查看: 6330|回复: 11
使用blinker制作一个WiFi遥控小车
 关闭 [复制链接]
    发表于 2018-5-3 22:25 | 显示全部楼层 |阅读模式
    本贴已作废,请看最新的开发文档
    本示例将展示如何制作一个WiFi遥控的小车,制作本项目前,你最好已经掌握一定的Arduino小车制作基础。
    演示视频,稍后上传
    硬件准备
    WiFiduino 或其他 esp8266开发板
    小车套件
    将WiFiduino与小车电机驱动相连
    软件准备
    下载并安装Arduino IDE
    点击去下载
    下载并安装esp8266扩展
    点击去下载
    下载并加载Blinker-library
    点击去下载
    下载并安装blinker APP
    android下载:点击下载
    IOS下载:app store中搜索“blinker”下载
    编译上传示例程序
    将示例程序上传到Arduino中
    其中ssid和pswd需写入你当前WiFi的ssid和密码
    char ssid[] = "<Your WiFi network SSID or name>";
    char pswd[] = "<Your WiFi network WPA password or WEP key>";
    完整示例程序如下:
     * Blinker WiFi CAR, support WiFiduino
    #define BLINKER_PRINT    Serial
    #define BLINKER_WIFI
    #define L_DIR_PIN       14
    #define L_PWM_PIN       16
    #define R_DIR_PIN       4
    #define R_PWM_PIN       5
    #define C_BAR_PIN       12
    uint32_t car_os_time = millis();
    bool isWarn = false;
    void blinker_car_init()
        pinMode(L_DIR_PIN, OUTPUT);
        pinMode(L_PWM_PIN, OUTPUT);
        pinMode(R_DIR_PIN, OUTPUT);
        pinMode(R_PWM_PIN, OUTPUT);
        pinMode(C_BAR_PIN, INPUT_PULLUP);
    // #if defined(ESP8266)
        analogWriteRange(255);
    // #endif
    void blinker_car_parse(uint8_t &_L_PWM, bool &_L_DIR, uint8_t &_R_PWM, bool &_R_DIR)
        uint8_t xAxis = Blinker.joystick(J_Xaxis);
        uint8_t yAxis = Blinker.joystick(J_Yaxis);
        bool    isStop = false;
        if (yAxis < 128) {
            _L_DIR = true;
            _R_DIR = true;
            _L_PWM = map(abs(128-yAxis), 0, 128, 128, 255);
            _R_PWM = map(abs(128-yAxis), 0, 128, 128, 255);
        else if (yAxis > 128) {
            _L_DIR = false;
            _R_DIR = false;
        else {
            isStop = true;
            _L_PWM = 0;
            _R_PWM = 0;
        if (xAxis < 128) {
            if (isStop) {
                _L_DIR = false;
                _R_DIR = true;
                _L_PWM = map(abs(128-xAxis), 0, 128, 128, 255);
                _R_PWM = map(abs(128-xAxis), 0, 128, 128, 255);
            else {
                _L_PWM -= map(abs(128-xAxis), 0, 128, 0, 128);
        else if (xAxis > 128) {
            if (isStop) {
                _L_DIR = true;
                _R_DIR = false;
            else {
                _R_PWM -= map(abs(128-xAxis), 0, 128, 0, 128);
        else {
            if (isStop) {
                _L_PWM = 0;
                _R_PWM = 0;
    void blinker_car_control(uint8_t cl_pwm, bool cl_dir, uint8_t cr_pwm, bool cr_dir)
        digitalWrite(L_DIR_PIN, cl_dir);
        digitalWrite(R_DIR_PIN, cr_dir);
        analogWrite(L_PWM_PIN, cl_pwm);
        analogWrite(R_PWM_PIN, cr_pwm);
    void blinker_car_detect()
        if (!digitalRead(C_BAR_PIN)) {
            if (!isWarn) {
                Blinker.vibrate();
                isWarn = true;
            else if (millis() - car_os_time >= 5000) {
                isWarn = false;
        else {
            isWarn = false;
        blinker_car_init();
        Blinker.begin(ssid, pswd);
        uint8_t L_PWM = 0;
        uint8_t R_PWM = 0;
        bool    L_DIR = false;
        bool    R_DIR = false;
        blinker_car_parse(L_PWM, L_DIR, R_PWM, R_DIR);
        blinker_car_control(L_PWM, L_DIR, R_PWM, R_DIR);
        blinker_car_detect();
    #if defined(BLINKER_CAR_DEBUG)
        BLINKER_LOG4("L_PWM: ", L_PWM, "  | L_DIR: ", L_DIR);
        BLINKER_LOG4("R_PWM: ", R_PWM, "  | R_DIR: ", R_DIR);
        Blinker.delay(2000);
    #endif
    添加设备
    确保开发板和手机在同一局域网下
    在blinker app中,点击右上角的“+”进入添加设备页面
    点击选择 Arduino > WiFi接入
    等待搜索设备
    点击选择要接入的设备
    控制设备
    我的设备 页面点击设备,进入控制面板
    点击右上角 编辑界面 按钮
    添加 摇杆组件
    点击界面右上角保存界面布局
    操作组件即可控制小车移动了
    其他
    你可以添加其他组件,给小车定制更多功能
    还有问题可以回帖了解
    2019-2-28 22:19
  • 签到天数: 22 天
    发表于 2018-5-6 16:52 | 显示全部楼层
    有没有截图的???地球人看了三秒都不知所云
    先从快速接入学起 https://www.arduino.cn/thread-76018-1-1.html  详情 回复 发表于 2018-5-7 09:16
     楼主| 发表于 2018-5-7 09:16 | 显示全部楼层
    先从快速接入学起
    难过
    2018-6-30 19:26
  • 签到天数: 11 天
    发表于 2018-5-15 15:00 来自手机 | 显示全部楼层
    支持一个,努力学习中
    2019-5-4 13:10
  • 签到天数: 51 天
    发表于 2018-5-26 21:34 | 显示全部楼层
    能发一下接线图吗?我纯小白,总觉的少了一个接口
    没图,不同的电机驱动接线都不一样,你需要先弄懂小车电机驱动,再修改这个例程  详情 回复 发表于 2018-5-28 08:51
     楼主| 发表于 2018-5-28 08:51 | 显示全部楼层
    2019-6-26 11:00
  • 签到天数: 316 天
    发表于 2018-6-24 13:03 | 显示全部楼层
    代码没有任何注释,看不懂
    2018-9-27 17:40
    发表于 2018-10-25 22:23 | 显示全部楼层
    class BlinkerSimpleESP8266_WS' has no member named 'Joystick'
    2018-9-27 17:40
    发表于 2018-10-25 22:24 | 显示全部楼层
    报错了,这是怎么回事?
    2019-4-12 15:19
  • 签到天数: 5 天
    发表于 2018-12-30 23:16 | 显示全部楼层
    摇杆组件在新版的blinker中取消了好像
    做了一个定时喂鱼的装置
    做了一个定时喂鱼的装置
    快放假了,怕鱼饿瘦了做了这么个控制,每天定时投鱼粮。用ESP8266编写,web设定参数,
    【项目】基于Arduino Nano的多功能桌面感应垃圾桶
    【项目】基于Arduino Nano
    arduino +MPU6050控制云台相机匀速转动(接受付费)!
    最近在调试云台(用的有刷直流减速电机挂大相机的那种),发现相机在往下移动时往往速
    光敏电阻检测环境光实验
    光敏电阻检测环境光实验
    基于Esp8266的点阵时钟
    基于Esp8266的点阵时钟
