查看: 1798|回复: 5
WiFiduino 8266 试机贴
    2019-11-1 21:03
  • 签到天数: 101 天
    发表于 2018-5-18 19:15 | 显示全部楼层 |阅读模式
    千呼万唤,WiFiduijno板子终于到手。。。共试了两部分功能 ,IO, WiFi
    1.从    https://www.arduino.cn/thread-76029-1-1.html    下载需要的文件,安装到默认位置,之后再打开IDE就能发现开发板里多出了 WiFiduino 。
    2.板子就选 WiFiduino,没说的,其它的不用动,串口号要对应上。
    3.先试试IO,懒,所以只用了8266的GPIO1,编译上传,正常开闪
      Blink the blue LED on the WiFiduino
      This example code is in the public domain
      The blue LED on the  module is connected to GPIO1
      (which is also the TXD pin; so we cannot use Serial.print() at the same time)
      Note that this sketch uses LED_BUILTIN to find the pin with the internal LED
      pinMode(LED_BUILTIN, OUTPUT);     // Initialize the LED_BUILTIN pin as an output
      digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (Note that LOW is the voltage level
      // but actually the LED is on; this is because
      // it is active low on the ESP-01)
      delay(1000);                      // Wait for a second
      digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
      delay(2000);                      // Wait for two seconds (to demonstrate the active low LED)
    blink
    blink
    4.再试试wifi.  这里有问题,编译正常,但无法正常下载,需要在下载的时间手动按一下reset,还不一定每次都好使。。。
        This sketch demonstrates how to scan WiFi networks.
    #include "ESP8266WiFi.h"
      // Set WiFi to station mode and disconnect from an AP if it was previously connected
      WiFi.mode(WIFI_STA);
      WiFi.disconnect();
      Serial.println("Setup done");
      Serial.println("scan start");
      // WiFi.scanNetworks will return the number of networks found
      int n = WiFi.scanNetworks();
      Serial.println("scan done");
      if (n == 0) {
        Serial.println("no networks found");
      } else {
        Serial.print(n);
        Serial.println(" networks found");
        for (int i = 0; i < n; ++i) {
          // Print SSID and RSSI for each network found
          Serial.print(i + 1);
          Serial.print(": ");
          Serial.print(WiFi.SSID(i));
          Serial.print(" (");
          Serial.print(WiFi.RSSI(i));
          Serial.print(")");
          Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*");
          delay(10);
      Serial.println("");
      // Wait a bit before scanning again
      delay(5000);
    WiFiscan
    WiFiscan
    订单号 143905477566214594
    2019-7-12 18:42
    发表于 2018-5-18 23:08 | 显示全部楼层
    应该是不用手工复位的,把IDE更新到最新版本,你这个版本太老了
    2019-11-1 21:03
  • 签到天数: 101 天
     楼主| 发表于 2018-5-19 05:24 | 显示全部楼层
    回家用自己的笔记本试了下,这回可以正常下载了
    2019-11-1 21:03
  • 签到天数: 101 天
     楼主| 发表于 2018-6-5 12:10 | 显示全部楼层
    @ coloz, 悄悄的说,我这个也是有订单号滴
    2018-6-22 18:21
    发表于 2018-6-27 10:46 | 显示全部楼层
    为什么程序都烧录完了,监视器显示都联网了,手机上的blinker就是搜不到设备,买了二块板都这样,啥毛病啊,急死了,试了好几天
    2019-11-1 21:03
  • 签到天数: 101 天
     楼主| 发表于 2018-6-29 17:44 | 显示全部楼层
    我是下了最新版本的blinker  arduino IDE。。。
    【原创】 drawbot平面关节
    Arduino使用电阻分压测量电池电压问题
    Arduino使用电阻分压测量
    中文 字库 的8针 OLED 128
