楼主: coloz
[官方公告] blinker bug报告
    2019-4-11 23:26
    发表于 2019-4-11 12:33 | 显示全部楼层
    bilnker库 2019.4.10从论坛奈何大大例程链接下载,烧录例程AT(mini/node板型)固件时报错。
    系统WINXP/win7 32位均测试;IDE是1.8.8/1.8.7;
    Blinker库放在My Documents\Arduino\libraries路径下。
    3月下载的库没问题。
    以下是WINXP,IDE 1.8.7测试的错误代码:
    In file included from d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:71:0,
                     from d:\My Documents\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTTAT.h:11,
                     from d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker.h:250,
                     from d:\My Documents\Arduino\libraries\blinker-library-master\examples\Blinker_AT_Firmware\AT_Firmware_WiFi\AT_Firmware_WiFi.ino:40:
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h: In member function 'bool BlinkerProtocol::checkAliAvail()':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h:151:52: error: 'class BlinkerStream' has no member named 'aligenieAvail'
                 bool checkAliAvail()    { return conn->aligenieAvail(); }
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h: In member function 'bool BlinkerProtocol::checkDuerAvail()':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerProtocol.h:152:52: error: 'class BlinkerStream' has no member named 'duerAvail'
                 bool checkDuerAvail()   { return conn->duerAvail(); }
    In file included from d:\My Documents\Arduino\libraries\blinker-library-master\src/BlinkerESPMQTTAT.h:11:0,
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'void BlinkerApi::attachDataStorage(blinker_callback_t, uint32_t)':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:471:15: error: '_dataStorageFunc' was not declared in this scope
                 { _dataStorageFunc = newFunction; _autoStorageTime = _time; _autoDataTime = millis(); }
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:471:47: error: '_autoStorageTime' was not declared in this scope
                 { _dataStorageFunc = newFunction; _autoStorageTime = _time; _autoDataTime = millis(); }                                               ^
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:471:73: error: '_autoDataTime' was not declared in this scope
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'void BlinkerApi::needInit()':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:1890:13: error: 'sharers' is not a member of 'BProto {aka BlinkerProtocol}'
                 BProto::sharers(_shareData);
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'void BlinkerApi::run()':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2807:25: error: 'needFreshShare' is not a member of 'BProto {aka BlinkerProtocol}'
                         if (BProto::needFreshShare())
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2816:29: error: 'sharers' is not a member of 'BProto {aka BlinkerProtocol}'
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2875:13: error: '_dataStorageFunc' was not declared in this scope
             if (_dataStorageFunc)
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2877:28: error: '_autoDataTime' was not declared in this scope
                 if (millis() - _autoDataTime >= _autoStorageTime * 1000)
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2877:45: error: '_autoStorageTime' was not declared in this scope
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:2884:43: error: '_autoStorageTime' was not declared in this scope
             if (millis() - _autoUpdateTime >= _autoStorageTime * BLINKER_MAX_DATA_COUNT * 1000 / 2)
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'void BlinkerApi::bridgePrint(char*, const String&)':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:4608:9: error: 'bPrint' is not a member of 'BProto {aka BlinkerProtocol}'
             BProto::bPrint(bName, data);
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'bool BlinkerApi::autoTrigged(uint32_t)':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:5641:16: error: 'autoPrint' is not a member of 'BProto {aka BlinkerProtocol}'
             return BProto::autoPrint(_id);
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h: In member function 'void BlinkerApi::shareParse(const ArduinoJson::JsonObject&)':
    d:\My Documents\Arduino\libraries\blinker-library-master\src/Blinker/BlinkerApi.h:7482:21: error: 'sharers' is not a member of 'BProto {aka BlinkerProtocol}'
    exit status 1
    为开发板 LOLIN(WEMOS) D1 R2 & mini 编译时出错。
    github下载最新库试试  详情 回复 发表于 2019-4-14 16:38
    2019-10-6 01:22
  • 签到天数: 5 天
    发表于 2019-4-14 16:22 | 显示全部楼层
    [mw_shl_code=arduino,true]#define BLINKER_WIFI
    #define LOG_PERIOD 1000
    char auth[] = "";
    char ssid[] = "";
    char pswd[] = "";
    unsigned long previousMillis=0;  //variable for time measurement  先前时间测量
    BlinkerNumber counts("counts");
    unsigned long cps=0;
    void heartbeat()
    { counts=0;
      Blinker.print("cps", 10);
        BLINKER_DEBUG.stream(Serial);
        BLINKER_DEBUG.debugAll();
        pinMode(LED_BUILTIN, OUTPUT);
        Blinker.delay(2000);
            unsigned long currentMillis = millis();
          if(currentMillis - previousMillis > LOG_PERIOD)
            previousMillis = currentMillis;
            counts = 0;
        cps++;
    }[/mw_shl_code]问题现象:给键值赋值会导致复位
    android版本:9.0
    手机型号:mi9
    开发板:esp8266
    其他说明:比如我在给counts这个键值赋值一次0 就会复位一次
    建议学下C++  详情 回复 发表于 2019-4-14 16:29
    发表于 2019-4-14 16:29 | 显示全部楼层
    #include
    这是瞎写程序,建议学下C++
    发表于 2019-4-14 16:38 | 显示全部楼层
    系统WINXP/win7  ...
