查看: 1820|回复: 1
UNO开发板+WiFi拓展板实现AT指令转发控制
    2017-12-28 11:54
  • 签到天数: 5 天
    发表于 2017-12-13 14:44 | 显示全部楼层 |阅读模式
    1)物料准备
    Arduino UNO R3开发板1块  + USB方口线1根
    Doit WiFi拓展板1块
    公-母杜邦线2根
    2)程序烧录
    ① Doit WiFi拓展板烧录AT固件;
    ② 将UNO开发板用USB方口线连上电脑,打开Arduino IDE,将程序烧录到UNO开发板上;
    #include <SoftwareSerial.h>
    //本程序通过再UNO开发板上构造一个软串口(GPIO 10---RX,  GPIO 11—TX),
    //通过程序实现软串口与硬串口(gpio0-RX,gpio1-TX)即USB接口的数据透传转发功能
    //由于WiFi拓展板的串口用杜邦线与UNO开发板的软串口用杜邦线对接,所以实现了两个开发
    //板的硬串口(在同等电平幅值下)通过软串口作为中转的透传转发功能。
    #define MAX_PACKETSIZE 128
    SoftwareSerial softSerial(10, 11); // RX, TX
    void doSerialTick()
      //uartdata
      static uint8_t buffSerial[MAX_PACKETSIZE];
      static unsigned int buffSerialIndex = 0;
      static unsigned long preSerialTime = millis();
      uint8_t t = 0;
      if (Serial.available()>0)
        t = Serial.read();
        buffSerial[buffSerialIndex++] =t ;
        if(buffSerialIndex>=MAX_PACKETSIZE - 1){
          buffSerialIndex = MAX_PACKETSIZE-2;
          preSerialTime = preSerialTime - 100;
      if(buffSerialIndex > 0 && (millis() - preSerialTime >= 50 || t=='\n'))
      {//data ready
        buffSerial[buffSerialIndex]=0x00;
        Serial.flush();
        softSerial.write(buffSerial,buffSerialIndex);
    void dosoftSerialTick()
      //uartdata
      static uint8_t buffsoftSerial[ MAX_PACKETSIZE ];
      static unsigned int buffsoftSerialIndex = 0;
      static unsigned long presoftSerialTime = millis();
      uint8_t t = 0;
      if (softSerial.available() >0 )
        t = softSerial.read();
        buffsoftSerial[buffsoftSerialIndex++] = t ;
        if(buffsoftSerialIndex >= MAX_PACKETSIZE - 1){
          buffsoftSerialIndex = MAX_PACKETSIZE-2;
          presoftSerialTime = presoftSerialTime - 100;
      if(buffsoftSerialIndex > 0 && (millis() - presoftSerialTime >= 50 || t =='\n'))
      {//data ready
        buffsoftSerial[buffsoftSerialIndex]=0x00;
        // softSerial.flush();
        Serial.write(buffsoftSerial,buffsoftSerialIndex);
      // Open serial communications and wait for port to open:
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      Serial.println("start");
      // set the data rate for the SoftwareSerial port
      softSerial.begin(115200);
      softSerial.println("AT+UART_DEF=9600,8,1,0,0");
      softSerial.begin(9600);
    void loop() { // run over and over
      doSerialTick();
      dosoftSerialTick();
    3)硬件连接
    再将Doit WiFi拓展板直插到UNO板上,在Doit WiFi拓展板上用杜邦线按以下规则连接:
    Doit WiFi拓展板的Arduino部分   ----------------------   Doit WiFi拓展板的ESP13部分
    GPIO11          --------------------------------------------       RX0
    GPIO10          --------------------------------------------       TX0
    具体连接如图:
    然后将Doit WiFi拓展板右上角的两个开关拨到“OFF”端;
    打开电脑的串口助手,选择对应端口号,
    波特率设置为115200;勾上“发送换行”;
    4)上电调试
    在串口工具的输入窗口中,输入AT+RST,然后点击发送;观察串口接收窗口返回的信息;
    例如:
    发送复位命令:AT+RST(执行指令)
    指令:AT
    响应:OK
    指令:AT+RST
    响应:ready
    现象如下:
    其他指令同理操作即可;
    发表于 2018-2-5 09:12 | 显示全部楼层
    能具体一点吗,我的wifi模块连不到别的热点,发出的热点别人页连不了,是我配置的有问题吗,还是模块是坏的?求解答
    一文教你选择Arduino开发板,小白进
    一文教你选择Arduino开发
    Arduino官方开发板购买
    Arduino官方开发板购买
    ESP8266-01用Arduino烧写应该选择那一项??
    ESP8266-01用Arduino烧写应该选择那一项??还有我用的 是usb串口板340
    酒精传感与超声波传感的使用
    酒精传感与超声波传感的使
    打算超声波传感检测到距离大于10之后就开始酒精浓度检测 下面是代码 mixly提示testArd
    基于Rosbot的声控小夜灯
    基于Rosbot的声控小夜灯
    参赛项目:基于Rosbot的声控小夜灯 参赛组员: 我自己。某单位在职员工,参与单位
