查看: 2415|回复: 19
[已解决] 64位win10系统下使用总提示上传失败
发表于 2018-6-17 08:24 | 显示全部楼层 |阅读模式
Arduino:1.8.1 (Windows 10), 开发板:"Arduino/Genuino Uno"
G:\Arduino学习\arduino-1.8.1\arduino-builder -dump-prefs -logger=machine -hardware G:\Arduino学习\arduino-1.8.1\hardware -tools G:\Arduino学习\arduino-1.8.1\tools-builder -tools G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -built-in-libraries G:\Arduino学习\arduino-1.8.1\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_439295 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -verbose G:\Arduino学习\ARDUINO 21节课程\LED闪灯实验\2\code2\code2.pde
G:\Arduino学习\arduino-1.8.1\arduino-builder -compile -logger=machine -hardware G:\Arduino学习\arduino-1.8.1\hardware -tools G:\Arduino学习\arduino-1.8.1\tools-builder -tools G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -built-in-libraries G:\Arduino学习\arduino-1.8.1\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_439295 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=G:\Arduino学习\arduino-1.8.1\hardware\tools\avr -verbose G:\Arduino学习\ARDUINO 21节课程\LED闪灯实验\2\code2\code2.pde
Using board 'uno' from platform in folder: G:\Arduino学习\arduino-1.8.1\hardware\arduino\avr
Using core 'arduino' from platform in folder: G:\Arduino学习\arduino-1.8.1\hardware\arduino\avr
Detecting libraries used...
"G:\Arduino瀛︿範\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IG:\Arduino瀛︿範\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IG:\Arduino瀛︿範\arduino-1.8.1\hardware\arduino\avr\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_439295\sketch\code2.pde.cpp" -o "nul"
Generating function prototypes...
"G:\Arduino瀛︿範\arduino-1.8.1\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IG:\Arduino瀛︿範\arduino-1.8.1\hardware\arduino\avr\cores\arduino" "-IG:\Arduino瀛︿範\arduino-1.8.1\hardware\arduino\avr\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_439295\sketch\code2.pde.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_439295\preproc\ctags_target_for_gcc_minus_e.cpp"
open NUL: The system cannot find the file specified.
换了最新版的1.8.5,也是一样
 楼主| 发表于 2018-6-17 08:41 | 显示全部楼层
 楼主| 发表于 2018-6-17 09:51 | 显示全部楼层
在论坛里看到一个帖子说要用低版本的可以,试了一下,果然可以,高版本对64位WIN10兼容性不好
不是win10的问题,你的代码或者说文件格式太老了,pde后缀的文件,说明已经是6前年的了 看社区教程吧,更新一些  详情 回复 发表于 2018-7-23 00:11
    2019-1-24 21:39
  • 签到天数: 84 天
    发表于 2018-6-17 18:18 | 显示全部楼层
    zyue760818 发表于 2018-6-17 09:51
    在论坛里看到一个帖子说要用低版本的可以,试了一下,果然可以,高版本对64位WIN10兼容性不好 ...
    arduino IDE 1.8.4版本 在win10专业版64bit运行稳定的路过
     楼主| 发表于 2018-6-19 20:35 | 显示全部楼层
    1.8.4试过了,不行呢
     楼主| 发表于 2018-6-19 20:52 | 显示全部楼层
    Arduino:1.8.5 (Windows 10), 开发板:"Arduino/Genuino Uno"
    G:\Arduino学习\Arduino\arduino-builder -dump-prefs -logger=machine -hardware G:\Arduino学习\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools G:\Arduino学习\Arduino\tools-builder -tools G:\Arduino学习\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries G:\Arduino学习\Arduino\libraries -libraries G:\zy\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_95785 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_775671 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose G:\Arduino学习\Arduino\examples\01.Basics\Blink\Blink.ino
    G:\Arduino学习\Arduino\arduino-builder -compile -logger=machine -hardware G:\Arduino学习\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools G:\Arduino学习\Arduino\tools-builder -tools G:\Arduino学习\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries G:\Arduino学习\Arduino\libraries -libraries G:\zy\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_95785 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_775671 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose G:\Arduino学习\Arduino\examples\01.Basics\Blink\Blink.ino
    Using board 'uno' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
    Using core 'arduino' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_95785\sketch\Blink.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_95785\sketch\Blink.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_95785\preproc\ctags_target_for_gcc_minus_e.cpp"
     楼主| 发表于 2018-7-5 13:47 | 显示全部楼层
    G:\Arduino学习\Arduino\arduino-builder -dump-prefs -logger=machine -hardware G:\Arduino学习\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools G:\Arduino学习\Arduino\tools-builder -tools G:\Arduino学习\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries G:\Arduino学习\Arduino\libraries -libraries G:\zy\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_109397 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_974254 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose G:\Arduino学习\ARDUINO 21节课程\2-测试程序\arduino 实用样例-配套德飞莱视频教程\11-电位器控制led亮度\AnalogInOutSerial\AnalogInOutSerial.ino
    G:\Arduino学习\Arduino\arduino-builder -compile -logger=machine -hardware G:\Arduino学习\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools G:\Arduino学习\Arduino\tools-builder -tools G:\Arduino学习\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries G:\Arduino学习\Arduino\libraries -libraries G:\zy\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10805 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_109397 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_974254 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avrdude.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avr-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose G:\Arduino学习\ARDUINO 21节课程\2-测试程序\arduino 实用样例-配套德飞莱视频教程\11-电位器控制led亮度\AnalogInOutSerial\AnalogInOutSerial.ino
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_109397\sketch\AnalogInOutSerial.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_109397\sketch\AnalogInOutSerial.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_109397\preproc\ctags_target_for_gcc_minus_e.cpp"
     楼主| 发表于 2018-7-5 13:48 | 显示全部楼层
    求高手指点!
    2019-2-23 12:02
  • 签到天数: 693 天
    发表于 2018-7-5 14:03 | 显示全部楼层
    没有遇到过这个现象。有个想法,我自己从不用Administrator用户,试试看,删除IDE,新建用户,新用户名登录,重装IDE。
     楼主| 发表于 2018-7-7 16:52 | 显示全部楼层
    我用的IDE都是绿色版,不是安装的
    [发布帖]RPG游戏 无人世界
    [发布帖]RPG游戏 无人世界
    视频攻略:https://www.bilibili.com/video/av43790997/ 剧情:主角是一只猫又,在逃
    arduino oled 时钟 可设置闹钟 表
    arduino oled 时钟 可设置
    呆板教程,固件是编译好的,有上传工具,这次不是IDE了
    Arduino 蓝牙机械臂
    Arduino 蓝牙机械臂
    蓝牙机械臂(这次没用BLINKER,改
    求助!!!!!!!!
    求助!!!!!!!!
    求助?????错在哪里了?谢谢
    max30102问题
    max30102问题
    最近网上买了个max30102的心率血氧模块,用卖家给的单个例程的时候数据还算准确,但是
