查看: 785|回复: 2
ESP32驱动microSD_SSD1351显示图片很慢求大神帮忙
    2018-12-12 11:46
    发表于 2018-11-30 23:04 | 显示全部楼层 |阅读模式
    2018-12-12 11:46
     楼主| 发表于 2018-11-30 23:05 | 显示全部楼层
    #include <Ucglib.h>
       MicroSD card 与 esp32 SPI引脚连接:
       MicroSD Card | ESP32
          GND        GND
          VCC        3.3V
          SCK        D2 SCK
          MOSI       D4 MOSI
          MISO       D3 MISO
          CS         D5 CS
    #include "FS.h"
    #include "SD.h"
    #include "SPI.h"
       SSD1351 OLED | ESP32 SPI 4线或5线引脚连接
           GND        GND
           VCC        3.3V
           SCL .      A3 SCL1 | A5 SCK1
           SDA .      A4 SDA1 | A8 MOSI1
           RES .      A9 | GDIO--
           DC .       A6 MISO1
           CS         A7 CS1
    #define my_sclk 25
    #define my_mosi 26
    #define my_dc   12
    #define my_cs   15
    #define my_rst  2
       本例程使用的scl sda 5线连接
    Ucglib_SSD1351_18x128x128_FT_SWSPI ucg(/*sclk=*/ my_sclk, /*data=*/ my_mosi, /*cd=*/ my_dc, /*cs=*/ my_cs, /*reset=*/ my_rst);
    // Color definitions
    #define BLACK           0x0000
    #define BLUE            0x001F
    #define RED             0xF800
    #define GREEN           0x07E0
    #define CYAN            0x07FF
    #define MAGENTA         0xF81F
    #define YELLOW          0xFFE0
    #define WHITE           0xFFFF
    #include <dht11.h>
    #define test_led LED_BUILTIN
    dht11 DHT11;
    #define DHT11PIN 14
    String text;
    // the file itself
    File bmpFile;
    // information we extract about the bitmap file
    int bmpWidth, bmpHeight;
    uint8_t bmpDepth, bmpImageoffset;
    unsigned long startTime, endTime; // For calculating FPS.
    unsigned int frames;
    #define ATN 5         // 定义MicroSD card CS片选引脚
    #define SD_CS ATN     // 定义SD卡的CS片选
    #define sd_led D6
      Serial.println("DHT11 TEST PROGRAM ");
      Serial.print("LIBRARY VERSION: ");
      Serial.println(DHT11LIB_VERSION);
      Serial.println();
      pinMode(test_led,OUTPUT);
      digitalWrite(test_led,HIGH);
      pinMode(sd_led, OUTPUT);
      digitalWrite(sd_led, HIGH);
      pinMode(SD_CS, OUTPUT);
      digitalWrite(SD_CS, LOW);
      ucg.begin(UCG_FONT_MODE_TRANSPARENT);
      ucg.clearScreen();
      /***********检查装载MicroSD是是否成功**********/
      if (!SD.begin(SD_CS)) {
        Serial.println("Card Mount Failed-SD卡装载失败");
        DrawFoneStr(0, 15, 8, "SD Card Failed!" );
        digitalWrite(sd_led, LOW);
        return;
      DrawFoneStr(0, 15, 8, "SD Card OK!" );
      Serial.println("SD卡装载完成");
      sdType();//验证SD卡类型
      /***********装载DH11温湿度和验证是否装载***********/
      int chk = DHT11.read(DHT11PIN);
      Serial.print("Read sensor: ");
      switch (chk)
        case DHTLIB_OK:
          Serial.println("OK");
          DrawFoneStr(0, 75, 8, "DH11 OK!" );
        case DHTLIB_ERROR_CHECKSUM:
          Serial.println("Checksum error");
          DrawFoneStr(0, 85, 8, "DH11 Checksum error" );
        case DHTLIB_ERROR_TIMEOUT:
          Serial.println("Time out error");
          DrawFoneStr(0, 95, 8, "DH11 Time out error" );
        default:
          Serial.println("Unknown error");
          DrawFoneStr(0, 105, 8, "DH11 Unknown error" );
      uint64_t cardSize = SD.cardSize() / (1024 * 1024);
      Serial.printf("SD Card Size: %lluMB\n", cardSize);
      DrawFoneStr(0, 55, 8, "SD Size:" );
      ucg.setFont(ucg_font_helvB08_tr);
      ucg.setColor(255, 255, 255);
      ucg.setPrintPos(60, 55);
      ucg.print((int)cardSize);
      DrawFoneStr(90, 55, 8, "MB" );
      //readFile(SD, "/1.bmp");
      delay(300);
      //readFile(SD, "/2.bmp");
        listDir(SD, "/", 0);
        createDir(SD, "/mydir");
        removeDir(SD, "/mydir");
        listDir(SD, "/", 2);
        writeFile(SD, "/hello.txt", "Hello1111 ");
        appendFile(SD, "/hello.txt", "World! chine\n");
        readFile(SD, "/hello.txt");
        deleteFile(SD, "/foo.txt");
        renameFile(SD, "/hello.txt", "/foo.txt");
        readFile(SD, "/foo.txt");
        testFileIO(SD, "/test.txt");
      Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
      Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
    delay(50);
      startTime = millis();
      frames = 0;
      for (int n = 0; n < 1; n++) { // .46 FPS before SPI_FULL_SPEED was added to SDClass::begin in SD.cpp in SD library.  .56 fps after.  1.46 FPS after adding block transfer to SD lib.
        bmpDraw("/1.bmp", 0, 0);
        bmpDraw("/2.bmp", 0, 0);
        bmpDraw("/3.bmp", 0, 0);
        frames = frames + 3;
      endTime = millis();
      ucg.setColor(255,255,255);
      ucg.drawFrame(0,0,127,127);
    2019-2-1 08:59
    发表于 2019-1-31 14:16 | 显示全部楼层
    使用软件模拟的SPI速度肯定慢,U8GLIB中SSD1351支持硬件SPI
      U8GLIB_SSD1351_128X128_4X_332(uint8_t cs, uint8_t a0, uint8_t reset = U8G_PIN_NONE)
          : U8GLIB(&u8g_dev_ssd1351_128x128_4x_332_hw_spi, cs, a0, reset)
    学习记录2,Blinker读取温湿度
    学习记录2,Blinker读取温
    学生智能打卡系统(接入blinker)
    学生智能打卡系统(接入bl
    关于红外控制空调的模块选型
    关于红外控制空调的模块选
    想问问这中模块能支持arduino吗
    LCD1602只亮 不显示
    LCD1602只亮 不显示
    18脚的8x8LED点阵如何使用??
    18脚的8x8LED点阵如何使用