    github下载最新库试试
    2019-5-22 11:39
  • 签到天数: 27 天
    发表于 2019-4-14 17:00 | 显示全部楼层
    手机:苹果7,系统:IOS10.3.3
    Blinker版本:2.1.5
    蓝牙模块:jdy-08
    开发板:mega2560
    照着例程把wifi改成了蓝牙,但是么得反应
    详细介绍帖子:学习记录2,Blinker读取温湿度
    https://www.arduino.cn/forum.php?mod=viewthread&tid=85510&fromuid=174941
    (出处: Arduino中文社区)
    #define BLINKER_BLE
    #include <DHT.h>
    BlinkerNumber HUMI("humi");
    BlinkerNumber TEMP("temp");
    #define DHTPIN 7
    #define DHTTYPE DHT11   // DHT 11
    DHT dht(DHTPIN, DHTTYPE);
    float humi_read = 0, temp_read = 0;
    void heartbeat()
        HUMI.print(humi_read);
        TEMP.print(temp_read);
        dht.begin();
        Blinker.begin(2,3,115200);
        float h = dht.readHumidity();
        if (isnan(h) || isnan(t))
            BLINKER_LOG("Failed to readfrom DHT sensor!");
            BLINKER_LOG("Humidity: ", h, " %");
            BLINKER_LOG("Temperature: ", t, " ℃");
            humi_read = h;
            temp_read = t;
    但是加上按键强制返回就有了
    [mw_shl_code=arduino,true]void refresh_callback(const String & state){
      if(state=="tap"){
        HUMI.print(DHT.humidity);
        TEMP.print(sensors.getTempCByIndex(0));
        TEXT.print("点击刷新");
        Blinker.delay(500);
    (上面的代码是另外一个程序里的,头文件不太一样,问题不大)
    (答辩录的视频,原谅下渣画质。。。)
    现在基本就是这么个情况。。。靠按键返回不用心跳包就ok,直接心跳包就没反应
    2019-4-11 23:26
    发表于 2019-4-15 16:27 | 显示全部楼层
    奈何col 发表于 2019-4-14 16:38
    github下载最新库试试
    可以了,2019.4.15版本。论坛例程一和AT固件可编译了。https://github.com/blinker-iot/blinker-library下的,请问下库没版本号吗?
    release版本才有版本号  详情 回复 发表于 2019-4-15 17:03
    发表于 2019-4-15 17:03 | 显示全部楼层
    nyx 发表于 2019-4-15 16:27
    可以了,2019.4.15版本。论坛例程一和AT固件可编译了。https://github.com/blinker-iot/blinker-library ...
    release版本才有版本号
    2020-7-9 11:45
  • 签到天数: 471 天
    发表于 2019-5-8 19:58 | 显示全部楼层
    问题现象:新版app定时开关机,
    1   如果有两个按钮,点第二个时,两个按钮图标都亮,无法在手机端分辨出定时设置的是那个按钮。
    2   如果初始化时两个按钮都是关闭状态,通过手机端定时打开一个后,初始化设备界面按钮开关状态在图标中还都是关闭状态,实际灯已经通过定时打开了。
    app版本:2.2.0
    android版本:7.0
    手机型号:红米
    库版本:arduino 2.0
    开发板:nodemcu
    2019-7-12 18:42
     楼主| 发表于 2019-5-8 21:01 | 显示全部楼层
    答:理论不会如此,建议你自查下程序。
    答:这个你在心跳包中反馈为打开就行了。
    2020-7-9 11:45
  • 签到天数: 471 天
    发表于 2019-5-8 22:03 | 显示全部楼层
    答:理 ...
    跟程序没关系,是手机端APP开设定时。
    看最后一张图,实际在定时状态,点了第二个按钮,是APP的两个定时按钮图标都亮了,,怎么知道是操作的那个尼?  ,为什么点第一个正常尼?
    你自己设置2个以上按钮,操作试试。没试,你怎么就知道不可能?
    好像只能设置同一时间,一个设备定时,能不能设置多个设备都可以定时?
    这确实是一个有待优化的地方,以后版本会做优化,解决办法是使用blinker规范的key命名方式:btn-xxx  详情 回复 发表于 2019-5-9 00:52
    求解用arduino 让WS2812全
    想通过blinker按钮按住常亮灯松手熄灭功能
    想通过blinker按钮按住常
    1.测试了APP里面的开关按键,可以实现按下灯亮再按一下灯灭。2.做第2步测试的时候,想
    新手求助!blinker同步到
