查看: 1299|回复: 7
[已解决] 上传项目出错,希望大佬帮忙看看!
发表于 2018-6-11 19:49 | 显示全部楼层 |阅读模式
Arduino:1.8.5 (Windows 10), 开发板:"Arduino/Genuino Uno"
项目使用了 2056 字节,占用了 (6%) 程序存储空间。最大为 32256 字节。
全局变量使用了188字节,(9%)的动态内存,余留1860字节局部变量。最大为2048字节。
上传项目出错
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
然后我就让他编译上传都显示详细信息
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\u'u\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\u'u\AppData\Local\Temp\arduino_build_410065 -warnings=none -build-cache C:\Users\u'u\AppData\Local\Temp\arduino_cache_937821 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\u'u\Documents\Arduino\sketch_jun11b\sketch_jun11b.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\u'u\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\u'u\AppData\Local\Temp\arduino_build_410065 -warnings=none -build-cache C:\Users\u'u\AppData\Local\Temp\arduino_cache_937821 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\u'u\Documents\Arduino\sketch_jun11b\sketch_jun11b.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\sketch\sketch_jun11b.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\sketch\sketch_jun11b.ino.cpp" -o "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\preproc\ctags_target_for_gcc_minus_e.cpp"
正在编译项目...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\sketch\sketch_jun11b.ino.cpp" -o "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\sketch\sketch_jun11b.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.elf" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065\sketch\sketch_jun11b.ino.cpp.o" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/..\arduino_cache_937821\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\u'u\AppData\Local\Temp\arduino_build_410065" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.elf" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.elf" "C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.hex"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\u'u\AppData\Local\Temp\arduino_build_410065/sketch_jun11b.ino.hex:i
上传项目出错
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
板子上什么也没插,上传前按了rest
烧录引导程序错误
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
烧录引导程序出错。
程序
程序
端口
端口
端口属性
端口属性
    发表于 2018-6-11 21:26 | 显示全部楼层
    板子是UNO吗?确定是烧了bootloader的UNO?
     楼主| 发表于 2018-6-12 15:41 | 显示全部楼层
    emmm。。。不知道怎么把图片发给你 我就把帖子编辑了一下。板子是学校发的,我自己看了论坛里的型号都没找到一样的,不过应该是uno的。我点烧录引导程序的时候也是显示烧录错误。
    这不是UNO,这应该是你们自己做的板子,问下做板子的人,里面用的什么哪个型号的bootloader,然后选择对应的型号即可  详情 回复 发表于 2018-6-12 17:26
    发表于 2018-6-12 17:26 | 显示全部楼层
    小白一枚-BOW 发表于 2018-6-12 15:41
    emmm。。。不知道怎么把图片发给你 我就把帖子编辑了一下。板子是学校发的,我自己看了论坛里的型号都没 ...
    2019-1-18 11:41
  • 签到天数: 206 天
    发表于 2018-6-13 10:45 | 显示全部楼层
    你可以烧个promini的BootLoader试试
     楼主| 发表于 2018-6-13 17:17 | 显示全部楼层
    奈何col 发表于 2018-6-12 17:26
    这不是UNO,这应该是你们自己做的板子,问下做板子的人,里面用的什么哪个型号的bootloader,然后选择对 ...
    已经解决了,谢谢您,确实是型号问题。
    发表于 2018-6-15 12:52 | 显示全部楼层
    这是pro  mini的板子,不是uno
     楼主| 发表于 2018-7-15 17:23 | 显示全部楼层
    Xuxx 发表于 2018-6-15 12:52
    这是pro  mini的板子,不是uno
    不是,是古老的NG板
    KittenBot杯第六届开源硬件开发大赛启动啦
    KittenBot杯第六届开源硬
    【原创】制作一套USB电流采样板
    【原创】制作一套USB电流
    arduino数字输出端低电平不稳定
    arduino数字输出端低电平
    [Arduino物联网开发实战2]数据反馈
    [Arduino物联网开发实战2]
    博哥零基础教你玩转ESP826
