楼主: createskyblue
发表于 2019-12-18 16:50 | 显示全部楼层
留个足迹,谢谢分享
发表于 2019-12-19 12:27 | 显示全部楼层
thankyou for sharing
发表于 2019-12-19 12:48 | 显示全部楼层
#include <SPI.h>
#include "U8glib.h"
unsigned char name0[8] = {0xC4, 0xE3, 0xBA, 0xC3, 0xCA, 0xC0, 0xBD, 0xE7};
unsigned char name1[12] = {0x48, 0x45, 0x4C, 0x4C, 0x4F, 0x2C, 0x57, 0x4F, 0x52, 0x4C, 0x44, 0x21};
  以下函数由arduinoCN坛友NoComment提供表示感谢
  这是他的github:https://github.com/XAS-712/gt20l16s1y
U8GLIB_SSD1306_ADAFRUIT_128X64 u8g(10, 9);    // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are  SCK = 13 and MOSI = 11) //[重要]注意u8g的配置要与以下4行匹配 必须要保证设备名为u8g
#define CS 8  //字库数据输出
#define SO 12 //字库片选
#define SI 11 //MOSI(数据线)
#define CL 13 //CLK(时钟)
long getAddr(uint16_t str)
{ byte hb = (byte)((str & 0xff00) >> 8);
  byte lb = (byte)(str & 0x00ff);
  Serial.print("HB ");
  Serial.print(hb, HEX);
  Serial.print(" LB ");
  Serial.println(lb, HEX);
  long Address;
  if (hb > 0xA0 && lb > 0xA0)//is GB2312
  { long BaseAdd = 0;
    if (hb == 0xA9 && lb >= 0xA1)
    { Address = (282 + (lb - 0xA1 ));//8位机在此出现了溢出,所以分三步
      Address = Address * 32;
      Address += BaseAdd;
    else if (hb >= 0xA1 && hb <= 0xA3 && lb >= 0xA1)
    { Address = ((hb - 0xA1) * 94 + (lb - 0xA1));
      Address += BaseAdd;
    else if (hb >= 0xB0 && hb <= 0xF7 && lb >= 0xA1)
    { Address = ((hb - 0xB0) * 94 + (lb - 0xA1) + 846);
      Address += BaseAdd;
  } else {//is ASCII
    long BaseAdd = 0x03b7c0;
    if (lb >= 0x20 && lb <= 0x7E)
    { Address = (lb - 0x20 ) * 16 + BaseAdd;
  return Address;
byte revBit(byte input)
{ byte output = 0;
  for (int i = 0;  i < 8;  i++)
  { if (input & (1 << i))
      output |= 1 << (7 - i);
  return output;
void fetchBitmap16(long address, byte *p)
{ byte hb = (byte)((address & 0x00ff0000) >> 16);
  byte mb = (byte)((address & 0x0000ff00) >> 8);
  byte lb = (byte)(address & 0x000000ff);
  digitalWrite(CS, LOW);//选通字库
  SPI.transfer(0x0b);//移入命令字
  SPI.transfer(hb);//移入地址次高位
  SPI.transfer(mb);//移入地址次低位
  SPI.transfer(lb);//移入地址最低位
  SPI.transfer(0x8d);//移入dummy byte
  for (int i = 0; i < 16; i++)
  { byte buf = SPI.transfer(0x00); //读出16bytes
    p[i] = revBit(buf);
  digitalWrite(CS, HIGH);//反选通字库
void fetchBitmap32(long address, byte *p)
  for (int i = 0; i < 32; i++)
  { byte buf = SPI.transfer(0x00); //读出32bytes
    p[i] = revBit(buf);
void drawV8P(int x, int y, byte b)
{ if ((b & 0x80) == 0x80)
    u8g.drawPixel(x, y);
  if ((b & 0x40) == 0x40)
    u8g.drawPixel(x, y + 1);
  if ((b & 0x20) == 0x20)
    u8g.drawPixel(x, y + 2);
  if ((b & 0x10) == 0x10)
    u8g.drawPixel(x, y + 3);
  if ((b & 0x08) == 0x08)
    u8g.drawPixel(x, y + 4);
  if ((b & 0x04) == 0x04)
    u8g.drawPixel(x, y + 5);
  if ((b & 0x02) == 0x02)
    u8g.drawPixel(x, y + 6);
  if ((b & 0x01) == 0x01)
    u8g.drawPixel(x, y + 7);
void draw8x16(int x, int y, byte *b)
{ int i;
  for (i = 0; i < 8; i++)
  { drawV8P(x + i, y, b[i]);
  { drawV8P(x + i, y + 8, b[i + 8]);
void draw16x16(int x, int y, byte *b)
{ int i;
  for (i = 0; i < 16; i++)
  { drawV8P(x + i, y + 8, b[i + 16]);
void displayStr(int x, int y, int len, unsigned char *c)
{ int i;
  for (i = 0; i < len; i++)
  { if (c[i] > 0xA0) //is GB2312
    { int code = (int)(c[i] * 256) + (int)c[i + 1];
      byte bmp[32];
      fetchBitmap32(getAddr(code), bmp);
      draw16x16(x, y, bmp);
      x += 16;
      i++;
    } else
    { //is ASCII
      int code = (int)c[i];
      byte bmp[16];
      fetchBitmap16(getAddr(code), bmp);
      draw8x16(x, y, bmp);
      x += 8;
void displayStrC(int row, int len, unsigned char *c)
{ int x = 64 - ((len * 8) / 2);
  displayStr(x, row, len, c);
  以上函数由arduinoCN坛友NoComment提供表示感谢
void setup(void)
{ pinMode(8, OUTPUT); //字库数据输出
void loop(void)
{ // picture loop
  u8g.firstPage();
  do
  { displayStr(0, 0, 8, name0);  //你好世界
    displayStr(0, 16, 12, name1);  //HELLO,WORLD!
  } while ( u8g.nextPage() );
  // rebuild the picture after some delay
  //delay(50);
发表于 2019-12-22 23:43 | 显示全部楼层
瞅一瞅看看咋样
发表于 2019-12-23 11:10 | 显示全部楼层
jhgnhgnbvngyfg
发表于 2019-12-25 12:32 | 显示全部楼层
感谢分享,找了好久了,顺便挖个坟
发表于 2019-12-25 18:16 | 显示全部楼层
233333棒棒
发表于 2019-12-27 15:26 | 显示全部楼层
好东西,进来看看。
发表于 2020-1-10 08:05 | 显示全部楼层
感谢楼主分享
arduino解码sbus
arduino解码sbus
wemos d1 wifi具体叫啥名,我也迷糊了,无法上传程序
wemos d1 wifi具体叫啥名
淘宝入手一块这样的板,详情页提供了教程,还提供了 arduino iDE 1.6.5免安装版本,
求大佬帮忙arudino上传报错programmer is not responding
求大佬帮忙arudino上传报
报错信息avrdude: stk500_recv(): programmer is not responding avrdude: stk500_get
新手求助!端口不显示的问题
新手求助!端口不显示的问
