查看: 7937|回复: 0
python读取arduino数据并实时绘图
发表于 2018-10-25 18:59 | 显示全部楼层 |阅读模式
我使用arduino uno 与 ds18b20。
python编写串口代码与数据显示
地址
https://blog.csdn.net/qq_39020934/article/details/83348972
绘图使用matplotlib库
Arduino代码
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  Serial.begin(9600); //Begin serial communication
  Serial.println("Arduino Digital Temperature // Serial Monitor Version"); //Print a message
  sensors.begin();
void loop(void)
  // Send the command to get temperatures
  sensors.requestTemperatures();
  Serial.print("Temperature is: ");
  Serial.println(sensors.getTempCByIndex(0)); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
  //Update value every 1 sec.
Python代码
import serial
import matplotlib.pyplot as plt
from drawnow import *
import atexit
import time
values = []
plt.ion()#打开交互模式
serialArduino = serial.Serial('COM14', 9600)
def plotValues():
    plt.title('Serial temperature from Arduino')
    plt.grid(True)
    plt.ylabel('temperature')
    plt.plot(values,'rx-', label='temperature')
    plt.legend(loc='upper right')
def doAtExit():
    serialArduino.close()
    print("Close serial")
    print("serialArduino.isOpen() = " + str(serialArduino.isOpen()))
atexit.register(doAtExit)#程序退出时,回调函数
#预加载虚拟数据
for i in range(0,50):
    values.append(0)
while True:
    while (serialArduino.inWaiting()==0):
        pass
    print("readline()")
    valueRead = serialArduino.readline(500)
    #检查是否可以输入有效值
    try:
        valueInInt = float(valueRead)
        print(valueInInt)
        if valueInInt <= 1024:
            if valueInInt >= 0:
                values.append(valueInInt)
                values.pop(0)
                drawnow(plotValues)
            else:
                print("Invalid! negative number")#无效  负数
        else:
            print("Invalid! too large")# 无效 超过1024
    except ValueError:
        print("Invalid! cannot cast")
DallasTemperature.zip (29.23 KB, 下载次数: 129)
arduino解码sbus
arduino解码sbus
wemos d1 wifi具体叫啥名,我也迷糊了,无法上传程序
wemos d1 wifi具体叫啥名
淘宝入手一块这样的板,详情页提供了教程,还提供了 arduino iDE 1.6.5免安装版本,
求大佬帮忙arudino上传报错programmer is not responding
求大佬帮忙arudino上传报
报错信息avrdude: stk500_recv(): programmer is not responding avrdude: stk500_get
新手求助!端口不显示的问题
新手求助!端口不显示的问
