激光模块,不会用
淘宝的
没有库函数,
又看不懂示范程序
ToF 激光测距传感器模块 TOF05140 5-140cm 距离传感器 串口输出-淘宝网  562663732336&_u=dd351qr4ceb
#include <avr/io.h>
#include <avr/interrupt.h>
char Res;
char usart_rxcmd_flag;
char USART_RX_BUF[16];
char usart_rxcmd_cnt;
char usart_rx_timeout;
unsigned char dcalib_flag=0;
unsigned short lenth_buf[10];
unsigned short lenth_cnt=0;
unsigned short lenth,avelenth;
unsigned char calib_cnt;
unsigned char ok_flag;
unsigned char fail_flag;
int serial_putc( char c, struct __file * )
  Serial.write( c );
  return c;
void printf_begin(void)
  fdevopen( &serial_putc, 0 );
void CalAveLenth(void)
  unsigned char i;
  unsigned short sum,max,min;
  max=0;
  min=9999;
  sum=0;
  for(i=0;i<10;i++)
    if(lenth_buf[i]>max)
      max=lenth_buf[i];
    else if(lenth_buf[i]<min)
      min=lenth_buf[i];
    sum+=lenth_buf[i];
  if((max-min)>10)
    if(lenth_cnt>0)
      avelenth=lenth_buf[lenth_cnt-1] ;
      avelenth=lenth_buf[9] ;
    avelenth=(sum-max-min)/8 ;
void CalDisplay_Length(void)
  unsigned char i,j;
  unsigned short tmp;
  unsigned char dispbuf[16]={"L=              "};
  for(i=0;i<16;i++)
    dispbuf[i+2]=USART_RX_BUF[i];
    if(USART_RX_BUF[i]=='m')
      if(USART_RX_BUF[i+1]=='m')
        dispbuf[i+3]=USART_RX_BUF[i];
        dispbuf[i+4]=0;
        dispbuf[i+5]=0;
        dispbuf[i+6]=0;
        if(i>0)
          tmp=USART_RX_BUF[i-1]-0x30;
        if(i>1)
          tmp+=(USART_RX_BUF[i-2]-0x30)*10;
        if(i>2)
          tmp+=(USART_RX_BUF[i-3]-0x30)*100;
        if(i>3)
          tmp+=(USART_RX_BUF[i-4]-0x30)*1000;
        lenth=tmp;
        lenth_buf[lenth_cnt]=tmp;
        lenth_cnt++;
        if(lenth_cnt>=10)
          lenth_cnt=0;
  if(dcalib_flag==0)
    CalAveLenth();
    if(avelenth>=1000)
      dispbuf[2]=avelenth/1000+0x30;
      dispbuf[3]=avelenth/100%10+0x30;
      dispbuf[4]=avelenth/10%10+0x30;
      dispbuf[5]=avelenth%10+0x30;
      dispbuf[6]='m';
      dispbuf[7]='m';
    else if(avelenth>=100)
      dispbuf[2]=avelenth/100%10+0x30;
      dispbuf[3]=avelenth/10%10+0x30;
      dispbuf[4]=avelenth%10+0x30;
      dispbuf[5]='m';
      dispbuf[6]='m';
      dispbuf[7]=0x00;
    else if(avelenth>=10)
      dispbuf[2]=avelenth/10%10+0x30;
      dispbuf[3]=avelenth%10+0x30;
      dispbuf[4]='m';
      dispbuf[5]='m';
      dispbuf[6]=0x00;
      dispbuf[7]=0x00;
      dispbuf[2]=avelenth%10+0x30;
      dispbuf[3]='m';
      dispbuf[4]='m';
      dispbuf[5]=0x00;
      dispbuf[6]=0x00;
      dispbuf[7]=0x00;
    printf(" **Get Length** ");
    printf("%s\n",dispbuf);
  for(i=0;i<16;i++)
    USART_RX_BUF[i]=0;
    dispbuf[i+2]=0;
ISR(TIMER1_COMPA_vect)
   digitalWrite(7, !digitalRead(7));
  if(usart_rx_timeout>0)
    usart_rx_timeout--;
    if(usart_rx_timeout==0)
      if((USART_RX_BUF[0]=='o')&&(USART_RX_BUF[0]=='k'))
        ok_flag=1;
        fail_flag=0;
        digitalWrite(6,LOW);
      else if((USART_RX_BUF[0]=='f')&&(USART_RX_BUF[0]=='a')&&(USART_RX_BUF[0]=='i')&&(USART_RX_BUF[0]=='l'))
        ok_flag=0;
        fail_flag=1;
        usart_rxcmd_flag=1;
        usart_rxcmd_cnt=0;
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  digitalWrite(6,HIGH);
  digitalWrite(7,HIGH);
  Serial.begin(9600,SERIAL_8N1);
  printf_begin();
  printf("start\n\r");
  // 初始化timer1
  cli();          // 进制全局中断
  TCCR1A = 0;     //设置TCCR1A全为0
  TCCR1B = 0;     // [size=1em]设置TCCR1B全为0
  //设置比较的值得大小
  OCR1A = 15;
  // 开启CTC模式
  TCCR1B |= (1 << WGM12);
  // 设置 CS10和CS12位
  TCCR1B |= (1 << CS10);
  TCCR1B |= (1 << CS12);
  // 允许比较中断
  TIMSK1 |= (1 << OCIE1A);
  sei();          // 允许全局中断
  digitalWrite(12,LOW);
  digitalWrite(13,LOW);
  while(Serial.available()>0){
    Res =Serial.read();
    if(usart_rxcmd_flag==0)
      USART_RX_BUF[usart_rxcmd_cnt]=Res;
      usart_rx_timeout=5;
      usart_rxcmd_cnt++;
      if(usart_rxcmd_cnt>(16-1))
        usart_rxcmd_cnt=0;
  if(usart_rxcmd_flag==1)
    CalDisplay_Length();
    usart_rxcmd_flag=0;
能不能教我,能不能给我库函数
问卖家啊,或者看看主芯片是什么网上搜一下
弄好了没有?
我之前做过,加QQ详聊3455482668
还没有弄好,想用在避障小车上
不知道怎样和避障小车的程序合并
程序也看不明白,店家说很简单,但是好像程序这么复杂,那我怎么把程序结合到我的避障小车程序中去?
能不能帮我把“L”提取出来,然后:
if(L>40)
digitalwrite(13,HIGH);
digitalwrite(13,LOW);
