查看: 312|回复: 1
[未解决] 这个程序有什么问题
发表于 2018-11-8 15:14 | 显示全部楼层 |阅读模式
#include <Servo.h>
//左右电机驱动
const int ENAA=14;
const int IN1A=15;
const int IN2A=16;
const int ENAB=17;
const int IN1B=18;
const int IN2B=19;
unsigned long time;
int startspeed;
int topspeed;
int dir;
int value;
/*边沿检测 检测到边沿返回值高电平*/
const int BY1=28;
const int BY2=29;
const int BY3=30;
const int BY4=31;
/*对手检测 检测到对手返回值低电平*/
const int DS1=41;
const int DS2=42;
const int DS3=43;
const int DS4=44;
const int DS5=45;
const int DS6=46;
Servo myservo1;
Servo myservo2;
int pos = 0;
const int TrigPin = 2;
const int EchoPin = 3;
int cm;
int CM;
    pinMode(TrigPin,OUTPUT);
    pinMode(EchoPin,INPUT);
    pinMode(IN1A,OUTPUT);
    pinMode(IN2A,OUTPUT);
    pinMode(ENAA,OUTPUT);
    pinMode(ENAB,OUTPUT);
    pinMode(IN1B,OUTPUT);
    pinMode(IN2B,OUTPUT);
    pinMode(BY1,INPUT);  //输入模式
    pinMode(BY2,INPUT);
    pinMode(BY3,INPUT);
    pinMode(BY4,INPUT);
    pinMode(DS1,INPUT);
    pinMode(DS2,INPUT);
    pinMode(DS3,INPUT);
    pinMode(DS4,INPUT);
    pinMode(DS5,INPUT);
    pinMode(DS6,INPUT);
    myservo1.attach(53);
    myservo2.attach(52);
  myservo_ready();
  digitalWrite(IN1A,HIGH);//正转
  digitalWrite(IN2A,LOW);
  analogWrite(ENAA,50);
  digitalWrite(IN1B,HIGH);
  digitalWrite(IN2B,LOW);
  analogWrite(ENAB,50);
  if (CM = 6){
  myservo_first ();
  digitalWrite(IN1A,LOW);//停
  digitalWrite(IN1B,LOW);
  delay(1500);
  myservo_back ();
  myservo_stay ();
  if(digitalRead(BY1)==HIGH && digitalRead(BY2)==LOW && digitalRead(BY3)==LOW && digitalRead(BY4)==LOW)//左前检测到边沿
          digitalWrite(IN1A,LOW);//后退
          digitalWrite(IN2A,HIGH);
          digitalWrite(IN2B,HIGH);
          digitalWrite(IN1A,HIGH);//右转
          delay(510);
    else if(digitalRead(BY1)==LOW && digitalRead(BY2)==HIGH && digitalRead(BY3)==LOW && digitalRead(BY4)==LOW)//右前检测到边沿
          digitalWrite(IN1A,LOW);//左转
          delay(510);
      else if(digitalRead(BY1)==LOW && digitalRead(BY2)==LOW && digitalRead(BY3)==HIGH && digitalRead(BY4)==LOW)//右后检测到边沿
          delay(510);
        else if(digitalRead(BY1)==LOW && digitalRead(BY2)==LOW && digitalRead(BY3)==LOW && digitalRead(BY4)==HIGH)//左后检测到边沿
          delay(510);
      else if(digitalRead(BY1)==HIGH && digitalRead(BY2)==HIGH && digitalRead(BY3)==LOW && digitalRead(BY4)==LOW)//前面检测到边沿
          delay(700);
        else if(digitalRead(BY1)==LOW && digitalRead(BY2)==LOW && digitalRead(BY3)==HIGH && digitalRead(BY4)==HIGH)//后面检测到边沿
          delay(700);
      else if(digitalRead(BY1)==HIGH && digitalRead(BY2)==LOW && digitalRead(BY3)==LOW && digitalRead(BY4)==HIGH)//左侧检测到边沿
          delay(255);
      else if(digitalRead(BY1)==LOW && digitalRead(BY2)==HIGH && digitalRead(BY3)==HIGH && digitalRead(BY4)==LOW)//右侧检测到边沿
          delay(255);
      else if(digitalRead(BY1)==HIGH && digitalRead(BY2)==HIGH && digitalRead(BY3)==LOW && digitalRead(BY4)==HIGH)//左前三角检测到边沿
       else if(digitalRead(BY1)==HIGH && digitalRead(BY2)==HIGH && digitalRead(BY3)==HIGH && digitalRead(BY4)==LOW)//右前三角检测到边沿
      else if(digitalRead(BY1)==LOW && digitalRead(BY2)==HIGH && digitalRead(BY3)==HIGH && digitalRead(BY4)==LOW)//右后三角检测到边沿
       else if(digitalRead(BY1)==LOW && digitalRead(BY2)==HIGH && digitalRead(BY3)==HIGH && digitalRead(BY4)==LOW)//Z左后三角检测到边沿
      else if(digitalRead(BY1)==LOW && digitalRead(BY2)==LOW && digitalRead(BY3)==LOW && digitalRead(BY4)==LOW)//在边沿内
          if(digitalRead(DS1)==LOW && digitalRead(DS2)==LOW)
           do{
             }while(digitalRead(DS1)==LOW && digitalRead(DS2)==LOW);
      else if(digitalRead(DS3)==LOW && digitalRead(DS4)==LOW)
         do{
          }while(digitalRead(DS3)==LOW && digitalRead(DS4)==LOW);//在边沿内动作
      else if(digitalRead(DS5)==LOW)
        do{
          }while(digitalRead(DS5)==LOW);//在边沿内动作
       else if(digitalRead(DS6)==LOW)
        do{
          }while(digitalRead(DS6)==LOW);
void myservo_ready () {
  myservo1.write(25);
  myservo2.write(25);
void myservo_first () {
for(pos = 25 ; pos <= 147 ; pos++) //转动底座舵机
      myservo1.write(pos);
      delay (10);
  myservo1.write(147);
  myservo2.write(25);
void myservo_back () {
for(pos = 147 ; pos >= 90 ; pos++) //转动底座舵机
      delay (10);
      myservo2.write(pos);
      delay (10);
  myservo2.write(25);
void myservo_stay () {
  myservo1.write(120);
  myservo2.write(120);
void chaoshengbo() {
  digitalWrite(TrigPin,LOW);  //低高低电平发一个短时间脉冲出去
  delayMicroseconds(2);
  digitalWrite(TrigPin,HIGH);
  delayMicroseconds(10);
  cm = pulseIn(EchoPin,HIGH)/58.0;  //将回波时间换算成cm
  cm = (int(cm * 100.0))/100.0;  //保留两位小数
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  CM = cm;
程序上传上去只有舵机运行,并且舵机运行了147度之后会一下打到180度,然后进入过载保护程序从新运行。如何解决?
求支招
 楼主| 发表于 2018-11-8 15:16 | 显示全部楼层
视频地址http://tieba.baidu.com/p/0
KittenBot杯第六届开源硬件开发大赛启动啦
KittenBot杯第六届开源硬
【原创】制作一套USB电流采样板
【原创】制作一套USB电流
arduino数字输出端低电平不稳定
arduino数字输出端低电平
[Arduino物联网开发实战2]数据反馈
[Arduino物联网开发实战2]
博哥零基础教你玩转ESP826
