查看: 1304|回复: 0
ESP-8266天气预报Demo---四博智联
发表于 2018-6-15 12:41 | 显示全部楼层 |阅读模式
1、硬件
用一个四博智联提供的nodemcu。一个OLED屏,一个USB线,4根杜邦线,可以上网的路由器,电脑。
     3V3---VCC
     GND---GND
     GPIO4(D2)---SDA
     GPIO5(D1)---SCL
2、设置路由器
把路由器账号设置为把路由器账号设置为
账号:xh003
密码:zxd+19901120=
3、烧录程序
打开ESP_TOOLS下载工具,选择8266.
工具下载:http://bbs.doit.am/forum.php?mod ... 6&highlight=TOO
点击START.等待烧录完成。
烧录完成后复位一下nodemcu。等待10s左右。
测试结果如下:
Arduino代码如下:
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include <Wire.h>
#include "OLED.h"
static const char logo[] PROGMEM={
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x03,0x00,0xf0,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x7f,0x00,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0x00,0xfe,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x03,0x00,0x00,0x00,0xf8,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xe0,0xff,0x03,0x00,0xe0,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x1f,0x1c,0xf0,0x1f,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0x80,0x7f,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0xff,0x01,0x00,0xfc,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x07,0x00,0x00,0xfe,0x03,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x03,0x00,0x00,0xfc,0x07,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x01,0x00,0x00,0xf8,0x0f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x3f,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x1f,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x0f,0x00,0x00,0x00,0xf0,0x3f,0x00,0xf0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x07,0x00,0x00,0x00,0xf0,0x1f,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x07,0x00,0x00,0x00,0xf0,0x0f,0x00,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x03,0x00,0x00,0x00,0xf8,0x03,0x00,0xfc,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x01,0x00,0x00,0x00,0xfc,0x00,0x00,0x7e,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x01,0x00,0x00,0x00,0x7f,0x00,0x00,0x7f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0x80,0x1f,0x00,0x80,0x7f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0xe0,0x07,0x00,0xc0,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x00,0x00,0x00,0xf8,0x01,0x00,0xe0,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x00,0x7f,0x00,0x00,0xf8,0x3f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0xe0,0x1f,0x00,0x00,0xfe,0x0f,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0xf8,0x03,0x00,0x80,0xff,0x0f,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x7e,0x00,0x00,0xe0,0xff,0x01,0xf0,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x00,0x1f,0x00,0x00,0xf8,0xff,0x00,0xf8,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xc0,0x0f,0x00,0x00,0xfe,0x7f,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xe0,0x03,0x00,0x80,0xff,0x1f,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0xf8,0x01,0x00,0xe0,0xff,0x07,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x7c,0x00,0x00,0xfc,0xff,0x00,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x3e,0x00,0x00,0xff,0x07,0x00,0x00,0xfc,0xff,0xff,0xff,0x7f,
0xff,0xff,0x7f,0x00,0x0f,0x00,0xc0,0xff,0x07,0x00,0x00,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x80,0x07,0x00,0xf0,0xff,0xff,0x0f,0xc0,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xc0,0x03,0x00,0xf8,0xff,0xff,0x3f,0xf8,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xc0,0x01,0x00,0xfe,0xf8,0xc7,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xe1,0x01,0x00,0x7f,0xc0,0x03,0x87,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xe1,0x00,0xc0,0x7f,0x80,0x01,0x86,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x63,0x00,0xe0,0x7f,0x80,0x01,0x86,0x00,0xfe,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x63,0x00,0xe0,0x7f,0x8c,0x31,0x86,0xc3,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x67,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x6f,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0x7f,0x00,0xc0,0x7f,0x8c,0x31,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x00,0x80,0x7f,0x80,0x01,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x01,0x00,0x7f,0x80,0x01,0x86,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x03,0x00,0x7c,0xc0,0x03,0x87,0x83,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x07,0x00,0xf8,0xff,0xff,0xf1,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x0f,0x00,0xe0,0xff,0x7f,0xf0,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x3f,0x00,0x00,0xfe,0x07,0xfc,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0x7f,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x03,0x00,0x00,0xe0,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x0f,0x00,0x00,0xfc,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0x7f,0x00,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
0xff,0xff,0xff,0xff,0xff,0xff,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,
//GPIO4(SDA) GPIO5(SCL)
OLED display(4, 5);
const char* ssid     = "xh003";         // XXXXXX -- 使用时请修改为当前你的 wifi ssid
const char* password = "zxd+19901120=";         // XXXXXX -- 使用时请修改为当前你的 wifi 密码
const char* host = "api.seniverse.com";
const char* APIKEY = "wcmquevztdy1jpca";        //API KEY
const char* city = "shenzhen";
const char* language = "en";//zh-Hans 简体中文  会显示乱码
const unsigned long BAUD_RATE = 115200;                   // serial connection speed
const unsigned long HTTP_TIMEOUT = 5000;               // max respone time from server
const size_t MAX_CONTENT_SIZE = 1000;                   // max size of the HTTP response
// 我们要从此网页中提取的数据的类型
struct UserData {
  char city[16];//城市名称
  char weather[32];//天气介绍(多云...)
