");
    Serial1.print((float)DHT11.humidity, 0);
    Serial1.print(",");
    Serial1.print((float)DHT11.temperature-2, 0);
[/mw_shl_code]
节点部分
dht11 DHT11;
char* itostr(char *str, int i)
    sprintf(str, "%d", i);
    return str;
   ZigduinoRadio.beginTransmission();
    ZigduinoRadio.write("13,");
    int a=(float)DHT11.humidity;
    int b=(float)DHT11.temperature-2;
    Serial.println(a);
    Serial.println(b);
    char c[10],d[10];
    itostr(c,a);
    itostr(d,b);
    ZigduinoRadio.write(c);
    ZigduinoRadio.write(",");
    ZigduinoRadio.write(d);
   ZigduinoRadio.endTransmission();
  delay(3000);
[/mw_shl_code]
调试部分
[mw_shl_code=c,true]/*
翻译:swim
时间:2013年5月27日
发表地址:www.geek-workshop.com
程序说明:无线串口通信
//初始化Zigbee,定义通道
//这两个函数是检测数据是否成功发送
  ZigduinoRadio.attachError(errHandle);
  ZigduinoRadio.attachTxDone(onXmitDone);
//串口接收到数据,通过Zigbee发送;Zigbee接收到数据,通过串口打出
  if (Serial1.available())
    while(Serial1.available())
      char c = Serial1.read();
    Serial.println();
    Serial.print("LQI: ");
    Serial.print(ZigduinoRadio.getLqi(), 10);
    Serial.print(", RSSI: ");
    Serial.print(ZigduinoRadio.getLastRssi(), 10);
    Serial.print(" dBm, ED: ");
    Serial.print(ZigduinoRadio.getLastEd(), 10);
    Serial.println("dBm");
void errHandle(radio_error_t err)
  Serial.println();
  Serial.print("Error: ");
  Serial.print((uint8_t)err, 10);
  Serial.println();
void onXmitDone(radio_tx_done_t x)
  Serial.println();
  Serial.print("TxDone: ");
  Serial.print((uint8_t)x, 10);
  Serial.println();
[/mw_shl_code]
发表于 2014-8-9 11:09 | 显示全部楼层
深深被楼主的豪气震伤
评分
参与人数 1金币 +9 收起 理由
Zzz + 9 这样我都不加钱太不厚道~
查看全部评分
发表于 2014-8-9 11:13 | 显示全部楼层
楼主还有几条大腿?
我想抱一条
深深被大神所折服啊~
Zzz
奔跑大神别黑我........  发表于 2014-8-9 11:16
发表于 2014-8-9 18:22 | 显示全部楼层
{:soso_e179:}大腿求抱
发表于 2014-8-10 00:13 | 显示全部楼层
厉害啊z神~被深深地折服了~
发表于 2014-8-10 21:37 | 显示全部楼层
被z折服了~祝成功,z神
评分
参与人数 1贡献 +3 收起 理由
Zzz + 3
查看全部评分
arduinoT12焊台 控制器 炫酷UI
arduinoT12焊台 控制器 炫
Arduino引脚图
Arduino引脚图
Arduino物联网开发实例教程
Arduino物联网开发实例教
