查看: 3548|回复: 6
[已解决] 通过udp通信通过WiFi将两个WiFi shield实现通信,收发一个字.....
    2016-12-21 15:41
  • 签到天数: 6 天
    发表于 2014-10-25 10:00 | 显示全部楼层 |阅读模式
    将两块arduino安上wifi shield,一块作为发送端,发送一个字符‘A’,通过WiFi发送,另一块作为接收端收到这个字符。求发送和接受这个‘A’的核心程序,谢谢大家,急用。
    2019-7-12 18:42
    发表于 2014-10-25 10:09 | 显示全部楼层
    不如先看例程学习,如果你懂点网络通信原理,你会知道,例程就是你要的程序
    2016-12-21 15:41
  • 签到天数: 6 天
     楼主| 发表于 2014-10-25 10:14 | 显示全部楼层
    我改的两个程序,就是通信没成功。你瞅瞅。
    这是发送端‘’
    #include <SPI.h>
    #include <WiFi.h>
    #include <WiFiUdp.h>
    IPAddress localip(172,27,35,13);
    int status = WL_IDLE_STATUS;
    char ssid[] = "360WiFi-9618"; //  your network SSID (name)
    char pass[] = "201331210010";    // your network password (use for WPA, or use as key for WEP)
    int keyIndex = 0;            // your network key Index number (needed only for WEP)
    // buffers for receiving and sending data
    //char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
    //char  ReplyBuffer[] = "acknowledged";       // a string to send back
    int iPin0 = A0;
    int iPin1 = A1;
    int iPin2 = A2;
    int iPin3 = A3;
    int ledPin = 13;
    //WiFiServer server(80);
    // An EthernetUDP instance to let us send and receive packets over UDP
    unsigned int localPort = 8888;      // local port to listen on
    char packetBuffer[255]; //buffer to hold incoming packet
    char  ReplyBuffer[] = "11";       // a string to send back
    IPAddress remoteip(172,27,35,15);
    WiFiUDP Udp;
      //Initialize serial and wait for port to open:
      pinMode(ledPin, OUTPUT);
      digitalWrite(ledPin, LOW);
      if (WiFi.status() == WL_NO_SHIELD) {
        Serial.println("WiFi shield not present");
        // don't continue
        while(true);
        while ( status != WL_CONNECTED) {
        Serial.print("Attempting to connect to SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
        status = WiFi.begin(ssid,pass);
        // wait 10 seconds for connection:
        delay(10000);
      Serial.println("Connected to wifi. My address:");
      //printWifiStatus();
      IPAddress myAddress = WiFi.localIP();
      Serial.println(myAddress);
      Serial.println("\nStarting connection to server...");
      // if you get a connection, report back via serial:
       /*status = WiFi.begin(ssid, pass);
       if ( status != WL_CONNECTED) {
        Serial.println("Couldn't get a wifi connection");
         while(true);
      else {
         server.begin();
         Serial.print("Connected to wifi. My address:");
    // printWifiStatus();*/
      Udp.begin(localPort);
       if(analogRead(iPin1)>=1024&&analogRead(iPin0)>=700&&analogRead(iPin2)>=700&&analogRead(iPin3)>=700)
      digitalWrite(ledPin, HIGH);
      while(1){
        int packetSize = Udp.parsePacket();
        IPAddress remote = Udp.remoteIP();
       Udp.beginPacket(remoteip,localPort);
         ReplyBuffer[0]='a';
         Udp.write(ReplyBuffer[0]);
         Udp.endPacket();
         Serial.println("had send");
    else {
      Serial.println("no send");
    这是接收端
    #include <SPI.h>
    #include <WiFi.h>
    //char ssid[] = "TeleTouch"; //  your network SSID (name)
    //char pass[] = "asdf1234";    // your network password (use for WPA, or use as key for WEP)
    int ledPin = 13;
    //IPAddress localip(192,168,60,13);
    IPAddress remoteip(172,27,35,13);
    WiFiUDP Udp;
         while(true);
      else {
         server.begin();
      //Udp.beginPacket(remoteip,localPort);
      //Udp.write(ReplyBuffer);
      //Udp.endPacket();
    //  Serial.write("had send");
      //delay(1000);
        Serial.println("myAddress111");
      // if there's data available, read a packet
      Serial.println("myAddress222");
      //Udp.beginPacket(Udp.remoteIP(),localPort);
      if(packetSize)
        Serial.println("myAddress333");
        Udp.read(packetBuffer,255);
         Serial.println("received");
        Serial.print("Received packet of size ");
        Serial.println(packetSize);
        Serial.print("From ");
        IPAddress remoteIp = Udp.remoteIP();
        Serial.print(remoteIp);
        Serial.print(", port ");
        Serial.println(Udp.remotePort());
    2016-12-21 15:41
  • 签到天数: 6 天
     楼主| 发表于 2014-10-27 11:55 | 显示全部楼层
    有没有人帮忙试一试啊,看看能不能通信啊
    2014-11-28 16:53
    发表于 2014-10-30 01:09 | 显示全部楼层
    用wifi shield的人本来就少,你居然还用两片,想试程序都爱莫能助额
    2016-12-21 15:41
  • 签到天数: 6 天
     楼主| 发表于 2014-10-30 09:10 | 显示全部楼层
    啊,没事,已经通了。ip的问题。没找对
    2019-7-22 09:48
    发表于 2019-7-22 16:08 | 显示全部楼层
    星空星辰 发表于 2014-10-30 09:10
    啊,没事,已经通了。ip的问题。没找对
    楼主不知道还能不能看到,将发送端和接收端的IP改的不一样就可以了吗?
    哪位高手帮帮忙呀用UNO主板控制垃圾分类
    哪位高手帮帮忙呀用UNO主
    打砖块游戏
    打砖块游戏
    **** 本内容被作者隐藏 ****
    【原创】全球最小口袋3D打印机mini one直播教程贴
    【原创】全球最小口袋3D打
    arduino Micro
    arduino Micro
    1、micro概述 Micro是一款基于ATmega32U4的微控制器板,与Adafruit共同开发 。