  char temp[16];//温度
  char udate[32];//更新时间
WiFiClient client;
char response[MAX_CONTENT_SIZE];
char endOfHeaders[] = "\r\n\r\n";
* @Desc 初始化操作
  WiFi.mode(WIFI_STA);     //设置esp8266 工作模式
  Serial.begin(BAUD_RATE);
  delay(10);
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");//写几句提示,哈哈
  Serial.println(ssid);
  WiFi.begin(ssid, password);   //连接wifi
    //这个函数是wifi连接状态,返回wifi链接状态
    Serial.print(".");
  Serial.println("");
  Serial.println(WiFi.localIP());//WiFi.localIP()返回8266获得的ip地址
  client.setTimeout(HTTP_TIMEOUT);
* @Desc  主函数
   //初始化oled
  display.begin();
  //测试显示信息
  display.print("Hello DOIT",2,3);
  display.print("www.doit.am",4,3);
  delay(2*1000);
  display.clear();
  while (!client.connected()){
     if (!client.connect(host, 80)){
         Serial.println("connection....");
  if (sendRequest(host, city, APIKEY) && skipResponseHeaders()) {
    clrEsp8266ResponseBuffer();
    readReponseContent(response, sizeof(response));
    UserData userData;
    if (parseUserData(response, &userData)) {
      printUserData(&userData);
  delay(300);//每5s调用一次
* @发送请求指令
bool sendRequest(const char* host, const char* cityid, const char* apiKey) {
  // We now create a URI for the request
  //心知天气
  String GetUrl = "/v3/weather/now.json?key=";
  GetUrl += apiKey;
  GetUrl += "&location=";
  GetUrl += city;
  GetUrl += "&language=";
  GetUrl += language;
  // This will send the request to the server
  client.print(String("GET ") + GetUrl + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("create a request:");
  Serial.println(String("GET ") + GetUrl + " HTTP/1.1\r\n" +
               "Connection: close\r\n");
  return true;
* @Desc 跳过 HTTP 头,使我们在响应正文的开头
bool skipResponseHeaders() {
  // HTTP headers end with an empty line
  bool ok = client.find(endOfHeaders);
  if (!ok) {
    Serial.println("No response or invalid response!");
  return ok;
* @Desc 从HTTP服务器响应中读取正文
void readReponseContent(char* content, size_t maxSize) {
  size_t length = client.peekBytes(content, maxSize);
  Serial.println("Get the data from Internet!");
  content[length] = 0;
  Serial.println(content);
  Serial.println("Read data Over!");
  client.flush();//这句代码需要加上  不然会发现每隔一次client.find会失败
* @Desc 解析数据
* 数据格式如下:
*    "results": [
*            "location": {
*                "id": "WX4FBXXFKE4F",
*                "name": "北京",
*                "country": "CN",
*                "path": "北京,北京,中国",
*                "timezone": "Asia/Shanghai",
*                "timezone_offset": "+08:00"
*            "now": {
*                "text": "多云",
*                "code": "4",
*                "temperature": "23"
*            "last_update": "2017-09-13T09:51:00+08:00"
bool parseUserData(char* content, struct UserData* userData) {
//    -- 根据我们需要解析的数据来计算JSON缓冲区最佳大小
//   如果你使用StaticJsonBuffer时才需要
//    const size_t BUFFER_SIZE = 1024;
//   在堆栈上分配一个临时内存池
//    StaticJsonBuffer<BUFFER_SIZE> jsonBuffer;
//    -- 如果堆栈的内存池太大,使用 DynamicJsonBuffer jsonBuffer 代替
  DynamicJsonBuffer jsonBuffer;
  JsonObject& root = jsonBuffer.parseObject(content);
  if (!root.success()) {
    Serial.println("JSON parsing failed!");
    return false;
  //复制我们感兴趣的字符串
  strcpy(userData->city, root["results"][0]["location"]["name"]);
  strcpy(userData->weather, root["results"][0]["now"]["text"]);
  strcpy(userData->temp, root["results"][0]["now"]["temperature"]);
  strcpy(userData->udate, root["results"][0]["last_update"]);
  //  -- 这不是强制复制,你可以使用指针,因为他们是指向“内容”缓冲区内,所以你需要确保
  //   当你读取字符串时它仍在内存中
  return true;
// 打印从JSON中提取的数据
void printUserData( struct UserData* userData) {
  Serial.println("Print parsed data :");
  display.print("City: ",0,0);
  display.print(userData->city,0,6);
  display.print("Weat: ",2,0);
  display.print(userData->weather,2,6);
  display.print("Temp: ",4,0);
  display.print(userData->temp,4,6);
// display.print("Last Updata : ",7,2);
display.print(userData->udate,6,0);
// display.print("\r\n");
delay(4*1000);
// 关闭与HTTP服务器连接
void stopConnect() {
  Serial.println("Disconnect");
  client.stop();
void clrEsp8266ResponseBuffer(void){
    memset(response, 0, MAX_CONTENT_SIZE);      //清空
bin文件下载地址:http://bbs.doit.am/forum.php?mod=viewthread&tid=442&page=1&extra=#pid514
KittenBot杯第六届开源硬件开发大赛启动啦
KittenBot杯第六届开源硬
关于arduino编译问题
关于arduino编译问题
编译示例程序老是这个问题,换了电脑都不行
莫名乱码 —— Arduino+RF
[blinker开发实战2]数据反馈
[blinker开发实战2]数据反
用Arduino控制PS2无线手柄为什么一直连接不上
用Arduino控制PS2无线手柄
