查看: 2752|回复: 5
4*4薄膜按键求助
    2020-4-16 13:55
    发表于 2018-9-19 17:22 | 显示全部楼层 |阅读模式
    按照教程代码写入单片机后,串口只能输出1,其他的按都没有反应!代码不知哪里有问题,请路过的大佬指点一二!
    const int numRows = 4;//定义4 行
    const int numCols = 4;//定义4 列
    const int debounceTime = 20;//去抖动时间长度
    const char keymap[numRows][numCols]= {//键值,可以按需要更改
    { '1','2','3','A' },
    {'4','5','6','B' },
    {'7','8','9','C' },
    {'*','0','#','D' }
    const int rowPins[numRows] = {9,8,7,6};//设置硬件对应的引脚
    const int colPins[numCols] = {5,4,3,2};
    //初始化功能
    void setup(){
    for(int row = 0; row < 4; row++){
    pinMode(rowPins[row],INPUT_PULLUP);
    //digitalWrite(rowPins[row],HIGH);
    for(int column = 0;column < 4; column++){
    pinMode(colPins[column],OUTPUT);
    digitalWrite(colPins[column],HIGH);
    //主循环
    // 添加其他的程序,循环运行
    char key = getkey();
    if(key !=0)
    Serial.print("Got key ");//串口打印键值
    Serial.println(key);
    //读取键值程序
    char getkey(){
    char key = 0;
    digitalWrite(colPins[column],LOW);
    for(int row = 0 ;row < 4; row++){
    if(digitalRead(rowPins[row]) == LOW){ //是否有按键按下
    while(digitalRead(rowPins[row]) == LOW) //等待按键释放
    key = keymap[row][column];
    digitalWrite(colPins[column],HIGH); //De-active the current column
    return key;
    2019-12-23 17:45
  • 签到天数: 6 天
    发表于 2018-9-19 23:05 | 显示全部楼层
    #include <Keypad.h>
    const byte ROWS = 4; //四行
    const byte COLS = 4; //四列
    //定义键盘的按键
    char hexaKeys[ROWS][COLS] = {
    {'1','2','3','A'},
    {'4','5','6','B'},
    {'7','8','9','C'},
    {'*','0','#','D'}
    byte rowPins[ROWS] = {9, 8, 7, 6}; //连接到键盘的行线
    byte colPins[COLS] = {5, 4, 3, 2}; //连接到键盘列引脚
    //初始化键盘
    Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
    void setup(){
    void loop(){
      char customKey = customKeypad.getKey();
      if (customKey){ //当键盘按下时
        Serial.println(customKey); //发送键盘值
    2020-4-16 13:55
     楼主| 发表于 2018-9-20 09:18 | 显示全部楼层
    谢了,兄弟,如果不用库呢?
    2020-4-16 13:55
     楼主| 发表于 2018-9-20 10:07 | 显示全部楼层
    重新了一遍,好了!不知,再查查看!
      { '1','2','3','+' },
      {'4','5','6','-'  },
      {'7','8','9','X'  },
      {'*','0','#','/'  }
    void setup(){
      for(int row = 0; row < numRows; row++){
       pinMode(rowPins[row],INPUT);
    for(int column = 0;column < numCols; column++){
        if(key !=0){
    char getkey(){
        char key = 0;
          for(int row = 0 ;row < numRows; row++){
              delay(20);
              while(digitalRead(rowPins[row]) == LOW) ;
        return key;
    2020-4-16 13:55
     楼主| 发表于 2018-9-20 10:13 | 显示全部楼层
    已完工,收工!
    2018-9-21 15:12
  • 签到天数: 8 天
    发表于 2018-9-21 11:10 来自手机 | 显示全部楼层
    用示例代码试试
    求大神看看哪里有问题,设
    晒图ESP8266一个框架
    晒图ESP8266一个框架
    Arduino 求助 串口接收数据不正确,数据丢失问题
    Arduino 求助 串口接收数
