    2018-2-2 17:05
  • 签到天数: 26 天
    以下是我的程序
    1. #include <OneWire.h>
    2. #include <DallasTemperature.h>
    3. // 定义DS18B20数据口连接arduino的2号IO上
    4. #define ONE_WIRE_BUS 2
    5. // 初始连接在单总线上的单总线设备
    6. OneWire oneWire(ONE_WIRE_BUS);
    7. DallasTemperature sensors(&oneWire);
    8. void setup(void)
    9. {
    10.   // 设置串口通信波特率
    11.   Serial.begin(9600);
    12.   Serial.println("Dallas Temperature IC Control Library Demo");
    13.   // 初始库
    14.   sensors.begin();
    15. }
    16. void loop(void)
    17. {
    18.   Serial.print("Requesting temperatures...");
    19.   sensors.requestTemperatures(); // 发送命令获取温度
    20.   Serial.println("DONE");
    21.
    22.   Serial.print("Temperature for the device 1 (index 0) is: ");
    23.   Serial.println(sensors.getTempCByIndex(0));
    24. }
    但是编译错误
    Arduino:1.8.5 (Windows 10), 开发板:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    E:\mBlock\arduino\arduino-builder -dump-prefs -logger=machine -hardware E:\mBlock\arduino\hardware -tools E:\mBlock\arduino\tools-builder -tools E:\mBlock\arduino\hardware\tools\avr -built-in-libraries E:\mBlock\arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10805 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_626187 -warnings=default -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_909734 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=E:\mBlock\arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\mBlock\arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=E:\mBlock\arduino\hardware\tools\avr -verbose C:\Users\user\Desktop\sketch_mar13a\sketch_mar13a.ino
    E:\mBlock\arduino\arduino-builder -compile -logger=machine -hardware E:\mBlock\arduino\hardware -tools E:\mBlock\arduino\tools-builder -tools E:\mBlock\arduino\hardware\tools\avr -built-in-libraries E:\mBlock\arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10805 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_626187 -warnings=default -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_909734 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=E:\mBlock\arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\mBlock\arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=E:\mBlock\arduino\hardware\tools\avr -verbose C:\Users\user\Desktop\sketch_mar13a\sketch_mar13a.ino
    Using board 'mega' from platform in folder: E:\mBlock\arduino\hardware\arduino\avr
    Using core 'arduino' from platform in folder: E:\mBlock\arduino\hardware\arduino\avr
    Detecting libraries used...
    "E:\mBlock\arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IE:\mBlock\arduino\hardware\arduino\avr\cores\arduino" "-IE:\mBlock\arduino\hardware\arduino\avr\variants\mega" "C:\Users\user\AppData\Local\Temp\arduino_build_626187\sketch\sketch_mar13a.ino.cpp" -o "nul"
    "E:\mBlock\arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IE:\mBlock\arduino\hardware\arduino\avr\cores\arduino" "-IE:\mBlock\arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\user\Documents\Arduino\libraries\OneWire" "C:\Users\user\AppData\Local\Temp\arduino_build_626187\sketch\sketch_mar13a.ino.cpp" -o "nul"
    "E:\mBlock\arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IE:\mBlock\arduino\hardware\arduino\avr\cores\arduino" "-IE:\mBlock\arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\user\Documents\Arduino\libraries\OneWire" "-IC:\Users\user\Documents\Arduino\libraries\DallasTemperature" "C:\Users\user\AppData\Local\Temp\arduino_build_626187\sketch\sketch_mar13a.ino.cpp" -o "nul"
    "E:\mBlock\arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IE:\mBlock\arduino\hardware\arduino\avr\cores\arduino" "-IE:\mBlock\arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\user\Documents\Arduino\libraries\OneWire" "-IC:\Users\user\Documents\Arduino\libraries\DallasTemperature" "C:\Users\user\Documents\Arduino\libraries\OneWire\OneWire.cpp" -o "nul"
    "E:\mBlock\arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IE:\mBlock\arduino\hardware\arduino\avr\cores\arduino" "-IE:\mBlock\arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\user\Documents\Arduino\libraries\OneWire" "-IC:\Users\user\Documents\Arduino\libraries\DallasTemperature" "C:\Users\user\Documents\Arduino\libraries\OneWire\OneWire.cpp" -o "C:\Users\user\AppData\Local\Temp\arduino_build_626187\preproc\ctags_target_for_gcc_minus_e.cpp"
    C:\Users\user\Documents\Arduino\libraries\OneWire\OneWire.cpp:85:24: fatal error: WConstants.h: No such file or directory
    #include "WConstants.h"
    compilation terminated.
    使用库 OneWire 在文件夹: C:\Users\user\Documents\Arduino\libraries\OneWire (legacy)
    使用库 DallasTemperature 在文件夹: C:\Users\user\Documents\Arduino\libraries\DallasTemperature (legacy)
    exit status 1
    为开发板 Arduino/Genuino Mega or Mega 2560 编译时出错。
    粗略看一下,大概是因为这个
    但是怎么解决
    我的问题解决了,谢谢,大概的方法就是更新一下库函数。在项目>管理库里面更新一下,找到新的下载。
    请看http://www.sizhlro2018.com/forum ... ;tid=112&extra=
    在项目>库函数里面找最新版本的OneWire就可以了
